Question about Mitsubishi Televison & Video
I don't know how to open bottom cover my Mitsubishi VCR model hs-ms11v to change belts as my tape wont eject but get mangled up thanks
SOURCE:
dodgecharger
  • 254 Answers
SOURCE: VCR eats tape when rewinding
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
Posted on Jul 10, 2007
  • 579 Answers
SOURCE: vcr hs-u500
Typical belt drive failure. Take the cover off and turn the loading motor shaft with your fingers until the tape is ejected. Get a belt kit for this model and replace all the rubber parts in your VCR. Mitsubishi's are nice units and worth fixing. Check the little pulley under the capstan motor for cracks or worse.
Posted on Dec 31, 2007
sharcnet
  • 2130 Answers
SOURCE: Mitsubishi HS-U61 SVHS
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or have the belt replaced. Belts are inexpensive but sometimes difficult to get to. Most of the repair expense will be in the labor. Unplug the unit and take the cover off. Hopefully there will be enough clearance so you can get to the tape. Try to find the motor and belt that is responsible for operating the eject mechanism. The motor will look like a shiny cylinder, about the diameter of a quarter and will have a plastic pulley attched to the shaft. You can rotate the pulley and belt with your fingers and manually eject the tape. If the tape is around the spindles and video head, you will need to manually move the mechansim that retracts the spindles and returns the tape to the cartridge. While you may be successful in getting the tape out, you need to find out what caused the problem in the first place. Putting in another tape will most like become stuck again unless the problem is identified and resolved. Also look for a broken spring or cracked gear (missing teeth) in the eject mechanism. Please let me know if I can be of further assistance Good luck! - Jim
Posted on Feb 28, 2008
  • 1153 Answers
SOURCE: Replacement Belts for Mitsubishi HS-U560
You can try Vancebaldwin.com or MCM electronics corps, or even tritronics INC.
Posted on Mar 22, 2008
SOURCE: My Mitsubishi VCR HS-M60V rejects cassette tape
Take it to a technician
Posted on Aug 28, 2009
I have a Mitsubishi HSU48. The tape is stuck in the VCR. I cannot get it out. Do you have any suggestions
I had this problem with this specific machine. These answers have all been general to any VCR. The Mitsubishi HS-U448 has its motor underneath the machine. You don't have to remove the top cover at all. Just remove the bottom plate and spin the motor (the correct direction) to completely eject the tape.
Dec 23, 2010 | Mitsubishi HS-U448 VCR
It ejects the tape immediately...and then it powers off.
older VCR--I have one like it. You need to remove top cover and bottom shield, look for one of the belts to be either broken or off.
There are places on the net where you can buy a belt kit, includes all belts and most are easy to replace--they get old and sloppy with age.
If this has helped you rate this solution as very helpful as I do this here for free.
SD TECH
Aug 22, 2010 | Mitsubishi HS-U570 VCR
Tape stuck will not eject
open vcr look for a belt on the right side of the vcr and begin manually turning it until the tape ejects
Jan 04, 2010 | Mitsubishi HS-U770 S-VHS VCR
In Mar.89 I bought a VCR Model HS-U50. Works great BUt a tape is now stuck in the cassette loading slot and while the Power button comes on and I try to eject the tape, since it wont come out or eject, the...
I took the cover off and noticed the tape was wrapped all around some wheels and unwrapped the tape from the wheels and got it out. Ate the tape up BUt at least its out. However, I tried a new tape and can now see what the problem may be. It keeps on eating the tapes, they get all scrunched up inside around various wheels and while I can get it out, each tape is mangled and beyond use. So something is causing the VCR to incorrectly wrap the tape around each aligned whlle. Dont know how to fix this , BUT since I wont be able to get parts or help on here to do it by myself, Can you be kind enough to find me a repair service outlet in Ottawa, Ontario, canada.
Dec 26, 2009 | Mitsubishi Televison & Video
A tape is stuck in my VCR. and i cant get it out, How can I remove it? notheng
Open bottom metal cover. Rotate the belts of the motor. Cassete should unload from Spindle and reel back into the cassette. Then please open the VCR top, and you will see a belt and gearmechanism on the right side of the cassette compartment. Manually rotate the gears and the tape will slowly come out.
Jul 20, 2008 | Mitsubishi HS-U560 VHS VCR
Feb 28, 2008 | Mitsubishi HS-U447 VHS VCR
Vcr hs-u500
Dec 30, 2007 | Televison & Video
Jul 09, 2007 | Mitsubishi HS-U781 S-VHS VCR
Televison & Video Logo
26 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
