Question about HP DeskJet 1220c InkJet Printer
LIGHTS FLASHING, FAILS TO PRINT
Rachet crunching noises during alignment set up
  • 417 Answers
Sound to me that the ink cartridge carriage is stuck if you can remove ink cartridges and then reinstall them. You may have to take machine apart. There are clips on the bottom of the machine to do this but be aware that when you turn it upside down the waste ink will leak
Hope I could help
Thanks J
Posted on Jan 13, 2008
How to set print alignment in hp officejet K7100
During cartridge alignment, the error message 'Print cartridge alignment failed' displays on the printer control panel....
More Info visit this links...
Print cartridge alignment failed Error Message Displays on the All in...
Alignment Page Does Not Print
Thanks,
HP Printer Support
Jun 26, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
I just want to run the self-test, but my MD 5000 won't do it. When I finish the button sequence to start the self test, it just makes some crunching & whining noises, then the power and error...
Check to make sure you have the dark grey ink cartridges installed in the printer. The blue (photo) and the Econo Black cartridges cannot be used for the self test.
Sep 02, 2011 | Alps MD 5000 Thermal Printer
We have a Bosch washing machine E-nr wet2820GB / 13 FD 8101 0017. Recently it has started making an unusual, very loud 'crunching' noise during the wash cycle, it then stops on 'main wash',...
There is a clutch that gets dry and sticks it has to be greased from time to time.
It sounds like the clutch cannot slide on the spline and is causing the issue at hand.
Aug 01, 2011 | Washing Machines
Making an awful ratcheting noise during aggitation and spin cycles
Under the agitator there is a rachet mechanism that works the agitator. If it is stripped, it will skip until the next good tooth.. when it fails entirely the agitater will stop going back and forth. Its nylon and age along with overloading hastens its dearg.. If you can get the parts you can replace it yourself without difficulty. There is a single bolt in the center of the agitator top . Remove and loft agiyator straight up.
Jun 03, 2009 | Maytag Legacy Series Top Load Washer
Alignment of printhead on Canon Pixma iP4600
This is simply a case of the ink tanks not being pressed in hard enough. They do click in, as the manual instructs but, unless they are fully pressed in top and bottom, this problem occurs. It's a shame that the Canon manuals and even the support centre do not mention this simple solution.
Jan 03, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Keep printing test sheets
A lot of HP printers print a page to enable the print head alignment and calabration. This normally orcurs when a cartridge has been changed. If the alignment page fails then it will reprint alignment page until it can align.
So, you need to get that page it prints and place it on the glass and press scan, then it will complete alignment and be ready to rock.
See Here
Cheers
Jan 19, 2008 | HP PSC 1510 All-In-One InkJet Printer
Aligning problem
You could try opening the HP toolbox should be under Start--> Control Panel--> Printers and Faxes. under properties os options. It will be something like that. Then print an alignment page put it in the scan section of the All In One as prompted and that should align it also under the setting there will be clean print nozzles. If this fails I would seriously consider just replacing the printer. There also explanations of this at www.hp.com
Aug 05, 2006 | HP PSC 1350v All-In-One InkJet Printer
HP DeskJet 1220c InkJet Printer Logo
148 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
