Question about Electrolux Epic 6500 Vacuum
Electrolux Epic 6500 SR series
Hi, as soon as I put the hose nozzle on the vacuum stops. It rins ok until you put a bit of obstruction in front of the aspiration hole. I have checked the bag,it is new, the filter is also new, I just do not know what can make it die like this.
Thanks for your help.
  • 3 more comments
  • sergep Nov 27, 2007
    Thanks for your help. I have triple check and there is no clog anywhere. as for the little switch I do not see it when I remove the cover to the bag. I have check the hose and it completely free of any obstruction. The problem persists even though the hose is not installed. Just the fact of putting my hand over the hole where the hose ususally goes kills the motor. Any other suggestions?
  • rick27025 Jun 28, 2008
    Vacuum cuts off and full bag light comes on with hose attached. Runs fine without hose until you place your hand over suction opening. Bag is new and empty, filter is new, no obstruction in hose.
  • Anonymous Jul 09, 2008
    Same problem--Have replaced filters and verified no obstruction in hose. Unit is 13 years old
  • dwilliams713 Jul 09, 2008
  • bangjeha
    bangjeha May 11, 2010
    Hi folks, especially oroussea, I got the same problem and can't open the case at all. Can anyone describe in more detailed how do I open this Epic 6500 Electrolux and disarm the BFSA. Thanks much.
Ok i found a solution for my Electrolux Epic 6000 which had the exact same symptoms as you describe. I fixed it by disabling the "bag full sensitivity adjustor" (BFSA for short, for the lack of a better term). For that i opened the case, removed the hose that was preventing me from opening complety the casing, unscrewed the transaparent BFSA mechanism.
Here's the walkthrough:
- Open the case: Open the top part of the vacuum (where the bag is)
- Remove the 2 side rubber by sliding them from the back to the front of the vaccuum
- Remove the "plastic cap" at the end of the vacuum (you can slightly lift the vacuum top part to make it easier)
- Now unplug a small air hose to be able to open the case completely.
- Find the BFSA device and unscrew it.
- Now give your vacuum a try... it worked for me.
Posted on Aug 10, 2008
  • oroussea Aug 10, 2008
    Ohh.. one last thing... my BFSA had some broken platic in it (i saw them when i unscrewed it). Might be the same thing for you.
  • Anthony H. Hughes Nov 26, 2011
    Notice there is a little switch which the bag would push down that goes up and down letting the vacuum know the door is shut properly.
    I pushed down the switch and stuck a stick into the hole along the switch holding it down even though the door is open.
    By doing this the vacuum works fine.
    It appears on mine anyway that when the door is shut it isn't pushing the switch down all the way and holding it there. It is bouncing so to speak so the vacuum went on and off after just a few seconds or it ran good when the door was open and the switch was pushed down.
    Hope this helps.
  • 3 Answers
Check the air filter which is at the air output (blower) part of the canister, under the part where the attachments are stored.
Posted on Jan 08, 2008
  • 3 Answers
You probably have a clog somewhere, also there is a vacuum switch close to the motor, check that. Those machines cut off if the vacuum pressure drops due to an obstruction.
Posted on Nov 27, 2007
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
Accessory compatibility between Electrolux Models 1521 and Epic 6500 SR
No, they have different connectors. 1521 uses a pigtail hose that has little metal clips. 6500 has a plastic end with an arrow that helps guide you for proper placement. Unfortunately you will need 2 separate hoses for the respective models.
May 12, 2015 | Electrolux Vacuums
I have an Electrolux Epic 6500 SR vacuum and the hose end with the handle is separating. Power nozzle losing contact intermittently. Is this piece replaceable or repairable?
It is replaceable. Just take it to the nearest Aerus Electrolux store and the service tech will take care of it for you.
Go to the following site and follow instructions to find the stores nearest you.
Nov 18, 2010 | Electrolux Epic 6500 Vacuum
I have the electrolux vacuum epic series 6000 SR and bought it used therefore I dont have a manual. I have had it for about a yr and it worked looked like it should have a filter but I didnt...
1. A manual can be downloaded from:
The Epic 60006500 is located under "Older Models". Download the Epic 6500 manual
2. Check for clogs in the hose and the power nozzle inlet.
3. Disconnect hose. Turn on vacuum. Does it run? If so, place hand over intake? Did it shut off? If it did, the problem is a worn out or broken component inside the vacuum. Generally a result of using generic "made to fit" Electrolux bags. This is a part that needs to be replaced in an authorized Aerus (Electrolux) shop.
Sep 15, 2010 | Electrolux Epic 6500 Vacuum
I have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Dec 05, 2009 | Electrolux Epic 6500 Vacuum
I am looking for an owners manual for my Epic Series 6500 SR.
Owners manual in pdf-format Electrolux Epic Series 6500 SR:
Clicking "Epic6500.pdf" will pop up a registration shortly,
but the manual appears directly after that.
Aug 09, 2009 | Electrolux Epic 6500 Vacuum
Series 6500 SR won't start
Look for a restriction somewhere in the suction system. Inspect every last inch of it so you know it is clear.
Jan 24, 2009 | Electrolux Epic 6500 Vacuum
Well, make sure the hose part is not clogged, this happened to my friends recently and their vacuum was smoking, if you're positive this isn't happening then it might be just the engine call the sellers, try to explain and see if they exchange for a new one or a refund.
Nov 29, 2007 | Electrolux Epic 6500 Vacuum
Vacuums Logo
1,116 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
