SOURCE: Wurlitzer arm keeps running
check the white plastic actuator next to the gear box, it is probably broken and not actuating the microswitch underneath it, these often fail, it may look ok,, but it actually is loose and the set screw on top of it is not clamping it to the rod.
SOURCE: Record Changer Arm
When the carousel reaches the correct count, the computer sends a signal to the gripper motor to start it. You could have a bad motor or a bad computer. But!....if the little switch at the front of the machine is in the off position (Gripper motor On/Off) that will give exactly the same effect. It's easy to knock Off when you are loading CDs.
SOURCE: need manual for Wurlitzer jukebox 1015 45
I suggest that you check out the Victory Glass wedbsite for a manual.
www.victoryglass.com
Regards
Alan Hood
ami-man
UK
SOURCE: Wurlitzer 1015 OMT Disc spins, then stops....
fault could be fuse in cd transformer or decoder board worst it could be the laser unit
Check the fuses behind the coverplate of the amp on the left. If it is a K99 it comes off by loosening the two nuts at the top then flexing it and popping the bottom edge off. If it is a Compact amp you can see the fuses.
