Question about Canon imageCLASS® MF4150 All-In-One Laser Printer
Toner my imageclass mf4150 keeps saying " toner not set insert toner"
  • 3 more comments
  • pzubekdw Dec 10, 2007
    I get the smae message after putting in a new laser cartridge.
  • Anonymous Dec 23, 2007
    I have the Same problem - purchased new toner - worked for 10 minutes - now I am getting the same error. Very Frustrated!!!!
  • Anonymous Jan 16, 2008
    EXACT SAME PROBLEM... UGH!
  • Ansha253 Apr 18, 2008
    I'm also suffering from the same problem can any one fix the problem?
  • Anonymous May 16, 2008
    my device says 'toner is not set' .....HELP ME. Note that the machine is brand new.
I had the same problem with this printer. And I think I got the problem solved by removing the all paper from the paper tray, and re-inserting the toner cartridge. I think it is the problem with incorrect error message from Canon's printer. It is problem of paper being fed into the printer mechanism slightly.
Posted on Sep 12, 2008
  • Sherry Byrd
    Sherry Byrd Nov 08, 2012
    Yaaay! It worked. Your instructions fixed my printer. Thank you so much fo
  • Sherry Byrd
    ...opps. Thank you so much for sharing this solution.
I took all the paper from the paper tray, I found that actually there is a paper got stuck in the tray, I removed that paper, then put the paper back in the tray, then it worked.
Posted on Jun 21, 2009
I had this problem pop up on two of my machines this month. I tried new cartridges, cleaning it, updating the firmware, etc. Nothing worked. I finally started looking around in the machine where the toner cartridge goes and noticed a little round metal tab on the left hand side that seems to need to make contact with the printer cartridge so that machine knows the cartridge is there. I pulled the tab out a little bit to make sure it would contact the toner cartridge when it was in place and my problem went away.
Hope that helps.
Posted on Feb 20, 2009
  • troscher
    troscher Mar 21, 2013
    SPOT ON!! Mine is the MFC 6550 and the contact is on the right side for me. After two reman's and one OEM not working and started hunting and this blog was the first hit. Tried the paper solution. No good for me, then came to your post with the contact. I looked in my machine and tried to puch the contact back and it would not go back any further. Got a dental pick and was able to get behind the contact and I put a little tension on it and POP, it came out and my copier is back in business.
There is a firmware update from Canon that fixes this problem.
search on canon MF4150 and go to the Canon website for this product, then to the Drivers and Downloads tab.
Follow the instructions in the PDF file that is downloaded.
Posted on Sep 01, 2008
I have had a similar problem with my 4150. The only practicable advice I can offer is to remove the toner cartridge, and then clean the bay into which it fits, as well as any metalic surfaces with which it connects.
I just tried this, and the printer decided that it was actually suffering from a paper supply error. It offered me the chance to resume, which I took, and thusly, I got my page printed.
Still not happy, but. I am aware that this will envariably happen again, usually at 5.05pm on a Friday...
Posted on Jan 14, 2008
Just had the same annoying problem. Went and got a new toner. Installed it. Didn't work. Opened it and cleaned the area. Didn't work. Removed all the paper and put it back, in paper tray. Didn't work. Turned it of and back on, and it is solved. Mind you, I have turned it on and off at least 20 times already. So it was either the cleaning of the toner area, or the paper tray (or both), plus turning it off and on, that fixed it. Just put back the old toner and it is working fine, so i'll keep this one for later (already took that tape strip out, so I hope that will not make it go bad soon or something...)
Posted on Mar 19, 2009
Fixed mine immediately----after 2 differenr toner refilled carts, and a new one from office depot (which is being returned now!)
Posted on Mar 14, 2009
My printer MF4122 shows Toner is not set. Insert Toner. means what?
Believe it or not this error normally relates to the paper tray. Take all of the paper out of the tray and then reinsert the paper into the tray.
Hope this helps.
Sep 14, 2012 | Canon imageCLASS® MF4150 All-In-One Laser...
"Toner not set" persists, even though new
Hey!This happens a lot!Take out all of the paper,Open the cover,take out toner,put it back and add paper!!If this does not work then the toner sensor might be faulty!Good Luck!!
Nov 03, 2010 | Canon imageCLASS® MF4150 All-In-One Laser...
Canon image class MF 4150: it is flashing, message says toner is not set insert toner. Toner has been inserted, it was working this morning, I printed documents fine, now this message. I have taken the...
spacer.gif If you removed and reinstalled toner correctly several times and this error code is flashing, you need to try another new toner cartridge, even though the other one may seem still good to you. If this doesn't remedy problem the Troubleshooting section of the Canonusa.com website says to call 1-800-OK-CANON.
Jul 16, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
TONER IS NOT SET INSERT TONER
Inspect the cartridge may be some damage on it but the most likely the bug in the digital board PCB ***'Y
Jun 22, 2010 | Canon imageCLASS® MF4150 All-In-One Laser...
Put new toner in and dialog says "Toner Not Set"
I pulled out the paper, turned the machine off, reinserted the paper and restarted the machine. The toner message went away.
Pav
Apr 15, 2010 | Canon imageCLASS® MF4150 All-In-One Laser...
My canon imageclass mf 4150 says toner not set but there is a cartridge in it.
my canon imageclass mf 4150 says no paper even paper loaded, kindly help to solve.
Feb 11, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Toner is not set Insert toner. Toner is set.
toner is like the catridge.. i think yu ve an laser printr.. yur toner is removed or else loose.. yu shd fix tat problm... by checkin yur toner.
Jul 06, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Toner is not set insert toner
Your toner cartridges may be faulty, or the wrong one. Try another cartridge
Jan 02, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Toner replacement
When this happens it is usually because the paper has misfeed remove paper from cassette tray replace it then reseat toner.
Jan 03, 2008 | Canon imageCLASS® MF4150 All-In-One Laser...
Canon imageCLASS® MF4150 All-In-One Laser Printer Logo
584 people viewed this question
old marine
old marine
