Air-O-Swiss 7133 Humidifier
Problem for Air-O-Swiss 7133 Humidifier
Air-O-Swiss 7133
By Rahul dev on Nov 27, 2007
I have problem with Humidifier, water level is 70% or more, humidifier runs good for some time and then it stops and red light is ON. what can cause this and how to slove this problem...?
Same Problem
Nov 30, 2008
-   Same problem - dunno what to do. I love this humidifier, so quiet and mist the right amount. Once I changed the filter I tried to scrub, soak, test, and nothing worked. The red light is constant now and won't start up. -   Guest
Jan 17, 2008
-   I've got the same issue. The tank is at almost 90%, but the red light comes on all the time. It seems to work for several minuted when you first turn it on, then the light comes on and it shuts down. I've taken the assembly apart including the float switch and scrubbed it clean with CLR to remove the lime deposits, however it still refuses to function.-   jasonsee
Jan 04, 2008
-   have the same problem with the 7135 model. it runs shuts off and red light flashes.-   geetar
Nov 28, 2007
-   My humidifier used to work, then I changed the filter and now I have the same problem as Rahul.-   Guest
Solution #1
posted on Feb 05, 2009
Not Rated)
lauramacl
Rank: Apprentice
Rating: 0%, 0 votes
Okay, I just started getting this same deal with my 7133 on it's third season. I found in a blog that if you hold down the button that controls the heat while turning the mist knob on, it resets the machine. It worked. The red light went green and I turned off the heat button for cool air and the upper light still stayed green. Fingers crossed this continues to work. good luck!
Was this helpful?
Yes
No
Popular Solutions for Air-O-Swiss 7133 Humidifier
Questions and Unsolved Problems for Air-O-Swiss 7133 Humidifier
Do you recommend Air-O-Swiss 7133 Humidifier?
Answer
Answer
I haven't used the Air o Swiss #7133 humidifier in a while - I took off the water reservoir to clean... (More)
Answer
I have one packet of replacement material for the cartridge. Do I just poor out the old material... (More)
Answer
I recently cleaned my Air-O-Swiss and now the humidity detector says its 80% all the time (which is... (More)
Answer
hello i have the humidifier #7133 no instructions in box how do i clean it.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Air-O-Swiss 7133 Humidifier:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 2528
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
