Question about The Kitchen Appliances - Others
CPT-415C toaster. Purchased December 2017. The down lever will not stay.
SOURCE:
  • 3 Answers
SOURCE: My Krups model 288 toaster won't always latch down.
You can fix this yourself by following these instructions. Unplug your toaster before proceeding!... Clean the toaster first. Turn the toaster upside-down and shake out the crumbs. Remove and clean the bottom crumb tray. 1. Unscrew the four Phillips head screws located in the corners of the bottom base. Remove the screws completely if possible. Do this over a cloth or newspaper - that way a stuck screw won't get lost if it falls out later. 2. With the toaster right-side up, pull off the wide toast lever knob. Do not remove the round adjustment knob (it will not come off from the outside) but make a mental note of what number (1-7) is showing at the knob's adjustment mark. 3. Carefully pry up the end of the case cover with the knob on it (don't pull on the "stop" button). When the knob's plastic shaft is clear of the circuit board, gently pull off the cover. 4. On the inner part of the circuit board you will see a black plastic "cam" surrounded by two sets of electrical contacts. Rotate the cam to open the contact points if necessary. Insert a thin nail file between the points and rotate the cam to trap the file between them, then scrub back and forth several times to clean the contact points. Do this for each contact on both sides of the cam. When finished, rotate the cam clockwise so it is all the way back down to it's original position. 5. To make re-assembly easier, remove the round adjustment knob from the cover by depressing the half-round shaft flanges inside the cover with your fingernails. 6. Re-assemble the toaster by reversing steps 1 & 2. Replace the knobs, making sure that the round one is in the same position you noted earlier before you push it all the way down.
Posted on Mar 27, 2007
snakehead
  • 1074 Answers
SOURCE: Toaster broken???
these toaster has to be pluged in so that the lift lever could stay down.
Posted on Feb 25, 2007
Ian Prins
  • 11 Answers
SOURCE: toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Posted on Dec 06, 2007
  • 16 Answers
SOURCE: When I depress the carriage control levers they do
my toaster did this once, i suggest that you get a new toaster from a different company, because if you've only had the toaster a month
and its doing this already that's a crappy toaster
Posted on Apr 20, 2010
SOURCE: toaster won't stay in down position
We opened up our toaster and scraped some baked-on crumbs off the top of the electromagnet that controls the carriage catch. When we closed it back up, it worked again.
Posted on May 10, 2010
Lever won't stay down
They are disposable items these days, just buy a new one. They aren't made to be repaired.
Jun 10, 2015 | Cuisinart CPT-70 Classic Style 2-Slice...
Lever will not stay down
There is a catch thatvis not free to move in place when pushed down. It may be jammed.
Feb 12, 2013 | Cuisinart CPT-70 Classic Style 2-Slice...
Toaster latch does not stay down on Cusinart CPT-120 compact two slice toaster
for Cuisinart cpt160: If the latch will not stay down it is because the electromagnet at the base of the toaster, which is supposed to activate when you push the handle down, is burnt out. I pulled my toaster apart and did a test of that mechanism and found that the solenoid was fried (open circuit). There are no replacement parts.
Jan 09, 2011 | Cuisinart CPT-160 Metal Classic 2-Slice...
Apr 20, 2010 | Cuisinart CPT-180 Metal Classic 4-Slice...
The toaster arms will not stay down on either side , have power to the toaster and can see the elements light when arm is held down but won't stay down.
First, turn it to the darkest setting. It may be set too light to stay down. Also, try cleaning it out. Take it outside and turn it upside down and shake it. Also, open the crumb door on the bottom. Hope this helps. Good Luck.
Feb 10, 2010 | Cuisinart CPT-180 Metal Classic 4-Slice...
Toaster won't stay in down position in order to toast - Cuisinart CPT-160 - although it will toast if I hold the lever down as it toasts
Dec 22, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
My cuisinart cpt 160 toaster won't start
Do any of the lights come on ?
If not then have you checked the plug top fuse
If the lights come on and then when you press the lever down it does not latch a solenoid has gone open circuit
Good toasters can be fixed
Cheap ones go in the trash bin
May 29, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
Toaster arms will not stay down
Arms stay down by the mean of an electromagnet, controlled by a chip. If the wall outlet is functional, you should be able to turn on light by pressing the "defrost" or "bagel" button while the arm is held down. No light? the toaster is good for garbage!!
Mar 15, 2009 | Cuisinart CPT-180 Metal Classic 4-Slice...
When i push the lever down to make toast, it does not stay
This is a problem, our old toaster had this problem, and it would only work if we jammed the handle down, but don't try this, only because ours broke after we tried this, but if you can send it to the manufacturure, they should be able to fix this. If you don't what to do this, please phone me at 505 9181, but please call me from 8:00-10:00, 2:30-8:00.
Oct 21, 2007 | Cuisinart CPT-60 Custom Control Total...
4 slice toaster
open the unit. look for disconnected wires from sloppy factory
May 20, 2007 | Cuisinart CPT-140 Cool Touch 4-Slice...
Kitchen Appliances - Others Logo
27 people viewed this question
Top Kitchen Appliances - Others Experts
vince
Kitman
Level 1 Expert
Carlos Alvarez
Level 1 Expert
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
