Question about Microwave Ovens
Comination Microwave Make  Panasonic Model NN-A752W Problem Oven and grill work fine.  Since last week microwave function does not work. I have tried different power settings. All appears fine, lights, turntable and clock timer.  The trouble is that there is no heat imparted to the food at the end of the cooking time. I have found and checked 2 internal fuses - they are ok.
  • bwos Jan 07, 2008
    Amana ACO1860 1000 Watts Microwave Oven
    Lights and turntable come on but the magnatron does not come on. If I oush hard on the top of the control pannel, the power comes on. It will cook as long as I hold it firmly there.
  • Microwave Ovens Master
  • 9,098 Answers
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
I would think it's not a door switch problem since the oven and grill work.
I'd say this is a problem with the inverter or a bad magnetron.
More importantly, due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 28, 2007
My panasonic NN-8500 microwave/convection oven the microwave part is working fine but,the convection grill defrost is not
Possibly the defrost heater element has failed. You will need to strip the cabinet off and use a multimeter to test the element. May also be the overtemp safety thermostat may have failed.
Nov 19, 2016 | Panasonic Microwave Ovens
Microwave trips and switches off within 2 seconds
We regret reading about your microwave. At this time we recommend you have the unit evaluated by an authorized service center.
May 01, 2014 | Panasonic NN-S254BF Microwave Oven
After many years of good service my Dimension 4 does not microwave. It goes through all the motions but doens not heat the food. the convection and grill functions are working fine. HELP!
Hi Michael,
i think something wrong with its high-tension circuit or your magnitron is bad.
the minor fault is open of therm stat for protection.
or burnt fuse in circuit.
Jan 09, 2014 | Panasonic NN-T888S Convection/Microwave...
Need user manual for National model no: NN-8655 Microwave oven user manual...
I would suggest that contact the dealer from whom you purchased the oven or call any number listed on the model tag of the oven.
Jan 06, 2014 | Panasonic Microwave Ovens
I have a panasonic microwave with convection oven, grill and steamer. When I switch on the microwave, the house fuse (16 amp) cuts out. With the other functions of the oven, it works fine. Do I need a new...
you have a short circuit.
test the a) HV rectifier b) Capacitor HV c) HV transformer d) Magnetron e) test the swich for door for short.f) circuit board main is short.
see the diagrams and proceed.
Oct 01, 2012 | Panasonic NN-C994S Convection/Microwave...
My Panasonic nn-s262 microwave/fan keeps reseting every time I try to use the microwave. The fan works fine and the light worked fine until today, it now resets the microwave. What can it be?
internal short that can damage your control panel but do not try to fix it yourself its got 4000v !!! sorry :( your life worth more then this microwave.
Dec 30, 2009 | Panasonic NN-S262SF Microwave Oven
Panasonic Microwave model # NN2505C stuck on Demo mode following power outage do not know how to return to normal function
The manual is not available on line so I do not know if this will work but try pressing FUNCTION-0-2.
Nov 01, 2009 | Panasonic NN-T655SF Microwave Oven
Our microwave oven Panasonic NN-S252WF stops after
Our technician suggest that there may be a problem with the Inverter Board in this model, which is something that would need to be looked at by a Service Center.
In rare cases it could be the door switches.
Mar 27, 2009 | Panasonic NN-S252WF Microwave Oven
Microwave not working but oven and grill do
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Dec 17, 2008 | Panasonic NN-C980 Convection/Microwave...
Panasonic dimension 4 microwave/convection oven
Does this unit have a turntable? If so does it turn when on?
Sep 24, 2008 | Panasonic NN-C980 Convection/Microwave...
Microwave Ovens Logo
159 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
