Question about Jenn-Air JCD2389G Side by Side Refrigerator
Jenn-Air Refrigerator My fridge keeps losing chill power,when I open the box,it is warm inside. The freezer defrosts. Does it need Freon,and what is the usual cost? Alane
  • doll baby Dec 14, 2007
    No just would like a manuel to check it out
  • Anonymous Mar 30, 2008
    the motor runs but the refrigerator side is warm and the freezer side is warm
My refrigerator keep warm and freeze work fine, but when i take the back panel off in the freeze the pipes are with a lot of ice on them. Once i defrost the pipes behind the panel it will work for two or three weeks and then its back to the same process. Help me please.
Posted on Dec 31, 2007
  • doll baby Dec 31, 2007
    I forgot it is a Whirlpool Gold that is a side by side refrigerator with no model number or serial number inside or outside can i still be help.
  • 833 Answers
Might be icy. First, fully defrost by either removing the rear panel and using a hair dryer (dangerous) or leave it off and open for two days. Check door gaskets and clean or repair. Clean condenser coils under the unit. Now, take off the back lower panel and find the compressor. Largest pipe is what we're interested in. Start unit. It will frost the pipe. After 5 minutes, frost should be replaced by ice, dry or wet...not frost. If still frosty, you need freon. Hard to know what the right price would be.
What else could it be? Thermostat, defrost timer. Try my stuff before going on.
Posted on Dec 22, 2007
Fridge is warm freezer is cold
Hello Abo Karin,
You are likely experiencing a DEFROST failure
(most commonly a defrost PCB failure)...
part number 67006740 item 5 on your exploded
case view (top center as viewed from the front).
There are typically only three (3) elements to a DEFROST
power control circuit:
- Defrost Printed Circuit Board ( PCB as noted above)
- Heater element to WARM the EVAPORATOR
- DEFROST thermostat... inhibit excess heat
(closed circuit at freezing - Opens at room temperature)
Check your defrost pan...
there should be water there DAILY...
IF not: you are assured that your DEFROST fails.
You need to look for a SUDDEN REASON (huge air leak)
why FROST would form so quickly...
USUALLY a big pizza box... BUT ANYTHING blocking a
TIGHT DOOR SEAL will cause massive frosting.
It is taking moisture from the WARM ROOM AIR and blocking your evaporator...
a PROPERLY functioning defrost circuit would remove that frost
at least DAILY... and the EVAPORATOR fan would properly chill the refrigerated side blowing cold air from the FREEZER.
Yes ... all INTERIOR panels must be in place for the refrigerator to function properly.
Hope this helps
Your part... (see video instructions)
Sears... (I don't USUALLY recommend for purchase)
also see other .com retailers
PartSelect Appliance Parts and Repair Help
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Apr 19, 2017 | Kenmore Refrigerators
Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2010 | Jenn-Air JCD2389G Side by Side...
I have a Jenn-Air JCD2389G Side by Side Refrigerator. The bottom of the freezer keeps things frozen, though the top of freezer & refrigerator remain mild to warm. There is not an excessive amount of...
It sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out for troubleshooting the defroster problem
Apr 25, 2010 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator. One month ago the water tap stopped working then I noticied that the top doors to refrigerator would not reliably close like they used to. Last...
The water could have been frozen in the door and melted when your fridge warmed up.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
Jul 13, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Jenn-Air JCB2389GRS Fridge not cooling properly
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Mar 15, 2009 | Jenn-Air JCD2389G Side by Side...
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Everything in My Freezer is Melting and Fridge is getting warm!
find another place for all of your food because you may need to call a service company.
possible causes: stuck in defrost (if nothing is running) bad compressor (if fans are still running) freon problem if everything is still running
Jun 28, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-air fridge not working
If the back panel of the freezer is Iced up you may have a defrost problem. or the damper between the freezer and thr refrigerator is closed.
May 19, 2008 | Jenn-Air JFC2087HRP Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
221 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
