My parents have lost the manual for their GE P7 (electric) self cleaning oven. They are trying to get it to go into clean mode. They have raised the window cover, latched the door shut, put both the temp and oven control in CLEAN mode, set the clean time for 1.5 hours, but can not figure out how to initiate the clean cycle.
Is there a pdf of the manual around, or can you tell me how to start the cleaning cycle?
Dave Keener
I, too, have lost my manual and none of the timers work. I can never remember how long to run the clean cycle for, but will turn it off as it has been a little over 2hours and your post mentions 1.5hours.
I initiate the cleaning cycle by completing steps mentioned above and then turning the top dial (which has a clean range on it) clockwise until the clean light comes on. I then just time it by my watch to turn it all off. Then I wait a couple of hours before attempting to open the door. Don't forget to take the racks out, they are not suppose to go through the Clean cycle.
Good Luck,
Linda
I just found this site from GE : http://www.geappliances.com/search/fast/...
Gives all needed info. Above in my explanation- don't turn oven set off as the fan needs to continue running to cool. Lock light will turn off when ready to open.
Linda
I'll look to see if my folks have theirs
Before you go working too hard to get
you oven to go into the self clean mode(self destruct)....check out
this tip...
Self
Cleaning Oven Problem
heatman101
Wish I had read this first. I never would have used the self cleaning
option. Thanks for the info!!
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
this is the pdf manual for the GE oven model: JKP07
http://genet.geappliances.com/DocSearch/...
More manuals are available at:
https://www.deviantart.com/emdad-compute...
