Question about Lexmark Wheelwriter 6 Series II Typewriter
Typewriter not printing
We just changed the ribbon on our IBM Wheelwriter 6 and now it will not print. It seems the keys are not hitting the ribbon??? Any suggestions?
  • 1 more comment
  • Betsyg Dec 10, 2007
    Looking for same solution. It stopped in "mid-typing" not when I changed anything. Have powered off & on, changed ribbons, changed batteries, changed typing platen wheel, & air cleaned machine. No loose parts or connections visible. Help?
  • RCab Jan 30, 2008
    I've read the comment on the broken solenoid plunger - can you tell me where it is located and how to obtain one?
    We apparently have just had the same thing happen on two of our Wheelwriters.
    Thank you.
  • mcleod Apr 23, 2008
    It won't hit the paper or the ink film.......changed the batteries, changed the film, the mechanism is not hitting the paper ......the space bar works, but nothing else will print......
  • Lexmark Master
  • 3,594 Answers
There is a plastic cap on the end of the print solenoid plunger that nis probably broken the part is available about 10.00 but a little tricky to replace.
dickto
Posted on Dec 13, 2007
  • Dick O Reilly Feb 01, 2008
    The solenoid is located below the ribbon just inside the l. side frame of the carrier. It is about an inch & 1/2 in daim., the plastic cap is on the back side of the plunger. We have the caps in stock for 15.00 including shipping. Email bizmach@earthlink.net
    DickyO
IBM Wheelwriter 6 typewriter. The print wheel does not move when typing and acts as if in stencil mode
From your posting it sounds like you have cracked plastic print solenoid cap. We sell them for 20.00 with instructions.
DickyO
216-269-3918
Apr 29, 2014 | IBM Wheelwriter 6 Typewriter
IBM Wheelwriter 6 - Ribbon doesn't lift high enough for the key that's pressed to print on paper. Ribbon advances OK.
If theribbon dosen't lift at all see if the black gear on the R. side of the printer will move, if not w3iggle it and it should free up they get tooth for tooth with the motor gear. If it only lifts partually thereis an adjustment on the roll that works with the black gear. BE SURE TO CHECK THGAT BTHE PLATEN IS FULLY SEATED IN THE VSIDE FRAMES THEY DO GET LOOSE!
DickyO
Jun 30, 2012 | IBM Wheelwriter 6 Typewriter
We have a wheelwriter 6. We changed the ribbon and now it won't type. I'm guessing we hit something that changed it to "stencil"?
There is no stencil on a WW. Put a Multipart form in it , if it types on the carbons thr ribbon isn,t feeding of lifting, if it dosen't type on the carbons the plastic print solenoid cap is probably broken. We sell them for 20.oo includes shipping and instructions.
DickyO
Cleveland Business Machines
216-241-0027
Nov 09, 2010 | IBM Wheelwriter 6 Typewriter
Ribbon strike mechanism won't move and strike ribbon when key is hit
You most likely have a broken plastic print solenoid cap.
We sell them for 20.00 with instructions and shipping.
DickyO
216-241-0027
Sep 16, 2010 | IBM Wheelwriter 6 Typewriter
IBM Wheelwriter 5. It was typing light so I
The plastic print solenoid cap is probably broken. We sell them with instructions and shipping for 20.00.
DickyO
216-241-0027
Feb 25, 2010 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 6-Letters striking paper above
Put in a multi part form and type if the carbons come out OK the the ribbon isn't lifting, Wiggle the big black gear on the R. side of the carrier back and forth. They do get tooth for tooth when they get old. If the print on the copies id bad or not there you need a print solenoid cap. We sell them for 20,00 including instructiond and shipping.
DickyO
216-241-0027
Feb 18, 2010 | IBM Office Equipment & Supplies
The correction tape is not working properly. Wheelwriter 1000
If everything was working befor the ribbon & L/O change Either the L/o is not properly attached to the ribbon or the ribbon and or L/O are old. Make some corrections then remove and look at the L/o, if the letters are near the center of the L/O the problem is the ribbon or L/o is old, if the print is on the top of the tape it is not properly attached to the ribbon or not coming out or the cassette properly.
If you have a fresh set or another T/W that works swap the ribbons and look at how they are attached.
For a picture ngo to lexmark.com and click your way to publications you will find a downloadable manual there.
DickyO
Jan 23, 2010 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 3 will not type
Probably the plastic cap on the print soleniod is broken. They are available from us for 15.00 but a little tricky to install.
DickyO
Jun 20, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 6 prints only top portion of characters
The platen is probably not all the way in. Be sure the black latches are lined up with the side frames and press firmly down on the platen.
hope this helps
DickyO
Feb 25, 2008 | Lexmark Wheelwriter 3 Typewriter
Lexmark Wheelwriter 6 Series II Typewriter Logo
237 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
