Question about Royal Office Equipment & Supplies
How do I set a left hand margin on a royal scriptor II typewriter?
  • Royal Master
  • 27,422 Answers
SOURCE:
JayBlair
  • 328 Answers
SOURCE: Margin Release for Brother GX-6750 Typewriter
Typewriters have alimit to how far to the right or left that you can set margins. Once you use the alt & 6 key to bypass the current margin setting then move to the new setting then hold the alt key and touch the 7 key to keep it in the new position.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 18, 2008
SOURCE: Olympia Startype 3 Typewriter
I need a manual for the olympia startype 3 typewriter. How do I optain that?
Posted on Oct 08, 2008
Geno111
  • 183 Answers
SOURCE: Setting Margins
move the carrier to where you want the mar.set then hit the R MAR or L MAR key.
to move the carrier beyond the margins hit the MAR REL key
Posted on Nov 25, 2008
  • 125 Answers
SOURCE: Left and right margins of typewriter on Brother ML 500 Memory
Hi:
First find the margin release key and press it once. Then use the spacebar to move the carrier forward and reset the right margin. Or again use the margin release key by pressing it once and then press and hold the backspace key to move through where the left margin was and reset it at the point where you want it.
Andrew
Posted on Mar 19, 2009
  • 46 Answers
SOURCE: resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Posted on Jun 26, 2009
How do I set or change the margins on my Royal Safari typewriter?
If you are following user's manual instructions to reset the margin and can't, maybe your Royal Safari is defective? Insist trying and if still no luck try to ge a typwriter repairman, a species in near extintion by now.
Jul 02, 2015 | Royal Office Equipment & Supplies
Why my royal Satellite II Typewriter has a beep?
Does it work or does it just beep. Could have the margins set together.
Jul 30, 2014 | Office Equipment & Supplies
Royal FP Typewriter's left Magic Margin is not holding. How can I fix it?
There is a spring that holds the margin together locking in place, most likely the spring is gone or the teeth are broken.
Mar 01, 2014 | Royal Typewriter Circa 1957 Fp
Cannot set left margin instructions on clearing display before setting margins
Go to the L. margin , press but don't hold the MAR REL key, backspace or space to the desired location, press L. MAR key.
DickyO
Jul 13, 2011 | Royal Satellite 80 Typewriter
How to set margins
after hitting the return key, the carrier goes all the way to the left margin. If you need the margin to move even more to the left, hit the margin rel key and backspace to the desired position and hit the mar left key. Same for the right margin, use the space bar to move the carrier all the way to the right margin and press the margin rel and move the carrier to the desired position and press the mar right key.
Jan 27, 2010 | Royal Satellite 40 Typewriter
Margin settings
You have to hold the magic margin button down while you move the carriage all the way to the left, then release the margin button. Then repeat for thr right margin. Hold the right magic margin button down while moving the carriage all the way to the right, then release the margin button.
Sep 05, 2009 | Office Equipment & Supplies
How do I get the left hand margine to release on my Royal typewri
Generally yoy can set the left margin all the way to the left by holding down the left margin key and pushing the carriage return button
Mar 23, 2009 | Office Equipment & Supplies
Resetting the margins on a manual typewriter.
Feb 19, 2009 | Royal MS 25 Typewriter
IBM Wheelwriter 5 (Setting the Margin back to 5"
Sounds like you don't know how to set l. margin or you have some debris in the typewriter. Turn it off and see if the carrier will move back and forth by hand, if so turn it on 7 return to l. margin press mar rel key, backspace to where you want the margin and press l. margin key.
hope this helps
DickyO
Jan 15, 2008 | Lexmark Wheelwriter 5 Series II Typewriter
266 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
