Question about Linksys Wireless-G WRT54GS Router (e125894)
Wireless channel how do i change the wireless channel on my router to match my wan
  • 1 more comment
  • WhitWheels Nov 27, 2007
    Further: should have said i want to connect wirelesly, works fie on Ethernet. works intermittently wirelessly, usually until i turn laptop off. I have a community alarm in house, which is wireless and wireless phone. the alarm is on channel 11 the phone swaps round i think. So I want to change my computer / router channel. the wlan is on chanel 1.
  • Anonymous Jun 01, 2008
    I have two routers one is the main router it is a WRT54G and i have a WRT54G2 on the other end for the other side of the house. the 54G is Channel 6 and the 54G2 is on channel 6 I need to change the 54G2 to another Channel but am having trouble doing that
  • Anonymous Mar 30, 2014
    RT-N66R
  • 205 Answers
Linksys routers have a built-in webpage server. You need to use your web browser to go to it's IP address. I think the default IP for Linksys is 192.168.1.1 (type that in the address bar of your browser).
Once you get to the router's webpage I think you need to go to the "Wireless" section and there you should be able to change the channel. That's where I found the channel on my Linksys wireless router.
Good luck.
Posted on Nov 27, 2007
  • 51 Answers
The ethernet cable connecting the router to the WAN doesn't require a channel. The channel setting is there for when laptop computer connects to the wireless router.
Channels 6 and 11 are mostly used in this scenario.
Does your wireless router communicate with your Internet provider wirelessly?
Hope this helps :) Please leave a rating. Thanks..
  • Mrunal Mody Nov 27, 2007
    The phone should be on 2.4 GHz, 5.8 GHz or lower. With the community alarm being on Channel 11, there seems to be the interference.
    What is the version of your WRT54GS?
HOW TO Connect tl-740n wireless WIFI router to PTCL DSL WIFI ROUTER
The easiest way to chain two wireless routers. *Please note this is just to have wireless access*
Make sure DHCP is enabled for both, make sure their SSID (the name that shows up when you connect to it) is different.
Make sure they are both different networks. So for example configure the first for 192.168.0.0 network and the other for 192.168.1.0. Now plug an Ethernet cable from the 740n router (WAN) port into a (LAN)
Second method *This only works if the tl-740 router supports AP mode (Access point).
In the configuration of the 740 router, enable AP mode and make sure DHCP and nat are turned off if they are on. Configure the wireless to operate on channel 1 6 or 11. Name the SSID the same as the other router. Plug in Ethernet from WAN 740 to LAN on the other router. Now on the DSL router make sure the SSID is the same and select a different channel from (1,6,11). Now you're all set.
Jan 26, 2013 | D-Link DSL-G604T Wireless Router
Update error message #32004
To solve this error :
Ensure you are using a broadband or high speed internet connection such as cable, DSL, or fiber optics. Slower connections, such as dial up, may cause issues with the Wii or may not work properly.
Ensure there is no interfering devices by shutting off microwaves, cordless phones, wireless keyboards, and wireless mice.
Disable your firewall settings, as it may be causing a connection problem.
Try changing the channel of your wireless router to either channel 1 or channel 11 which can increase download speeds. Be sure to test both channels to see which works better or faster.
If you are using a Netgear wireless router, disable the SPI firewall setting which is usually found under the WAN Settings of your wireless router.
If you are attempting to connect your Wii console online using the Nintendo Wireless (Wi-Fi) USB Connector and you receive this error.
Aug 23, 2011 | Nintendo Wii Console
How do I set up a security password
Here's a video on how I did it on my F9K1003V1.
Aug 09, 2011 | Belkin Basic Wireless Router
Hi,i am having edimax br-6204 wlg wireless router and i am facing problem sometimes RTD reaches more than 2000ms & getting request timed out in between.I am suspecting WAN port speed is not matching...
Hi best is to choose 100 full duplex you may find this setting in web base router page by typing 192.168.1.1 username admin and password 1234 this is default if you not changed it find WAN setting if there is option you can change it to 100 Full duplex most of the Routers has auto sense features than can do for you should you need any help please contact me http://computernetworksupportindubai.com/
Jul 22, 2011 | Edimax BR-6104 Broadband Router. One...
I want to change the channel my Linksys is using. So I went to Internet Browser and typed in my IP address. It said I need a Username and Password. Where would I find that.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . If you are not able to access router with above user and password then yo need to reset it. For that press RESET button for 10 seconds it is in back side of router.Then configure it again with above method.
Let me know if you need further assistance. Thanks for using FixYa.
Dec 05, 2010 | Linksys Wireless-G WRT54G Router
I need my wep/wpa pass phrase
just configure again your router.
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
======= WIRELESS SETTING UP A WIRELESS CONNECTION ================
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Oct 10, 2010 | Belkin (F5D8231-4) Wireless Router...
Intermitence wireless
This can be caused by various issues but the first thing I would check is to change the channel your wireless router is broadcasing through. Many 2.4Ghz cordless phones, as well as microwaves can cause the signal level to drop in and out on your wireless devices. You have to access the web page for your router to change the channel and then you have to change the channel on your wireless device to match as well. It will be a trial and error process to determine which channel works best for your devices. There should also be step by step instructions in your user manual which will walk you through the process. Hope this helps
Aug 03, 2010 | D-Link AirPlus DI-524 Wireless Router
Disable firewall in router and change wireless chanel to 11
To disable firewall and change channel on the router please perform the below task:
1. Connect a computer to the router using any one of the 4 available ports. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the username as "admin" and password as "password" (please note that the username and password are case sensitive).
4. Click on WAN setup from left menu. Set the MTU size to 1400.
5. Check the box for 'Disable SPI Firewall'. Click apply.
6. Click on wireless settings in the left hand side menu under Basic Settings.
7. Change the wireless channel on this page and click apply.
Hope this allows you to resolve the issue. Let me know if you need any further help.
Regards
Anand
Apr 13, 2010 | NetGear WGR614 Wireless Router
My dynex won't connect to my laptop
Try to change the channel first on your router. Access the router's admin page through http://192.168.1.1 and look for wireless tab and change the channel to 11. Save the settings. On your laptop, verify if your wireless settings is matching the router's wireless settings like the SSID and the security or encryption used.
Aug 02, 2009 | Dynex DX-E401 Router
D-Link AirPlus Xtreme G DI-624
Using the Configuration Menu
Note: if you have changed the default IP Address assigned to the DI-624, make sure to enter the correct IP Address.
 Open the web browser
 Type in the IP Address of
the Router (http://192.168.0.1)
12 Type admin in the User Name field
Leave the Password blank
Click OK
Home > Wizard
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
.13
Using the Configuration Menu (continued)
Home > Wireless
Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
SSID-
Channel-
6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP-
Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-624 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption-
Select the level of encryption desired: 64-bit, or 128-bit.
Key Type-
Select HEX or ASCII.
Keys 1-4-
Input up to 4 WEP keys; select the one you wish to use.14
Home > WAN > Dynamic IP Address
DI-754
Dynamic
IP Address-
Choose Dynamic IP Address to obtain IP Address information automatically from your ISP. Select this option if your ISP does not give you any IP numbers to use. This option is commonly used for Cable modem services.
Host Name-
The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address-
The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone
MAC Address-
The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the "Clone MAC Address" button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Enter a DNS Address if you do not wish to use the one provided by your ISP.
Primary/
Secondary DNS Address-
MTU-
Enter an MTU value only if required by your ISP. Otherwise, leave it at the default setting.15
Home > WAN > Static IP Address
Static IP Address-
Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address-
Input the public IP Address provided by your ISP.
Subnet Mask-
Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP
Gateway Address-
Input the public IP address of the ISP to which you are connecting.
Primary
DNS Address-
Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary
DNS Address-
This is optional.
Aug 27, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Linksys Wireless-G WRT54GS Router (e125894) Logo
194 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
