Question about Bose & Wave& Music System
Bose wave radio/cd often cd spins but does not play, sometines will correct if I turn unit off and on. HELP tHANKS
  • 1 more comment
  • Anonymous Jan 27, 2008
    Exactly the same problem CDs will not play anymore. Sometimes turning it off then on again helps, sometimes it will eventually start playing after minutes of spinning, at other times it justs spins & spins and NEVER starts. I paid what I consider to be a lot of money for this device and really do want it to work. What can I do ? Don't BOSE have any pride in their products ??
  • pipestoner Mar 01, 2008
    I have the same problem with my unit! I have resisted the urge to pound the thing with my fist or a sledgehammer, but really I would like to know if there's a way to fix the problem.
  • Anonymous Mar 27, 2014
    cds won't play at all
    New Friend:
I've repaired about 10 type Bose AWRC3x (the radio/cd model with lift up lid and top controls). If the cd won't play or skips, try cleaning the lens VERY carefully with a cotton bud with some isopropyl alcohol. Let it dry then try again. This will help in about 1/3 of cases.
After that, a new laser unit is needed. They cost around 15 pounds,30 dollars, (Type SFP100s with 13 pin connector made by Sanyo). You need to have some electronics experience to take the case to bits to get the laser deck out, change the cd laser and reassemble. Basically, DISCONNECT THE POWER! Remove the 3 screws on top, turn over and carefully prise the front of the base away from the top cover with a table knife or similar. Lift off the top cover - be careful with the lid ribbon! The deck can be disconnected from its ribbon cable and wired connector very carefully. Take the deck to bits and fit the new laser head (take photos if you think it will help). Remember to unsolder the shorting 'blob' of solder which protects the new laser from static till its fitted.
On the bright side, there is no tracking etc to set up, that's all automatic so usually they work like new with a new laser fitted. I have to say this is the weakest feature on the Bose CD radio, the actual electronics rarely gives trouble.
Hope this helps Steve O'Donnell
Posted on Mar 20, 2008
Bose wave radio cd won't play cd's
If your CD is not scratched,the optical lens need replacement.
Apr 02, 2013 | Bose Awrc1g Wave Radio Cd Player Only -...
Bose wave awrc-1g cd player spins but does not play.
You have done what i would have suggested, the Bose Wave unit will need to back to Bose for service, and there is a good chance they will need to replace the laser pickup assembly and cost should be considered even thoe it is top of the line.
Apr 02, 2012 | Bose Wave radio/CD remote control -...
I copied some music to a disk with 4 different formats but the bose radio wont play any of them.
The Bose Wave Radio doesn't have a CD player. The Bose Wave Radio/CD does.
It will only play standard music CD's with standard CD Audio on them.
The manual is available at Bose.com.
Mar 15, 2011 | Bose Wave Radio
I have had a boise radio abdcd olayer for some time and know very little about its operations. today i played a cd and left the house and expected it to stop as it usually does. however, it keeps on...
With the typos and all it's just a guess, but I'll assume you mean the Bose Wave radio.
I suspect the CD Mode button has been pushed so that the mode is set to REPEAT.
The manual for the Bose Wave Radio / CD is here:
http://www.retrevo.com/support/Bose-Wave-Radio%2FCD-Radios-manual/id/19079bh132/t/2/
Jan 11, 2011 | Bose Wave Radio
I have a bose wave radio and cd player the cd
you sure have a problem with your cd pick up unit or servo drive,for that must bring it to your local repair shop
as for the poor recepcion olease try a better antena
Dec 18, 2009 | Bose Wave Radio
Cd does not play
Does the radio work? If not, make sure the volume is up. If so, the speakers are not blown. Return your product.
Oct 15, 2009 | Bose & Wave& Music System
Bose Wave Radio with non-Bose speakers.
bose cd will not work but radio is fine
Jul 28, 2008 | Bose & Wave& Music System
Bose Wave AWRCC2 error message
Which error, you did'nt put it in the post.
Mar 31, 2008 | Bose Wave Radio
Wave CD changer
Could try a CD lens cleaner disc, but this will just as likely get stuck inside. Far better to contact Bose for a repair - sounds like a problem in the changer mechanism
Dec 11, 2007 | Bose Wave Radio
Bose & Wave& Music System Logo
803 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
