IMAGE RUNNER 600 DOES NOT CONNECT TO NETWORK
LCD SCREEN SAYS WAITING
OPTION TO SET IP NOT AVAILABLE
To increase bandwidth and quality without a paying MPLS prices
www.talari.com/solutions
Shut down any devices you wish to incorporate into your network, including computers and cable or DSL modems.
Connect one end of an Ethernet cable to any of the numbered ports on the rear of the router. Connect the remaining end to the Ethernet port on your computer. Connect a second Ethernet cable to the port on the router labeled "Internet." Connect the other end of the cable to your high-speed modem.
Power on your high-speed modem. Plug the router's power supply into any available electrical outlet; connect the power supply to the appropriate port on the rear of your router. Examine the LCD lights located on the front of your router. Wait for the LCD light labeled "Diag" to stop displaying a bright red light, and then turn on your computer.
Open the network management control panel for your operating system (in Windows, open the "Start" menu, select "Control Panel" and double-click on the "Network Connections" icon; in OS X, open the "Apple" menu, select "System Preference" and click on the icon labeled "Network").
Configure your network settings. In Windows, double-click on the icon labeled "Local Area Connection," click on the button labeled "Properties," click on the option labeled "Internet Protocol (TCP/IP)," select the option labeled "Obtain an IP address automatically" and click "OK" twice. In OS X, select "Using DHCP" from the pull-down menu labeled "Configure IPv4." Repeat this procedure with any other computers you wish to connect to the router.
Open your Web browser and enter "192.168.1.1" in the address field. When prompted, leave the "User Name" field blank and enter "admin" in the "Password" field. Locate the wireless mode menu and select the appropriate option, based on the types of devices you wish to connect to your network (if uncertain, select "Mixed"). Choose a unique SSID name and enter it in the appropriate field; click "Apply."
Click on the button labeled "Enable" next to the option labeled "WEP." Click on the button labeled "Edit WEP Settings" and enter your desired security information. Make a note of these settings; then click "Apply."
Restart your computer(s). For those computers you wish to connect wirelessly, open their network configuration screens and enter the security information in the appropriate fields. Setup is now complete
