Question about Lexmark Office Equipment & Supplies
Lexmark x4650 says it has no signal. It won't print documents. What do I need to do?
Hi, My lexmark x4650 printer will not connect to my laptop. I tried unplugging everything and resetting it but none of that helped. I bought a new wifi antennae piece because the other one snapped. It keeps displaying that there is no signal. I have been trying to figure this out for days.
SOURCE:
SOURCE: printer problem lexmark and hewlett packard
Turn off all your security software (antivirus, firewalls), download the latest drivers from the lexmark site, manually extract them to a folder without running the setup wizard- connect printer to usb- go to the folder you extracted the files to, right click on the setup file and 'run as administrator'- it should successfully install and go wireless-
Posted on Feb 10, 2008
SOURCE: lexmark 3400
i had a similar problem when the printer wouldn't print. Make sure that the printer 3400 lexmark series is the default printer in the control panel. (start/control panel/printers/printers and faxes/right click lexmark 3400 series/set as default printer).
Posted on Nov 05, 2008
  • 140 Answers
SOURCE: Can't get my wireless printer to receive a signal from the router
I would take that printer back. I do not know which store you bought it from, but from my troubleshooting experience rule out that it is in fact not the printer. Another one taken through the same paces will tell you that. Then you know that it is something outside that printer or some question or parameter not answered right during the installation process. Good luck and God bless.
Posted on Jan 08, 2009
  • 3278 Answers
SOURCE: New installation- can't figure out how to make wifi printer operate
You hadn't indicated that you have the installation software. If you have, just insert the CD and follow the instructions. They are pretty clear. The Wifi light is orange and then turns green when complete.
Posted on Jun 15, 2009
Printtech
  • 1087 Answers
SOURCE: My Lexmark X4650's wifi light is off. I have tried
Great job on trying to reset the printer's wireless network adapter. Somehow, the printer's memory is stuck to thinking to connect to a wireless network when it's not communicating at all. Unplug the power adapter from the printer. The power adapter is the rectangular black box behind the printer where the power cord is attached. Wait at least 30 seconds before plugging back the power adapter in the printer. That should refresh itself. If wifi light won't turn on orange after the printer's on ready, reset the wireless network adapter again. Thanks.
Posted on Jul 27, 2010
I have a Lexmark X4650 InkJet Printer I need to find a driver to install
You can download the drivers for your Lexmark X4650 at www.Lexmark.com. Just choose the Operating System of your computer.
May 03, 2012 | Lexmark X4650 All-In-One InkJet Printer
Just got a new HP with Windows 7 Home Premium and a new Lexmark x4650. Printer only works intermittently. Have installed and uninstalled the drivers more times than I care to remember...at least 5 times....
This could be a driver issue. Try to uninstall the driver this way, refer to this article: How to Uninstall Lexmark Printers. Reboot pc when prompted. When your computer turns on, check if your Windows 7 is running on 32-bit or 64-bit System Type. Go to Start menu -> right-click on Computer -> Properties. Take note of the System Type.
Download and re-install the driver using the links below: - Lexmark X4650 driver for Windows 7 32-bit - Lexmark X4650 driver for Windows 7 64-bit
Execute the file and follow the instructions on your computer screen.
Apr 28, 2011 | Lexmark X4650 InkJet Printer
My lexmark x4650 printer is connected to the wifi, but the orange light is blinking. And nothing is able to print. When I look at the printers activity it shows the document that im trying to print but...
When you installed your printer, you had to install the software on your PC. So go to your PC's start menu, go to Programs, select Lexmark software, select Tools and then select Wifi Configuration Utility. It will open a window which will give you step by step instruction on re-configuring your wifi settings. When you are doing this, make sure your printer is connected to your PC via the USB cable.
Apr 07, 2011 | Lexmark X4650 InkJet Printer
Hello, My Lexmark keeps failing to print, or often prints only the last couple of pages of a multi-page document. Any idea why? Thanks
Hi
Please try to set up again the printer and set it as default printer to correct the driver corrupted.
Please let me know if you need more help. Please rate my solution. Regards
Mar 01, 2011 | Lexmark X4650 InkJet Printer
I had my x4650 series printer connected wireless and it worked fine for about 2 weeks. All of the sudden it would not print anymore. I uninstalled it, and reinstalled with the driver disk and connecting to...
It seems that the driver and software has incompatibility issues with your computer's Windows version or Windows might have downloaded and installed an update that caused this problem. I suggest first to visit Lexmark x4650 support & downloads website to download and install appropriate drivers by selecting your windows version (XP, Vista or 7). Remember to uninstall existing software & driver first. If problem persists, contact your printer's manufacturer for assistance.
This is your printer manufacturer's contact details.
http://www1.lexmark.com/content/en_us/about_us/contact_us.shtml
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Jan 22, 2011 | Lexmark Office Equipment & Supplies
Just installed software cd for lexmark X4650 on laptop with windows 7 64 bit. Productivity Center app won't work. setup wireless print - works fine. Get a popup that says to download m.NET Framework 2.0...
You will need to use the Lexmark X4650 driver for Windows 7 64-bit from the Lexmark website. First, uninstall the existing driver from your pc. Go to Start menu -> Programs -> Lexmark 4600 Series -> Tools -> Uninstall. Reboot your pc when prompted.
To reinstall, click on this link Lexmark X4650 Driver for Windows 7 64-bit. Download, execute the file and follow the instructions on the software.
I hope this information has been helpful. Thanks.
Jan 13, 2011 | Lexmark X4650 InkJet Printer
I cannot delete a document from my print queue on my lexmark x4650. I get the deleting message but the document does not delete and now I cannot print any other document. How do I fix this?
Have you tried restarting your PC? Once you do this, unplug your printer power cord for a few minutes, uninstall your printer from your computer and reinstall the software. Then plug your power cord back into your printer and try printing your document once more.
Hope this solves your problem.
Best wishes,
Graemevm
Aug 04, 2010 | Lexmark X4650 InkJet Printer
Turning off unnecessary printing instructions
I believe this is controlled in the software part of the printer. Check the Lexmark Productivity Studio under settings. There should be an option that says enable instructions page for 2 side printing.
Feb 05, 2010 | Lexmark X4650 InkJet Printer
X4650 not printing footer correctly
Most printers have a no print border roughly 0.6 cm around the page.
You may be able to set the printer to "Edge to Edge printing to get around the no print zone.
Don
Oct 23, 2009 | Lexmark X4650 InkJet Printer
Open Questions:
20 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
