Took the Television apart didn't seem to be a problem that was visable. before I spend $99 on a power inverter what else could it be. Or does the power inverter seem to make since?
It is possible that your powerboard needs to be replaced. But keep in mind if power comes into the unit and the LED light shows blue then you do not need a power inverter. What you're gonna need a new backlight bulb. You can contact us @ 800-701-0680 where we can further assist you.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Westinghouse LTV-27W2 27 in.
I have this running thru a cable box and haven't
changed anything for a lllonnnggg time. It is...
(More)
changed anything for a lllonnnggg time. It is using the YPbPr2 ( three wire )
connection.
After watching a show the screen will go black. the blue light stays on.
After a while of powering the TV on and off, the screen will come back and
usually runs the rest of the time we watch it.
Any help is appreciated
my westinghouse LCD model LTV-27w2-b keeps cycling through on and off. Will be on for a few...
(More)
my westinghouse LCD model LTV-27w2-b keeps cycling through on and off. Will be on for a few seconds, then shuts off and comes back on in a few seconds. What might be causing this?
I have a 40" Sony Bravia KDL-40v5100 that is approx. 1 month old and is hooked up via HDMI to...
(More)
I have a 40" Sony Bravia KDL-40v5100 that is approx. 1 month old and is hooked up via HDMI to Comcast HD. Whenever I was changing channels there was a popping sound, so I called Comcast and a Tech came and changed the HD box, and the popping noise went away for a while, but now it has returned. The noise is not quite as pronounced, but it is still there. I am not sure what to do at this point, as it seems nobody seems to want to take ownership for the problem, Sony/Comcast. I wonder if this is happening with other makes of LCD's or if it is only Sony.
