Question about Singer Sewing Machines
Refitting the bobbin case on 4411 singer
My 4411 keeps gaming sad the needle is hitting the needle plate, I've cleaned it and true day sting the needle position but now the bobbin case keeps jumping out and under stitch is all loopy
SOURCE:
bargainbox
  • 1388 Answers
SOURCE: Needle hitting bobbin plate
Is the needle inserted correctly with the flat side at the rear and fully up into the holder ?
If yes, take off the needleplate, remove bobbin case and slowly rotate the handwheel towards you watching the relationship between needle, and the "hook" of the moving "race".
Set on wide zig zag........when the needle is fractionally past it's lowest point, and starting to rise, the hook should be level with the left side of the needle when on the right hand stitch of the zig...the eye of the needle will be below the hook, and ready for thread to be picked up for the stitch to form.
Any other result will mean your timing needs adjusting.
Posted on Feb 10, 2008
SOURCE: My Singer 2639 Bobbin case
Hi, I used to have the same problem. I pulled the whole bobin casing out, cleaned it oiled it. When I put it back in, I made sure the actual bobin was turing the right direction so the cotton didnt snag and pull casing up.
If you havent already tried this give it a go.Its amazing how much gunk gets in there.
Posted on Sep 03, 2008
SOURCE: my needle keeps hitting the bobbin casing...have
Your timing is off. There should be a ruber belt behind your hand wheel, if you take off the case around it; you should be able to adjust your timing of the bobbin casing.
Posted on Jul 31, 2009
  • 1788 Answers
SOURCE: I have a 5050c singer The bobbin case jump out
I think that you have had the wrong size bobbin. It should be a class 66. Look in your manual, it should tell you. If, that is not it, call Singer at 1-800-4singer and ask if it sounds like the timing and if so where can you take it to get fixed. This is a nice machine, my friend, has one and it is worth getting fixed if you like it.
Posted on Jan 02, 2011
Testimonial: "it was in the timing .problem solved. thank you for your help. "
SOURCE: My Singer 6160's needle is hitting the bobbin plate.
first change the needle--flat side to the back of the machine, make sure the needle is inserted all the way up into the needle holder
make sure it's the correct needle for the machine
if the needle keeps hitting the bobbin plate then the machine may be out of time & would have to be take to a sewing machine shop for retiming.
Posted on May 04, 2012
The hand wheel does not move. removed the needle, still not working
sounds like you have thread bunched up in the bobbin case. take out the entire bobbin plus the bobbin holder and clean it. it is worth a try....
May 20, 2016 | Singer 4411 Heavy Duty Sewing Machine
I have a singer confidence 7469 quilter, the upper thread keeps bunching up in the bobbin case. I've tried re threading numerous times with no luck.
try changing the needle
make sure the bobbin is turned the correct way in the bobbin case
make sure the thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
Jan 29, 2013 | Singer Confidence 7469 Mechanical Sewing...
I 've been using this 2639 Singer since 2006. It was working perfect until one day the bobbin case popped up away from the shuttle causing the needle to be blocked from moving. So, I removed the p
First change that needle. It's likely bent. A bent needle won't create a stitch.
Then double check your timing. It sounds like you have it ******** a bit... But that's hard to determine from a description. Before you start the timing process, make sure that your needle bar is in the correct position. (typically the upper timing mark on the needle bar is just below the lower needle bar guide when the needle is at its very lowest point) If necessary loosen the needle bar holder and make a correction. Once the needle bar is positioned correctly... then move on to the shuttle/needle timing.
Nov 03, 2012 | Singer Sewing Machines
How to thread a bobbin on singer 4411 sewing machine
If you've threaded the bobbin per instructions... then make sure your needle isn't damaged, bent, or dull. Also make sure the needle is seated fully and correctly oriented into the needle bar.
Aug 24, 2012 | Singer Sewing Machines
May 03, 2012 | Singer Sewing Machines
Looking for bobbin case for singer 3270c I see lots that look like the one I have but none of the numbers they list match mine... Also the machine is bunching up the tread and my bobbin case is broke so...
check with these 2 websites for the part ,,
sewingpartsonline.com or sewvacdoctor.com
it's possible the bobbin case could be a problem, I have 2 sewing machine & if one of them had a broken bobbin case I would replace it
have you tried a new needle
also check the thread take up lever, if the thread comes off of it, that can jam up the machine as well, I've had that happen before
also keep under the needle plate area clean of lint or loose threads & also the bobbin area
Aug 14, 2011 | Singer 3270 Mechanical Sewing Machine
I think the timing is off on my singer 7430 -- it keeps breaking needles and I can see where the needle hits the bottom of the bobbin casing when it is in the fully down position -- any quick fix?
Drop-in bobbin?
Refer to the maintenance section of the manual for cleaning.
Raise the needle to it's highest position and remove the bobbin and bobbin case.
Clean the shuttle and replace the bobbin case, noting the graphic in the instruction manual for aligning the case into the shuttle.
Turn the handwheel to see if the needle now clears the outer edge of the bobbin case.
Mar 29, 2010 | Singer 7430.CL Computerized Sewing Machine
New Problem...I have a Singer CG-550. When I try and sew anything, the needle hits something inside where the bobbin is. The little black casing holing the bobbin keeps moving all over the place, I slip...
On the right of the black bobbin case there are two screws, you can slacken those screws off and move the bobbin case nearer to the guard leaving enough room for the thread to pass through, if the needle is hitting the bottom you may need to retime the machine.
Mar 06, 2010 | Singer Sewing Machines
Sewing Machines Logo
20 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
