Question about KDS Radius RAD-7 17" Flat Panel LCD Monitor
Monitor displaying yellow tint
From last few days my monitor display suddenly change in yellow tint.
I opened photoshop - turned around - and then my screen had a yellow tint that i couldn't get rid of
  • 1 more comment
  • Anonymous Mar 31, 2008
    I'm having the same problem with my KDS 20" LCD monitor. I thought it was the video card, but attaching the monitor to my brand new IBM PC produces the same yellow tint.
  • Anonymous Jan 28, 2009
    yep changed video card and now monitor has same yeelow tint...still searching for solution..hope i can find one
  • Anonymous May 01, 2009
    I was browsing the internet, and visited a site when a yellow tint appeared.
    I've checked around to try to fix it and was told to try these:
    ~ Adjusting the 16/32 bit colors.
    ~ Open the tower and using a house fan blow it out.
    ~ Check the cables.
    I did all of that and still nothing.
    I also tried adjusting the brightness on the screen. Still didn't work. I was also told to download this program which they said was free only to find I had to pay for it.
Hay guys make sure your video card is seated and fastened properly and the connection for the monitor is secured firmly, worked for me.
Posted on Sep 04, 2009
Try this. Worked for me immediately, including with PhotoShop
  1. Go to Color Management (in Vista, just click the Windows Orb / Start Search & type in Color Management)
  2. On Devices, select your display (repeat if you have multiple ones... at least I did). e.g., Syncmaster ....
  3. Check the box: Use my settings for this device
  4. Select any and all profiles you have and Remove them.
Check to see if that fixed it. You may need to restart. I didn't have to.
more info, and where I learned about it here:
Posted on Jan 29, 2009
Yellow screen
There are a variety of problems that can happen to the display monitor of an Acer laptop.
The most common problem is the screen fading or becoming too hard to see.
This can be corrected by adjusting the brightness levels.
Another common problem involves incorrect color, which can be resolved by adjusting the display color settings.
Yet another big problem is the display freezing or appearing jumpy, which can be resolved by updating the display driver.
Hold down the "Fn" key.
Tap the right-arrow key to brighten the display screen.
Tap the left-arrow key to darken the display screen.
Release the "Fn" key to save your display settings.
Right-click on the desktop and click "Graphic Properties."
Adjust the screen resolution by clicking "Display Settings" and choosing a resolution setting from the drop-down menu.
Click "Apply" to check the resolution of the display.
Click "OK" to save the resolution settings.
Adjust the color of the screen by clicking "Color Correction" and moving the brightness or contrast slider to the right or left.
Click "Apply" to check the color resolution of the display.
Click "OK" to save the color settings.
Click "OK" to exit the Graphic Properties application.
Update the Display Driver
Right-click on the desktop. Click "Personalize," "Display Settings" and "Advanced Settings."
Click the "Intel Graphics" tab and choose "Monitor Properties."
Click "Driver."
Click "Update Driver" and choose "Search Automatically."
Click "Install" to install the updated monitor driver. After the driver has been installed, click "OK" to restart the laptop when prompted.
Yellow screen
Yellow tinting in monitors can be caused by either a software calibration issue, bad cables or a worn out display and backlight.
Before you assume that the issue is a hardware one, determine if there are software settings that affect the color or if the cables are working correctly.
After checking these items, and if the yellow tint only occurs on one monitor and you cannot eliminate it, the problem is a display hardware issue and it is less expensive to replace the monitor.
Unplug the power cord from the monitor and replace it with another one.
This is a standard power cord used in printers, monitors and desktop PCs so you can trade it for a cable from another device.
Turn on the PC and monitor to see if the yellow is still there.
Turn off the computer and monitor.
Replace the video cable with another VGA cable from another monitor.
Use one from another computer before going out to buy one.
Restart the computer to see if the yellow tint is gone.
Right click any area on the desktop and click "Properties" from the list of options that appears.
Choose "Display Settings," then "Advanced Settings."
Select "Monitor" and click the "Calibrate Color" button.
Wait to see if the yellow tint goes away.
Locate the temperature color settings on the monitor.
Adjust these to see if there is a change in the color.
A warm color setting will give the screen images more of a yellowish tint.
Click on the "Start" icon, then click "Control Panel" and "System and Security" and choose "Device Driver."
Locate the video driver and click "Update."
Select the option allowing Windows to connect to the Internet to find an updated driver.
Wait for the update to complete in a few minutes.
Expect the yellowing issue to disappear.
Connect the PC to another monitor to see if the same problem occurs.
If the yellow tint does not appear on the newly connected monitor, the problem is a bad backlight or display and the monitor should be replaced with a new one.
Jul 21, 2013 | Acer Computers & Internet
Laptop LCD goes black after a few seconds
Yes, The pink tint is an indication that the backlight is failing. Now the backlight is basically dead, the best way to get back going is to do an Ebay search for your model laptop and get a new screen. Most screens can be purchased for around $50.00 - $70.00 and they are very easy to swap. Email me if you need more info.
Corporate Computer
Aug 03, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Yellow tint in photoshop
Try adjusting the brightness on the monitor
Feb 27, 2009 | Adobe Photoshop® CS3 Extended Full Version...
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Quick version--open photoshop select --edit->color preferences, and make sure that adobe RGB(1998), or sRGB IEC61966-2.1 is selected. If this doesn't help please let me know
Nov 23, 2008 | Adobe Computers & Internet
Pink tint on Dell 1704FPT Flatpanel LCD
Unfortunately if you have tried a different machine (it could be a bad video card) and tried the cables most likely it is the screen itself. Typically when one of these lcd's begin to fail the pixles no longer access the blue field and you see mostly red instead of the other two colors. In short pink screen is terminal, it will last for a while longer.
Oct 01, 2008 | Computers & Internet
Check the video cable at both ends to make sure it is connected properly.
Move the cable around near the ends and chances are it will look normal. If so then you have a broken wire inside the video cable. A common thing and easy to get another cable.
Apr 03, 2008 | Mag Innovision LT776s 17" LCD Monitor
Icons green tint to them
I'm not sure but I think this model uses an integrated graphics card which would then involve replacing the entire motherboard.
It may be that the screen backlight is getting old - they often age by showing a tint, usually it is pink but I have seen them go greenish.
Try an external monitor connected to the laptop via the VGA d connector. If the picture on the external monitor has a good colour balance then it is probably not a faulty graphics chip, and likely to be the laptop screen.
Mar 16, 2008 | ASUS A6Km Notebook
hi there, check your video cable, most of it has a broken cable. ty
Dec 26, 2007 | Balance CM2015 15" LCD Monitor
Problem with the acer al1916w
Sounds like the backlight or inverter might need replaced. It's pretty common on LCD monitors. It's best to call a local repair shop to do that unless you know what you're doing.
Jul 31, 2007 | Acer AL1916W 19" LCD Monitor
KDS Radius RAD-7 17" Flat Panel LCD Monitor Logo
6,978 people viewed this question
Top KDS Computers & Internet Experts
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
