Question about LG Heating & Cooling
LG mini split LMU187HV 1 ton and 1/2 ton standard wall units. Error CH24 on cooling only. Bigger unit only causes the error but smaller one just runs and doesn't cool much. Both high pressure lines frost up.
SOURCE:
  • 306 Answers
SOURCE: I have a Tane 2
Has anyone added some freon? The unit has way too much freon inside it. You need someone to reclaim the freon and weigh in the right amount of freon. If you run the unit the way it is will cause some very serious damage. Let me know ken
Posted on Apr 29, 2009
2coolrick
  • 560 Answers
SOURCE: my LG intelloair 1.5 ton split a/c's compressor not working.
check the compressor's start/run capacitor. if it is swelled at the top, where the connectors are, replace it.
Posted on Apr 04, 2010
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
Posted on May 04, 2010
jumptrout51
  • 3361 Answers
SOURCE: unit leak at high pressure
Sorry about your problems.
The StopLeak is expensive and does not work on leaks larger than 8 ounces per year.
Neither of these "technicians" confirmed the location of the leak and repaired it.
When the vacuum was done on the system a leak would have been obvious after the first tech replaced a valve.
If they did not see a rise in pressure,they are incompetent.
I apologize for not having an answer for you,but,without being there and checking your system,I do not know what your specific problem is.
Posted on Aug 16, 2010
  • 910 Answers
SOURCE: LG Art Cool mini-split heat
C1 Indicates a Fault with the Indoor Temperature Sensor.
What type of Thermostat are you using and can you check if it's operating correctly?
Posted on Aug 04, 2011
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
The control card is displaying error ch-01
PDF]SERVICE MANUAL R?410A Ductless Split System Air ...
dms.hvacpartners.com/docs/1011/Public/.../42108920400_ICP_26610.p...
421 01 9204 00 1/03/13. SERVICE MANUAL ... Consult local building codes and National Electrical Code. (NEC) for special ..... 18000 (5970-22350). Heating Capacity (Min. - Max). Btu/h. N/A ..... Error Messages Displayed Front Panel. S.
Oct 08, 2015 | LG 18000 BTU Dual Zone Mini-Split Heat...
What does error P1 means in pioneer heat pump
It means the power is off or went off to unit . Check for power then power cycle unit to try and restart .
Nov 14, 2014 | Pioneer Ductless Mini Split INVERTER Air...
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
My indoor lg mini split unit the cool light flashes 4 time what's wrong
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
clean your condensate drain line you can do this with a shop vac,
Read more: http://dgoma.es/multisplit_lg/lg-multi-split-units-error-code/#ixzz34dr3Cu00
Follow us: dgoma on Facebook
May 26, 2014 | LG LMN127HVT LMN127HVT 12 000 BTU Ductless...
What does CH 24 mean on ArtCool mini-split?
Ch24 means your unit has a low or high pressure fault,check gas charge and if filters are clean see if helps
Aug 31, 2011 | LG Art Cool LA121CNP wall/window Air...
System 3 in-door with system 4 out door inverter. all in door unit show error code CH24 pls help
CH 24-Splits and Multi Splits = High or low pressure trip. Low at 1 bar High at 35 bar check pressures. Multi V = High pressure trip.
Nov 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Apr 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Lmv240he & lav181cnw
I searched the website but could not locate the literature for that particular unit. I recommend you contact the manufacturer's technical support department. They should be able to email you the manual and direct you how to obtain replacement remote controllers.
Technical Support
For technical support on a DFS, PTAC or TTW Product call 888.865.3026, then press 2.
I hope you find this helpful with your endeavor. Good Luck! :-)
Mar 08, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Lg split system ch 05 error outside fan not working
Solution # 1, Check Condensor Fan Motor Capacitor 4uf or MFD
# 2, Check Motor Windings
# 3, Check Relay OR Defination Contactor
# 4, Check Connection Terminals
hope will help u 2 solve this
GOOD LUCK
Jan 26, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
24 people viewed this question
Top LG Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Steve F
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
