Question about Hardware & Accessories
I understand what 'set' 'Hrs' 'Min' mean on the ETU02 timer. But what does 'Md' mean?
  • SSN-MM3 Jun 07, 2019
    after much Googling, etc, and finding nothing directly relevant (and believe me, I KNOW how to search), I have come to the following conclusions: I believe the MD stands for 'Mode'.
    Your timer question has been asked before and the most relevant answer is this one:
    http://www.fixya.com/support/t14864587-s...https://www.tlc-direct.co.uk/Technical/D...
    Short of actually contacting the company and asking for a manual, I don't believe you will find one. There are many companies that make similar products/knockoffs and the only answer that makes any sense is 'Mode'. You can reference this page also for info.http://waterheatertimer.org/Woods-timers...
    As stated prior, many of the design elements are similar and there is a certain logic to it, which is why the only answer that seems to make any sense is 'MODE'.
    https://www.youtube.com/channel/UC2uFFhn...
    Sergeant:
  • 256 Answers
What brand of timer is it? Smiths, Time*?
Posted on Jun 06, 2019
Testimonial: "It's a Smiths timer."
2 Suggested Answers
SOURCE:
  • 5353 Answers
SOURCE: I have lost the instructions for use of smiths plug in digital timer etu02
10-30-12
Smith's ETU02 timer does not appear on the Smith's manual page:
http://www.tlc-direct.co.uk/Technical/DataSheets/Smiths/Index.htm
Other sites report this 7-day digital timer is discontinued, but can be replaced with similar timer from local box store locally.
Another option is to search following page for same-similar timer that might yield a manual similar to your timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-week
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Oct 31, 2012
I cant understand the times on tht timer
Set it to 5 on the timer and start it. Wait 5 seconds. If it has reached zero, the 5 means 5 seconds.
If it has not, the 5 means 5 minutes.
Dec 28, 2013 | Hardware & Accessories
10-30-12
Oct 30, 2012 | Hardware & Accessories
Verve Digital Water Timer as sold at B&Q have lost the operating instructions.
Verve water timers might be Melnor:
Open following link for manuals.
http://www.melnor.com/instructions.php
Links to other water timer manufactures and manuals are found on following link:
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
Jun 14, 2011 | GARDENA Water Timer
I have a Kenmore Elite Coffee Maker, I press brew, the light flashes and then it beeps but does not brew.
gotta have the correct time set, also check auto brew timer. Coffee pots usually beep when they are done brewing and then when it's turning off, usually after a hour. Play around with timer (hrs. and min.)
Apr 07, 2011 | Coffee Makers & Espresso Machines
The load starts out with 1 hr 3 min on the timer, but during the process the timer may go from 35 min to 40 min, then when it gets down to 29 min it goes back to 34 min and so on and by the time its done...
not sure but sounds like a mother board is playing up, try turning it off at the wall over night just to see if it will reset itself.
if not you will need to keep asking.
Mar 25, 2011 | Washing Machines
How to program a digital timer
You posted under a photo that looks like Woods 49063 or GE 28441
Link below shows this particular timer with manuals for each:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
If your timer does not show on link above, add a comment with as much description as you have, with button locations and color and purpose of timer.
To program the GE timer:
1) Set current time
Press and hold Time button: and then push hour and MIN button to set current hour and current minute.
2) To program:
Press and hold PROG button for 1 second
Prog 1 ON will display
This is program1 ON
Press hour button and MIN button to set program1 ON hour and minute
Prog 1 OFF will display
This is program1 OFF
Press hour button and MIN to set program1 OFF hour and minute
Prog 2 ON will display
This is program1 ON
Press hour button and MIN to set program1 ON hour and minute
Repeat steps to program up to 6 different ON-OFF programs
When programming is finished, press TIME button to return to current time.
3) Set MODE
Press mode button once and ON displays, this means light is ON
Press mode button again and OFF displays, this means light is OFF
Press mode button once and nothing displays, this means timer programs will run as you set them
Dec 12, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Takes 2 hrs to run a 45 min cycle
defo a heating element fault or an ntc fault. More likely to be the element though.
Mar 10, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
SHUTS OFF AFTER 1 HOUR
Here ya go!
Setting Auto Off (units with timer only)
On models with a glass carafe, the auto off can be set to shut the coffee machine off from 1 - 5
hours after the brew cycle is complete. The factory setting is 2 hours. On models with a thermal
carafe, the coffee machine shuts off after 20 minutes.
Note : On models without a timer the coffee machine must be turned off manually. It
will not automatically shut off.
• Press the prog button (o), immediately followed by the h/min button (n).
• The display will show the time setting.
• Press the h/min button in steps to set the auto off time.
• Press the prog button to confirm the setting.
Dec 30, 2008 | Krups FME2 Coffee Maker
Converting a sony mini disc into a mp3/audio cd
i understand (i've gone through 3 sony md recordable players & now i have about 15 - 20 md with good mixes from clubs/carribean islands beach partys) the only thing i can suggest is invest in another mini disc that is capable of playing the 74 min disc (and speed that was recorded) here are two sites to check out 1--http://shopping.yahoo.com/s:Portable%20MiniDisc%20Players and 2-- http://www.google.com/products?hl=en&q=mini+disc+player&um=1&ie=UTF-8&ei=OhkbSozEApC6tAOr9NCSDw&sa=X&oi=product_result_group&resnum=4&ct=title
Nov 25, 2007 | Sony Net MD Walkman MZ-N910 Portable...
Looking for manual of a chefmate bread machine
I have a manual for CM 725 if someone still needs it.
Sep 20, 2007 | Kitchen Appliances - Others
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
