Question about JVC COMPACT VHS-C CAMCORDER
E04 I TRIED A HEAD CLEANER IN THE CAMERA AND NOW IT JAMBS WITH THE EO4 MESSAGE AND "PLEASE REMOVE AND REATTACH BATTERY"
  • 156 Answers
Thre is problem with drum assy .may the speed of drum is not correct.try to replace with a new one.
Posted on Feb 04, 2008
Shows fault E04 remove & reattach battery
Do a search of this problem and you will ind that every JVC owner is having the same problem. I finally got mine "reset" by powering the unit on in payback mode while holding down the "play" button. Then, turn it back off and power it on in the camera mode while holding down the "rec" button. This seems to have reset it and I've not had anymore issues SO FAR!
Good luck with it.
Apr 28, 2009 | JVC Video Cameras
Hi, Regarding the above fault with my JVC camcorder, I have solved the problem by removing the tape and replacing with a new one. Thanks anyway.
Regards,
**** Coupe
Mar 30, 2009 | JVC Video Cameras
Camera gives message E04. What can I do?
Sounds crazy, but It worked for me. I open up the tape door, ejected the tape. lightly squeezed the two long sides of the piece that hold the tape in place. I placed the tape back in. The tape fit slightly more snug in the cassette holder.
This worked for me.
Feb 20, 2009 | JVC GR-DVF31U Digital Cybercam GRDVF31U...
E04 Error
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
Jun 26, 2008 | JVC GR-DVF21 Mini DV Digital Camcorder
Jvc gr-dvx9 E04
The mechanism is out of sync, put a tape in and hold it, it wont go in but will try to open don't let it, remove the battery and reattach, let the tape eject, rinse and repeat 3 or 4 times and it will finally accept the tape.
Jan 08, 2008 | Video Cameras
JVC GR-DVX90
Put it on fire and buy some good camcoder<br />
Dec 16, 2007 | JVC GR-DVX9 Mini DV Digital Camcorder
E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 18, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 17, 2007 | JVC GR-DVF21 Mini DV Digital Camcorder
Video Cameras Logo
75 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
