Sorry but does the dw911 xe type 1 radio charge the battery
Yes, the DeWalt radio will recharge the batteries, from the 12 Volt to 18 Volt versions. However, even with the radio plugged into an AC outlet, you have to either have the radio turned on, or have the unit in the AUX setting, in order for the batteries to get charged.
It typicaly takes about an hour +/- to fully charge a discharged battery. I normally don't put batteries directly into a charger right after they become discharged from being used in a tool, since they are still warm from use and charging them will generate more heat in the recharging
process.
Heat is the enemy of rechargeable batteries, so to get the longest working life out of your batteries, I'd let them cool down first, before recharging them, unless you absolutely need to use them right away, then go ahead and recharge them. If you can delay recharging them until they've cooled down, you'll get a more fuller recharge out of them.
Hope you find this Very Helpful and best regards!
put in new batterie still not working didnt want to open up and brake something
Works off power cord but not off battery. Doesn't charge a battery either. Looking at the female battery connector inside the radio, it seems that one of the conductors isn't in the slot where it should be. Is there a schematic showing how to take it apart? I can hear the conductor rattling around inside.
Thanks
