Question about Garmin StreetPilot 2610 GPS Receiver
Locating satellites I just bought this brand new and when I turned it on outside to test it out, it continues to say "Wait locating satellites' The start guide says it is only supposed to say this for about 30 seconds the first time (and only a few seconds after that) before it says "Ready to navigate" So, what can I do? I have the same problems when I turn on the GPS system. It is searching for satellites.
  • garmincust Mar 19, 2008
    never locates satellites
  • 4 Answers
This takes about 15 to 30+ min. Make sure you are in an open area and NO XM or serious receivers turned on!
Posted on Dec 26, 2007
Just bought it and set it all up when i go outside and turn it on it just says locating satellites even stood there for bout 20 mins with no change
give it more time.
Go to an open area so that the unit has a clear view of all the satellites.
The first location lock take the longest,
Good Luck
Jan 12, 2011 | GPS
My c340 stops at "locating satellites". I reset it
If your StreetPilot c300 or c500 series device is no longer acquiring satellites please read the article linked below to ensure that this is not being caused by something in your environment:
Why won't my unit acquire satellites?
If after reading the above article your unit is still having problems, please ensure that your unit's software is up to date. You can do this by using our WebUpdater® program.
If you have tried all of the above suggestions and your unit is still not acquiring satellites, you can perform a master reset by doing the following:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit powered OFF and unplugged from power.
  2. Touch and hold the bottom right corner of the touchscreen.
  3. Power the unit ON and continue pressing the screen until a new message displays, "Do You Really Want To Erase All User Data?".
  4. Touch Yes and go through the set up again.
Take the unit outside and let it set with a clear view of the sky for 3-5 minutes to acquire satellites. If the unit still does not acquire satellites after this, please contact Garmin Product Support.
Nov 17, 2010 | Garmin StreetPilot c340 GPS Receiver
Can't get out of Kansas location --- can't locate satellites
Have you taken it outside to see if it needs better skyview to get a lock. I also suggest force feeding it the firmware again. You can use Garmin Webupdater to update the unit. It would of updated when you did the map update install but a file may of been corrupted.
Jul 11, 2010 | Garmin nuvi 255W GPS Receiver
Wrong current location
You have to change in the menu settings on your gps.
Dec 28, 2009 | Magellan Maestro 5310 Car GPS Receiver
No locating satellites when i on gps and flip up antena still no satellites they show only satellites bar not green
Turn the thing off and turn it back on.  You got the old crappy model.  Sell it on e-bay and get an updated widescreen version.  This crappy model doesn't work very well when its dark and cloudy outside.
Oct 24, 2009 | Garmin nuvi 350 GPS Receiver
Wait...Tracking Satellites
Turning off WAAS and then "Super Master Reset" (then reacquiring signal normally) did the trick for me. Note that it will wipe out ALL saved waypoints, so write 'em down before trying. This link describes it:
http://www.fixya.com/support/t260605-garmin_etrex_vista_date_problem
Jan 12, 2009 | Garmin eTrex Vista GPS Receiver
New Garmin 330 stuck on kansas
Take the unit outside and turn it on. Then select View Maps, at the top of the screen it will say either "Locating satellites" or "Acquiring Satellites". Once the garmin has locked onto the overhead satellites, then it will say "Ready to Navigate".
Locating Satellites take longer than Acquiring Satellites.
Jun 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Locating satelites
Are you outside, exposed to the GPS signals?
If so, have you tried resetting the unit?
Remove the face cover (GENTLY pry it loose by using the fingernail groove directly under the GARMIN logo), press the RESET button, then re-attach front cover... this is covered in the owners manual, also available online at garmin.com /support /downloads
Feb 27, 2008 | Garmin StreetPilot c340 GPS Receiver
Locating satellites
Hi cassyd
I have 2 questions in order to help.
1) It can take longer than 30 seconds depending on where you are, how long have you waited for it to acquire?
2) Are you holding the unit verticle while you wait for it to acquire?
If you know your lat/lon you can type that into the position screen while you are waiting for it to acquire, sometimes that helps.
Oct 27, 2007 | Garmin eTrex GPS Receiver
Garmin StreetPilot 2610 GPS Receiver Logo
157 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
