once you press RESET you will not be able to connect wirelessly, you have to configure the router. you can only do that via a LAN cable connected PC. switch router off for at least 10 seconds. attach a pc using a lan cable to ports 1/2/3/4 NOT to the WAN port(5). switch on the router and start your browser. type in either http://router or 192.168.2.1 to get router menu up. configure the router because you have RESET it. http://www.belkin.com/uk/support-article?articleNum=8181
That is connect. You will need to connect the router to the modem with the Ethernet cable.
First connect the computer to the modem with the Ethernet cable. Make sure that you can access Internet without router.
Connect the computer to the Ethernet port 1 and modem to the Internet port on Linksys router. Open the setup page of the router. Change the Internet connection settings according to the Internet service provider. Create a wireless network and then connect your computer and other devices to the wireless network.
Please connect the internet cable on the Belkin router and the ethernet cable to your machine and the other end to the belkins ethernet port,then turn on the device and wait for the appropriate lights are turned on
Then if your machine is win xp,Click Start and run and type cmd
Hit enter you will get a black window
Type in ipconfig and hit enter
the default gate way is usually 192.168.2.1
minimize it and open up the browser and type 192.168.2.1 in the address bar
hit enter you will get a window type admin in username and password and provide your connection details and save it
If ever I have had a problem with my D-Link I have contacted them directly and they have solved it over the phone for me. There is an initial answer message that states that you MAY be charged $40 for the help ... but I have never been charged. It is a brilliant service. phone 0800 900900. I hope that this helps you.
What people use is a Roku box and a wireless router. You can stream the Netflix movies from the wireless router to the Roku box which connects to your TV. There are some new TVs that have built-in wireless adapters and in that case, you don't need the Roku box.
I have dlink 2100ap wireless router any body had access my wireless network but i want to ristrect network just like network passkey how can i give my dlink 2100ap wireless router pass key please give me reply
To access your router you should goto http://192.168.0.1 - It should explain in the manual.
You may have to set the router in Cable Modem mode as it may be in DSL mode now.
I hope this may help.
ALSO! There should be a little hole in the back that you can put the tip of a pen into to press a button and it will reset the router back to factor defaults. Default settings would be cable modem mode. Be sure to have the router powered on and press the button down for 10 secs and notice the lights on the router should flash. After that power down the router, by unplugging the power and the plug it back in. It should be set back to factory defaults.
I have the Belkins "G" Wireless Router I cannot get it connected to my Computer System. I also have the Installation CD but need to know how many Ethernet Cables should I have to start the stallation? What color are the cables? I think that I am missing an Ethernet Cables. The Ethernet Cable Connections on the Router are color coated. The Serial Number is: BELL7D4811F - Belkin "G"Wireless Router: Model No. F5D7230-4
