Question about Gigabyte GA-8S661FXM-RZ Motherboard
Please help i just connected every thing on my mother board but i get no feed back not even a beep , the screen is blank the cpu fan spins ,the motherboard light go on but no feed back at all is it my cpu ? or zif socket cause my cpu works on my other pc.,......... please help thanks and ill return the favour with a possetive rating
  • lasting love Mar 19, 2008
    DRIVERS
  • Webster-mind Lungu
    Webster-mind Lungu Nov 18, 2008
    PSU fan and CPU fan spin, amber light on, green light off, cd rom LED off & cd rom not active, no display on monitor, tried a different cpu & wont work either, tried without RAM sticks & CPU but wont boot or give error msg. no on board sounds.
  • 205 Answers
The first time I installed a new motherboard I did not realize there were two power cables, one has a small square connector and the other a long rectangular connector. Did you connect both power cables?
Posted on Nov 27, 2007
  • ohiotom Nov 27, 2007
    If everything is connected properly and the CPU works in a different motherboard then I woudl guess the motherboard is bad.
Turns on (fans spinning, HD clicking), blank screen, no sounds
hi this issue is with ribbon cable it is connect between the mother board and your LCD screen. the cable required change. if you can change it OK other wise take it to nearest service center.
Jun 15, 2010 | Acer Aspire One Netbook 8.9" Notebook
My Dell cooling fan now runs at a high speed and the computer will not turn on. I robbed one from an older Dell, and got a message that the (new-old) fan wasn't working, (The plug was smaller then mine)but...
The cooling fan racing is a symptom of a No Post state in the Motherboard. The Power LED and diagnostic LED indications would be helpful in resolving your issue. If the power LED is flashing Amber, the power supply is suspect, solid Amber points to the motherboard or something connected to it. The DIAG LEDs 1234 on the front or ABCD on the back give more specific information.
Initial Impression, is motherboard failure, post the DIAG and Power LED indications for more exact diagnosis
Mar 03, 2010 | Dell (6F858) Cooling Fan
Desktop screen is blank even when the cpu and monitor indicator a
It looks like issue with either mother board or processor.
open the box and remove all memey and power it on. if it makes a beep sound, there is no issue with processor, else we suscpect processor. If it make beep sound, it might be mother board issue. And for checking monitor working condition, remove monitor data cable and see no cable connected messages comes in monitor or not
Oct 13, 2009 | Dell Computers & Internet
Blank screen, not boot screen.
Not all of this applies to you but the links for the beep codes may well be of use to you.
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Sep 19, 2009 | Compaq Presario R3000 Notebook
Computer do not but up at all/No beep sound, no BIOS start
You shouldn't of pulled anything out. I've done the same thing aswell, i took mine to the local computer repair shop and they fixed for the odd $60.00.
Aug 20, 2009 | Compaq Presario 5000 PC Desktop
Emachine will not power up
By nothing else, from a technical standpoint this would mean literally nothing, the CPU fan, power supply fan, aux fan, disk drive not spinning up, etc. My experience with EMachines is their motherboards aint the best, have been known to take out hard drives and other peripherals to the mother board. If you are technically inclined the first thing to do is to bare out the system, Power Supply attached to the Mother Board w/ Cpu Monitor and Keyboard no Hard Drive and no Non esential boards installed, very carefully remove the memory and start it up all should be fine except it should give you a long beep from the PC Speaker indicating the Mother Board is aware there is no memory installed if it will not do this most basic of tests this is not good. If it does give you a health beep continue to install one item at a time, first the memory, the display should, if working, tell you there is a boot failure, of course, the hard drive is not connected, do so and keep on testing. Without knowing what type of mother board you have, most likely an AT with integrated peripherials the process to determine exactly what the problem is would take hands on trouble shooting. If you dont get the beep indicating the mother board cant determine if memory is installed and truley nothing else is on it is more likely the mother board. There are several good ones online that will fit your case if you want to go this route. Or is it time to upgrade ?
Jun 04, 2009 | E-Machines eMachines Desktop PC
Moniter Screen Blank when my PC start....Giga byte 8S661FXME-RZ Mother board
try to remove the motherboard from the casing and see it if the have some capacitors or any circuit distroy. use other mother board for testing chek your hardware one by one maybe some of your hardware devices damages.
Jan 01, 2009 | Computers & Internet
EMachine T3406 wont boot
is there a post beep when the pc is switched on. check the memory if it is a beep beep beep sound , also disconect the hard drive, dvd drive, floppy, and any usb devices and see if it boots up. if that fails it does seem like the mother board, also check the cpu fan has it stoped. also find out the power switch conector on the mother board, from the base unit switch to the mother board. also chech the power connector from the power supply to the mother board , on newer boards there are two that go to the mother board its self , a big one and a very small one .
Jul 05, 2008 | E-Machines eMachines Desktop PC
No signal to monitor.......all dark
and im sure the screen appers to be blank and the key board lights flash once and no feed back other than the fans spinning right? . this is a common problem with asus motherboards and AMD cpu's which indicates a bad motherboard or cpu if you have acces to anouther cpu try changing to that one if that doesnt work you're motherboard is gone
thank you
ace
Dec 11, 2007 | ATI Asus P4R800-V Deluxe Radeon FSB800...
Gigabyte GA-8S661FXM-RZ Motherboard Logo
192 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
