We have a 7 camera system and the monitor is just displaying the watchdog logo. Maybe a setting?
Hello Jeninesque, indicates the brand and model of the equipment you are discussing, in order to find the best possible solution
Check the power supply of the cameras, as well as the video connections, if they are IP cameras, search camera by camera independently, or get in touch with who installed the cameras
I wait your answer
Greetings Franco Dosil
Hola Jeninesque, indica marca y modelo de los equipos que estas comentando, para poder encontrar la mejor soluci?n posible
Revisa la alimentacion de corriente de las camaras, como asi tambien las conexiones de video, si son camaras IP, busca camara por camara en forma independiente, o ponte en contacto con quien instalo las camaras
Espero tu respuesta
Saludos Franco Dosil
SOURCE: Ultra10 3750115 Motherboard displays watchdog reset intermittently
Try this
replace M/board battery or rest BIOS to default and try again
SOURCE: Sony analogue Hi8 Handycam as a security camera
Hi!
You need to have things with you before you can proceed to use it as a security camera. As your's is a analog camera we will require a video capture card connected with your pc/laptop.
After you have one connect that with your pc and pTo get the video into your computer, you need a analogue to digital video capture card....otherwise, connect the camcorder to a CD or DVD player/recorder, and use the CD/DVD as a source for your video editing... Otherwise, you need a later model of SONY "Digital 8" digital camcorder which plays analogue tape, and with this your computer can capture the video via firewire
For details on how to record using a software and video capture card please look at this link---
Handycam as Security camera
If you find this solution helpful then do rate this solution.
Thanks
Rylee
SOURCE: Channel 3/Camera 3 not displaying properly
try swapping the cam inputs first to rule out the unit, if not the camera may be faulty or needs setting up properly with a focus adapter, or the lens could need setting up!
when CCTV company's set up these systems they have all the equipment to plug in and focus auomatically etc..
Hope this helps!
Try looking at www.digitalvideos.co.uk (test equipment) section.
