Question about Refrigerators
Coldspot 106.61982101 rust bleeding through door
I have used both the white magic sponge and some CLR spray. The rust stains, scattered all over refrigeration door *not top freezer unit door, look much better. BUt how can I stop them from coming back, and how can I prevent further rust from developing?
    Top Expert:
  • Refrigerators Master
  • 21,326 Answers
Will need to sand down to metal no rust then primer then repaint --or spray or wire on a rust away product most auto or home stores carry it
Posted on Jun 02, 2019
    Top Expert:
  • 25,081 Answers
Repaint it
SOURCE:
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
aborcass
  • 2651 Answers
SOURCE: Repainting doors on whirlpool white refrigerator
oowwwww!!! thats what we call in the refrig biz "refrig cancer" the door itself is actually rusting from the inside out. the older refrigs used fiberglass insulation inside the doors which has a tendency to hold moisture, and overthe years rusts through. the new door use blown-in poly styrene foam far less likey to hold moisture. That being said you could remove the door lightly sand and paint, can of krylon enamal aint should do it, at least for a little while anyway
Posted on Nov 30, 2008
SOURCE: New LG 8000 btu a/c units are rusting
I have a similar situation with 66 a/c units in my motel. The problem is the drain valve in the back of the unit (near the compressor) does not function properly. It is supposed to open when the water temp (laying in the bottom of the unit) gets to 50 degrees cusing the drain valve to open and let the water out. The problem is the water never reaches 50 degrees when the outside temperature is in the 80's. So the water sets in the units. The fan sprays the water over the fan motor, heating element and inside the chasis causing it to rust from the inside out. I have notified LG and they are investigating it...... Amana has the same problems with their units which use the same drain valve and they have removed the drain valve in several motels in the area.
I would suggest removing the drain valve or wedging something under the little round plate so the the unit drains. Also make sure your A/C is tilted properly so the water runs to the back of the unit and drains.
Posted on Oct 09, 2009
Testimonial: "My a/c is still under warranty so LG drilled a small hole in corner of the drain pan on the side where the water was spraying out. Works great now!"
  • 414 Answers
SOURCE: The interior of my refrigerator
Try applying a paste of "Barkeepers Friend" instead, let it sit overnight. It will eliminate
rust stains and it works well on tubs also. If you must paint the racks, use Rustoleum
Appliance Epoxy. Hope this is helpful.
Posted on Apr 27, 2011
murf427
  • 336 Answers
SOURCE: Orange stains on clothing
I had detergent with oxy-cleaners do this.
murf427
Posted on Aug 01, 2012
How to use acid citric to clean a thermal 5lr boiler
Use CLR or white vinegar. If it is a plumbed in unit, there is usually a small bypass tank at the rear and a crossover valve where you put the descaler and then run the cycle. On others, you fill the water tank and run the descale program.
The amount of Citric Acid you would need is prohibitive, CLR is a better product.
CLR Calcium, Lime & Rust Remover is a powerful formula that quickly and easily dissolves and removes tough calcium and lime deposits as well as surface rust stains from bathtubs, toilet bowls, sinks, glass, chrome, fiberglass, stainless steel, most coffee makers, humidifiers, dishwashers, washing machines and ...
CLR Calcium, Lime & Rust Remover - Jelmar ' We Clean More Than ...
www.jelmar.com/CLRbasic.htm
CLR descaling coffee machine Google Search
Oct 03, 2017 | Coffee Makers & Espresso Machines
Removing rust stains from silk
You can use the old lemon juice and salt trick. Place a sponge or towel under the stain, and use a washcloth or very soft brush to work it through the fabric. When the stain looks gone, wash the entire thing as per manufacturer's instructions.
If that doesn't work, try hydrogen peroxide..the disinfectant you can get from the **** store..in a spray bottle with a mild detergent, or one of the oxygenating cleaners, like Oxyclean, mixed with a bit of water.
Work it through the fabric just like the instructions above.
Jul 20, 2014 | Clothing
How can I remove coloured marks made by toys
Mr Clean magic eraser. Its a white sponge. It works.
Jun 02, 2014 | Villeroy & Boch Home
How can I clean stains in concrete?
It depends what the stain is. Concrete is porous and like clothing, some stains are permanently set. Detergents remove oils. Surfectants take it a step further. Acid removes scale. Cat litter can soak up standing oil. Once clean to satisfaction, seal the concrete to help prevent future staining.
Jul 22, 2013 | Building Materials
What does de-scale mean?
To de-scale anything in relation to water means to remove the mineral scale buildup on the walls or where ever. That's the usually white chalky stuff that you might see around nozzles etc. Follow yu manuals instructions to de-scale. Usually involving white vinegar, or possibly a product like CLR for removing minerals and rust stains. I AM NOT SAYING TO USE CLR IN YOUR MACHINE, just indicating an example of a product that manages mineral scale. Read the manual to do it correctly.
Nov 26, 2010 | Keurig B100 Coffee Maker
I have 3large brown stains on the lower portion of the back panel
Probably rust stains bleeding through, try CLR. Don't get it too wet or the panel behind it will rust more. Use one of those vacuum type cleaning machines that spray a little and picks it it back up Good Luck. We owe this attempt in honor of Billy Mayes.Good Luck
Jul 11, 2009 | GE XL1800 1100 Watts Microwave Oven
How to get the clean off an ge coffee pot?
Automatic clean function
The coffee maker is equipped with an automatic clean function. After 60 brewing cycles, the clean indicator/button (22) lights up. This indicates coffee maker should be cleaned by using the automatic clean function and the charcoal filter (17) should be replaced.
NOTE: The coffee maker can continue to be used, when clean indicator/button (22) is on.
• To begin the cleaning cycle, remove the charcoal filter (17) from the water tank (10). Fill the tank with a vinegar and water mixture (1/2 vinegar and 1/2 water) or a descaling product. Press clean (22) button for three seconds. The clean indicator/button (22) flashes and the cleaning process begins.
Cleaning process:
• 24 cycles of 7 seconds brewing and 21 seconds off
• 30 minutes rest
• Brewing the remaining descaling solution
• After cleaning process is complete the clean indicator/button (22) goes off. Fill water tank (10) with clean water and run one brewing cycle to rinse the coffee maker.
• Change the charcoal filter (17) (ill. k). Reinsert the charcoal filter to the coffee maker (ill. l).
NOTE: You can use the cleaning function before reaching 60 cycles (especially if the water hardness is above normal). Press and hold clean indicator/button (22) for 3 seconds.
NOTE: The Cleaning Process takes 60 minutes to complete. You cannot cancel the cleaning process before it is complete. Unplugging the machine only delays the cleaning process.
Dec 21, 2008 | GE 106591 Coffee Maker
Rust on Jenn Air Refrigerator Door at Water Dispenser
You may end up respraying the door, but here goes.-
First mechanically remove as much of the rust as you can with an old screwdriver or similar scraper. Then use coarse emery cloth - 80 -120 grit untill all you're left with is shiny metal with rust pits.
You may need to go out further than you think - about 1" all round.
Then use a paint- on de-rusting fluid from vehicle products supplier. When all rust is black or dissapeared, use a zinc primer on all the bare metal. (this will stop it reacuring)
Then either spray the area with an "appliance white" aerosol or squirt it into the cap, and use a paintbrush.
If you are spraying it, open all house windows and doors, cut a mask from newspaper- then tape it to the fridge. Use blankets , plastic dustsheet or old sheets to protect things, and spray it from 12" in several very light coats.
When done, "polish" with T cut - which should remove the rust stain too.
Seal the area of the original leak with a white or clear silicone - and sort the original leak out.
If you polish the plastic with a silicone spray, water will tend to stay put rather than seep.
Jun 11, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
273 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
