Magnavox 19mf337b lcd tv
Screen has white lines running across it..warranty expired, is it worth fixing ?
  • Anonymous Sep 06, 2008
    I have the same model 19MF337B and it is under warranty. shop says the labor to fix it could cost $120 or more. Not sure it is worth fixing it.
If the cost of repair is 50% or more of the price you purchase the TV at, your better off buying a new TV.
Posted on Oct 09, 2008
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
I have a Magnavox 19MF337B, and it powers on and off a few times before staying on. After it powers on, I just get a white screen, and nothing else works. remote does nothing, and buttons on top do...
In some cases these TVs were to be returned for exchange. As costs were excessive. If this TV is out of warranty and you have no place to go with this TV, you might just have a hobbiest open the darn thing up. I would say you have a bad capacitor or two in the power supply. This is at its easiest repair. If not you may have a bad LCD panel and that is not worth replacing! Hope I could give a something to work with. Thanks for asking!
Aug 22, 2010 | SNK Magnavox 19MF338B/27 19 in. LCD TV
No audio and have a thin white verticle line across tv
Always suspect a bad EEprom...very common on this TV! See a tech, he will have to select one of six eeproms to fix this!
Jan 10, 2010 | Philips Magnavox 27MS343S 27" TV
Magnavox 19mf337b/27b flat panel tv doesn't boot up
I had the same problem but was too cheap to replace the scaler board on a television which was not worth the cost. That board has 3 1000uf 10V aluminum electrolytic capacitors which had swelled tops and indications that they may have vented. Since they were installed using through-hole technology, they were easy to change with 1000uf 16V capacitors. (caps can not be more than 16mm tall). The set has worked fine for months. Cost of repair was 72 cents
Nov 13, 2009 | Televison & Video
Emerson LC320EM82 S LCD TV I purchased this TV a year and 3 weeks ago. It suddenly stopped powering on. When I turn it on the screen comes on for half a second with 3-4 inch white lines across middle of...
Your not alone with this problem.
I had to fix mine. The warranty is less than impressive.
The trouble is going to be the Power Supply/Backlight Inverter board.
This is the picture of yours:
11e1946.jpg This is board # BA71F0F01042. Replacement boards are hard to come by.
Fixing the board like I did seem to be the only option. If you need info on fixing it, let me know.
Jun 18, 2009 | Emerson LC320EM8 32 in. LCD TV
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Dark vertical lines on tv screen
If under warranty then of course use that.
This is a display problem. One solution someone knowledgeable in electronics can try.
This problem can be caused by a bad connection fitting of the flat cables on LCD controller board. Dis-connect the flat cables from the LCD controller(T-CON) and carefully reconnect them. Try the unit before reassembling the back cover. You may have to disconnect/reconnect several times to show improvements if this is the problem.
Sep 25, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Static or lines running across viewfinder
Do they transfer when you upload the pics? Usually, on these models, when you get the funny lines on the screen and/or in pictures, it's the main PCB in the camera that is faulty. Unfortunately, Fuji's parts costs are out of this world. Call them up to get a flat rate repair. Sorry
May 16, 2006 | Fuji FinePix S3000 Digital Camera
Televison & Video Logo
955 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
