I have a cd in the play back and a cdrw in the record side and when i go to record from side one to side two it say in the display window no audio... i also have the device set to analog, not coax or opt
SOURCE: problem with audio cd-recorder LG adr-620
First of all, CD-RW will not work in most regular CD players.
CD-R should work in other players but you will need to finalise them first. Refer to your manual on how to finalise a disc. Once finalised your discs should play in 99% of machines. Only very old machines (from the 80s) might have problems.
SOURCE: LG ADR 620,Won`t record or play.
Mine keeps doing this. It isn't a disc compatibility problem. I find if I switch the machine off completely for about half an hour and then switch it back on the problem fixes itself.
SOURCE: won't record
Are you using CD-R- Audio or Music discs? It won't record onto computer (data) discs)
