Question about Cameras
Why doesn’t my solar panel fully recharge my battery?
  • Anonymous May 25, 2019
    MAybe the sun has gone out - have you looked up in the sky recently ?
  • 4,204 Answers
The battery may be detective or the charger does produce enough power.
https://zhcsolar.com/solar-charge-controller-not-charging-battery/
Posted on May 25, 2019
5 Suggested Answers
SOURCE:
geokohler
  • 304 Answers
SOURCE: Solar power cell
Here is a link to a site for solar panels and all the required information you need for your application:
http://www.firemountainsolar.com/
Here is their phone number also: 1-877-230-7710
Just give them a toll free call and their friendly staff will set you up with the equipment you need for your project. This is where I bought the solar system for my RV. They are the best source for solar sells and info on the internet. I researched 20 companies before I went with Fire Mountain Solar. I was fully satisfied with every aspect when dealing with this company and they stand behind their work and their products. You can not go wrong with them.
I hope you find this information priceless. If you do please take the time to rate my solution fixya as I found you the best source for your solar cells from the best company that I deal with myself. If you need any help in the future I will help you for free again. I do this for a hobbie. geokohler@gmail.com
Posted on Jul 28, 2008
SOURCE: solar battery charger
Yes, but the efficiency of solar cells is terrible. Its one thing to use free sunlught to charge the cells, its another to have to pay the electric company to do it. If you can access the batteries in the solar rig easily and they are in the correct voltage range, I think you would be better off getting a battery tender (trickle charger). Just let the van sit outside until the batteries are fully charged, then connect the battery tender to keep it fully charged.
Posted on Feb 21, 2009
  • 400 Answers
SOURCE: I had asked about a solar panel on the AC of our
That is correct the solar panel will charge the RV battery which is connected to an inverter. This converts the DC power to AC for the AirCon.
Posted on Nov 04, 2009
Testimonial: "Thanks very much. Very helpful."
mkh5094
  • 145 Answers
SOURCE: outdoor umbrella with solar leds with switch, doesn't turn on
If you connect to solar panel for the lights to go on do the lights go out at night? If so, and the they do not light when hooked to the batteries then the batteries may have no charge and may also not be holding a charge. Put in new batteries to test.
Posted on Apr 26, 2010
Can I charge my HP 632 (that has rechargeable batteries in it; from the USB hooked to a solar charger?
You may recharge the batteries using any compatible charger. It doesn't matter to the camera whether the charger is powered by a nuclear reactor or a hamster running in a wheel. Bear in mind that the HP M632 is NOT a battery charger. The batteries must be recharged outside the camera.
Dec 12, 2012 | HP Photosmart M632 Digital Camera
We have set up the solar power fountain with pump as per instructions. The pump is submerged, solar cell in full sun for 3 days, but the pump does nothing. doesn't even make a sound. Its an 8 watt...
Using a battery/volt meter, check if the battery has a full charge. Also check if there is an on/off switch on the back of the solar panel. If the batteries are removable and are standard batteries, charge them using an AC battery charger the first time. If not, you may have a defective solar panel and should return it to the store/manufacturer.
Aug 20, 2011 | Solar Powered Pond Fountain Pump Kit - 80...
We bought a solar light a Westinghouse item # 37136608W It had a least 7 hrs of direct sunlight for over 7 hrs.but still does not work, We think we had it on. is it possible that the off switch shuts off...
For first time use solar light needs to charge in full sunlight for 8-12 hours with the switch in the "ON" position to allow the rechargeable battery to reach maximum capacity.
There is also a protective film on the solar panel that needs to be removed.
After doing that, fully charging the battery with the switch in the "ON" position, then if the light does not turn on, remove the 4 screws from the solar cell assembly, remove the battery, wipe both ends and reinstall battery. Make sure the battery is making secure contact with the terminals. I had a new one and the battery was loose inside, making the light go on and off. I reseated the battery and all is well.
However you should not have to replace the battery or the unit, it should still be under warranty if you just bought it. Westinghouse guarantees this unit for one year.
A description is here
http://www.westinghousesolarlights.com/products/solar/instructions/371366-08.pdf
Waranty information is here
http://www.westinghousesolarlights.com/products/solar/1yrwarranty.pdf
I would counsel you to just take the unit back for exchange or refund, as the warranty has an exclusion clause and one of the exclusions is if the unit has been opened. Opening the unit might invalidate the warranty.
Mar 20, 2011 | Garden
Outdoor umbrella with solar leds with switch, doesn't turn on
Apr 26, 2010 | Solar 2-wire Pull Chain Light Switch For...
Solar garden lights that don't hold their charge
Actually it is the batteries that are not taking or holdimg the charge...replace the batteries with rechargable ones and they will work...
heatman101
Mar 19, 2010 | Garden
My solar lights will not stay on they will blink and go off.I live in Florida SUNSHINE most of time. These are from Home Depot and are Hampton Bay mfg.
... and they are how old???
In my experience, where I live to the North of you, where I work in a camping resort, where our seasonal campers make use of the same devices from the same supply and source), I have found the batteries in these devices are good for NO MORE than two seasons with little exception.
You might have other troubles, like the day-lite sensor is cloudy or being impacted by some other light source or the panels are cloudy and will not charge the battery fully. Read on please.
The way these things work, generally speaking, the solar panel part of your light actually recharges a rechargable battery in the battery pack. These batteries take a beating - fully recharging and fully discharging EVERY DAY. You can probably replace these batteries with new RECHARGABLE batteries to extend the useful life of your lights. Did I mention the lights are always subject to the full heat of your beautiful sunny days as well as the full fury of your dreadful rainy season? BTW, we visit often and love Florida.
I hope this information helps you.
Thanks for using FixYa.com
please vote
thanks
a
Dec 05, 2009 | Washing Machines
The solar eyes dont light up anymore
Check the rechargable batteries insode of the decoy. The solar panels recharge the batteries so that they can supply energy to the lights at night. The batteries have a limited lifespan and need to be replaced every couple of years. Replacing the batteries ought to bring your decoy back to life. Enjoy!
Aug 04, 2009 | Nurserypro - Floating Solar Alligator...
I have an original freeplay clockwork radio which has died. Help!
Hi , you have probably expired the battery life out of the radio [ they have a recharge battery life ] but all you have to do is replace those recharge batteries with new recharge batteries and your as good as new
Jun 12, 2009 | Freeplay Energy BayGen AM/FM/SW Radio
Solar battery charger
Jun 04, 2008 | 1992 Dodge Ram 250
Cameras Logo
Top Cameras Experts
Marvin
Marvin
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Camera Expert? Answer questions, earn points and help others
