Question about Singer Sewing Machines
I have a 3337 singer sewing machine.every ting ok but the tread keeps going out of the nedel, Is it the needle need to be changed. thank you
SOURCE:
  • 255 Answers
SOURCE: inserting needle on old singer machine
Hi Terry--
If your machine is 40-50 years old, it might be a Singer Featherweight portable. (If it is, you have one of the very best machines ever made!) On the Featherweights, the flat of the needle faces left (and the needle is threaded from right to left). The bobbin goes in a bobbin case; you'll see a small notch when you look down on the bobbin in the case. That's where the thread goes. I'll email you direct with more information.
Lookingpast
Posted on Jan 11, 2008
  • 37 Answers
SOURCE: tread keeps coming out of the needle.
Make sure you sink the needle into the fabric before starting to sew. If that isn't it...remove the thread and rethread the machine. Make sure the thread isn't wrapped around the spool holder.
Posted on Apr 16, 2009
  • 139 Answers
SOURCE: how to thread & what needles for singer 660 A2 sewing machine
You can download a manual here:
http://parts.singerco.com/IPsvcManuals/
Posted on Apr 07, 2010
  • 1788 Answers
SOURCE: twin needle treading for singer sewing machine 3116
Yes, put your second thread in a cup behind your machine and thread your machine like normal
Posted on Aug 15, 2010
Joe Onley
  • 363 Answers
SOURCE: Singer Electronic Control Sewing Machine
Hi Cat,
This seems to be a common problem, but easy to fix. Check the bobbin, and see if the thread feeds out quickly when holding the thread and letting the bobbin case drop. You should see a small screw on the front of the bobbin case for adjustment. Screw that until the drop rate is slight. You may need to adjust a few times to get just the right rate of feed.
Hope this helps, Please rate and comment, Thank You
Joe
Posted on Sep 07, 2011
Singer 9960. my tread wont catch the bob tread
check and adjust needle thread tension tighter
check needle /hook timing
Feb 22, 2018 | Singer Sewing Machines
Need a botton plate cover unable to find for singer sewing machine model number 3337
contact a singer service agent to get the part or contact singer spares direct
Oct 21, 2017 | Singer Sewing Machines
Ive got a singer sweingmachine 247 model no when i put the bobbin in the bobbincasing with tread and guide so the needle goes down to bring bottom tread up nothing happens it doesnt feed it to come up i...
try changing the needle
try rethreading the machine, make sure the presser foot is in the up position
make sure the bobbin is turned correctly in the bobbin case,, counter clock-side
also could be a timing problem
Dec 22, 2014 | Singer Sewing Machines
Evey time I start to sew, my tread keeps breaking at the needle
i would change the needle
check the top thread tension it may be to tight usually 3 or 4
check the needle plate to make sure there are no burrs on it
rethread the machine to make sure the thread is not caught anywhere
try a different spool of thread
Aug 13, 2011 | Singer Sewing Machines
Twin needle treading for singer sewing machine 3116
Jan 22, 2010 | Singer 3116 Simple
When I tread the machine and lower the foot, press the peddle it appears to be sewing but nothing sew together.
the problem of your machine is your needle. put your needle in his right position. adjust the tension. and it is ok. promise
Oct 08, 2009 | Singer 5050 Mechanical Sewing Machine
Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Apr 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Inserting needle on old singer machine
Hi Terry--
Lookingpast
Dec 26, 2007 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
24 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
