Question about Exercise & Fitness
How can I adjust the calorie counter on the yahoo sports band? I have walked 3488 steps or 1.44 miles and it says I burned 313 kCal. Is this correct?
SOURCE:
SOURCE: how to setup the omrom Walking Style pedometer
go to the company's web page: http://www.omronhealthcare.com/product/manuals.asp The Support tab has a link to Instruction Manuals. Then use the tab for Fitness Diagnostics to find the manual for your product. It's downloadable, so you won't lose it again!
Posted on Feb 16, 2009
SOURCE: How accurate are the calorie counters on treadmills and cardio equipment?
Here's what the Sole exercise equipment makers say about calorie counters on exercise equipment. it's from their E-95 users manual: "Calorie readings on every piece of exercise equipment, whether it is in a gym or at home, are not accurate and tend to vary widely. They are meant only as a guide to monitor your progress from workout to workout. The only way to measure your calorie burn accurately is in a clinical setting connected to a host of machines. This is because every person is different and burns calories at a different rate. Some good news is that you will continue to burn calories at an accelerated rate for at least an hour after you have finished exercising!"
Posted on Mar 19, 2009
SOURCE: The Reebok Fitwatch 10S Calorie Counter
Yes when you are in time mode press the mode button 5 times this will be your calorie screen press the st/stp button to activate the calorie counter you will see in the bottom left corner it says CA ( meaning calories) and in the bottom right crn are the calories you are burning press the st/stp button again to stop then reset when you want to start again.Hope this helps can you help me? I keep pressing the sensor buttons and my heart rate does not appear what am I doing wrong ? Ive read my instructios inside out even returned the watch and got another but the same thing keeps happening ! Initial when I set the watch up it works then I just cant seem to get my heart rate to appear ????????? Thanks Nicole
Posted on May 15, 2009
  • 65 Answers
SOURCE: My sportline watch resets itself during exercise
I don't know this watch personally but it sounds like it may be a short circuit or maybe one or two of the buttons may be being activated during a particular movement. I'd recommend you take it to a watchmaker for diagnosis.
Posted on Jul 30, 2009
maxtreadmill
  • 832 Answers
SOURCE: was given a Schwinn spin bike Model DX 900. Has
Sometimes taking them out looking at the Battery holder for corrosion first then check if the batteries are in the right way ( I've made that mistake ) Also the wire that leads down to the sensor and see if its adjusted correctly
Posted on Aug 14, 2010
How do I reset a Sportline WV1915WH after putting in a new battery
RESETTING PEDOMETER DATA
1.
Reset Pedometer data by
PRESSING & HOLDING
the
RESET
key in Step, Distance (Mile or
Km), Calorie (Kcal), Speed or Timer modes
Aug 29, 2017 | Sportline Watches
How do I reset the time?
How to Configure Your Omron HJ-303 Pedometer
www.walking4fun.com/.../pedometers/...pedometer/how-to-configure.ht...
When your pedometer first comes out of the box, you'll need to configure it. When youchange the battery, you'll have to reset the time on your pedometer, but the ...
[PDF]Getting Started: Setting Up Your Pedometer
www.whoi.edu/fileserver.do?...
Woods Hole Oceanographic Institutionyour pedometer and walk your way to better health. Pedometer Setup ... down theRESET button. Additional ... you'll track steps, time, and miles throughout your daily routine. And, in ... Do the math: 20 divided by the number of steps equals.
How to Reset an Omron Walking Style Pedometer ...
www.livestrong.com > Sports and Fitness
Oct 28, 2015 - Your Omron pedometer is a fitness accessory used to provide a great amount of ... session, including steps taken, time walked, distance traveled and calories burned. ... Do not use the end of a pencil to perform a system reset.
Dec 14, 2015 | Exercise & Fitness
When does the clearview pedometer reset
I'm responding 'cuz my Clearview pedometer remains something of a mystery to me, too. So I apologize, right off, about the length and confusion in this procedure. Maybe someone will add a simpler, comprehensive list of commands.
W/o access to a user manual, here is what I've learned about it. Barbara, I didn't think it reset itself... maybe you can explain. I did find that when I hit the "reset" button on the back (to the left of the belt clip), it resets the Step (number taken), Mile (distance traveled), and Kcal (calories burned) to zero. One click for all-three together.
More SETTING steps: The menu is a vertical column to the right of the digital display (from top to bottom: Step, inch, LB, Mile, Kcal). As you scan down the menu, look for the teeny > arrow pointing at one of the functions. Normally the arrow skips from Step, to Mile, to Kcal. If you've been using it, and there are numbers in these fields, you can manually reset these to zero by pressing the "reset" button. Those 3 fields should now register "0" when you scan through the modes as before. I believe this does not reset your stride or weight settings.
These other 2 modes: inch (length of YOUR step), and LB (YOUR weight = this helps in calculating your calorie consumption... I think) were a bit tricky to reset to MY body. I managed to select those modes and enter my own data somewhat haphazardly, by simultaneously pressing the two buttons on the right (Mode, and Set); and then (sometimes, but not necessarily?) pressing the Set button alone. Either way, if you're lucky (!) you'll eventually get a blinking number and the arrow > indicating which field you're in: inch, or LB.
If it is the inch field, it will read 0, or something like 30 (your stride in inches). If you want to change it, press the SET button repeatedly (lower/right) to INCREASE the number in the field. Apparently you can't lower the number directly - if you instinctively press the upper/right button (MODE), it just closes the setting function.
So in order to set to the length of YOUR step, keep pressing (or you can hold it down) until you reach your stride length... it continues up to 120 inches (!!) before restarting at zero. I haven't figured out why it opens in inch, or in LB, but by randomly pressing both rt-hand buttons, I can eventually get into each of the two fields. The weight settings in LB also adjust only upward by pressing the SET button (that is, once you get the field to open). You may have to go to 150# (its max. setting) before you can begin at zero again. Last weird note: When I can't seem to get into these fields at all, I have had some success by pressing and HOLDING the SET button until the reading (usually 0, by then) blinks off and then on, once. Then you can proceed with the other steps.
Mar 24, 2014 | Ariel Premium Supply Clearview Pedometer
Is the Kcal an abbreviation for calories? Also, how do I read that screen? It has a 35 on top and 1.9 on the bottom? Thanks. HJ-112
I can help only with the Kcal. Kcal is the abbreviation for KiloCalorie (1000 Calories) (The prefix "Kilo" means 1000x) The Metric system uses the Joule and if you like arithmetic, 1 calorie = 4.186 Joule)
Mar 09, 2013 | Exercise & Fitness
If I walk for a mile how many calories will I burn?
it really depends on the speed, but on average you will burn about 100 calories when walking a mile.
Feb 20, 2013 | Luggage & Travel
How does the e3200treadmill fat calories work with the regular calories burnt.
Add incline. Instead of keeping the treadmill on a flat surface, maintain an incline as you walk, jog or run. This will serve to replicate the wind resistance and terrain variation that you encounter when you run outdoors. Keep an incline of at least 1.5 percent on your treadmill throughout your workout.
  • 2 Increase your speed. If you run at the same speed every time you workout, your body will not be challenged and you may reach a fitness plateau. Up your speed by a quarter-mile per hour every few weeks.
  • 3 Vary your workout time. In order to challenge your body in different ways, variety is key. If you run for half an hour three times a week, opt for a one-hour run for your fourth workout. This will help to condition your body for endurance training, resulting in more calories burned.
  • 4 Use intervals. Interval training can dramatically increase your calorie burn in an average workout. Instead of running at a steady pace for your entire workout, mix in sprints. Jog at a steady pace for two minutes, and then increase your speed to a full sprint for 30 seconds. Return to the steady pace to recover. Your heart rate will rise on your intense sprint intervals and stabilize on your longer recovery periods.
  • 5 Incorporate incline into your interval training. You can use incline in the same manner that you would speed to interval train. Walk or jog at a 5 percent incline for two minutes. Increase the incline to 10 percent for two minutes and then to the 15 percent maximum for one minute. Decrease the incline back to 10 percent for two minutes and finally back to 5 percent for two minutes. Repeat this same pyramid interval a few times.
  • 6 Wear a heart rate monitor. This will monitor how hard you are actually working as well as how many calories you burn in each workout. You can then adjust your speed and incline accordingly to maximize your calorie burn.
  • 7 Drink plenty of water before, during and after your treadmill workout. If you are dehydrated, you won't perform as well as you can. You'll work harder and burn more calories if you're hydrated
  • Nov 03, 2011 | Exercise & Fitness
    I don't know what the kcal means?
    KCal is short for Kilocalorie or Kilogram Calorie.
    One KCal equals one standard food Calorie like the kind you see on food labels.
    On your pedometer, this is probably an indication of how much energy you have burned off during your workout.
    Good luck.
    Apr 23, 2011 | Danskin Exercise & Fitness
    Lost the directions need to know how to set all the buttons
    Here see if this helps....
    http://www.gaiam.com/product/pedometer+fitness+kit+-+intermediate+level.do
    How to use the pedometer:
    Take out battery insulator pull tab.
    Set the metric / imperial system.
  • Press the S5 (Up/Mode) to enter step mode.
  • Press S3 (Set) and hold button for 3 seconds.
  • Press S5 (Up/Mode) to toggle between metric / imperial.
  • Press S3 (Set) to select.
  • Basic operation buttons:
    Time mode
  • The display shows the current time.
  • Press S6 (Down) to toggle 12/24 hour display format. If 12-hour display format is selected, PM times are indicated with a P.
  • To set time: press and hold S3 (Set) to adjust mode. Hour will flash and display.
  • Press S5 (Up/Mode) of S6 (Down) to adjust the flashing digits. Hold the button for fast scrolling. Press S3 (Set) to confirm and move to minute. Adjust the minute.
  • Press S3 (Set) to confirm, and return back to the time mode.
  • Step mode:
  • Press MODE key to enter step mode.
  • The display shows the steps you have dones.
  • Press and hold S2 (CLE) to reset the step count. All information regarding the step counter/distance/calorie will be erased.
  • Distance mode:
  • Press mode to key enter distance mode. It shows the distance traveled.
  • To set personal stride: press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and / or S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to distance mode. Set stride: 30-180CM (12-70 inch).
  • Calorie mode:
  • Press mode key to enter calorie mode.
  • It will show the calories burned.
  • To set personal weight: Press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to calorie mode. Set weight: 10-15kg (20-330 lbs.)
  • Measuring your own stride:
  • An individual's stride may vary in length. Input the appropriate length by measuring the distance of 10 steps and dividing by 10 to get your own stride length.
  • How to adjust:
    Motion sensitivity slide switch
  • Attach the unit correctly and walk 100 steps. If the reading is 105 steps or more, slide the Motion sensitivity switch to the left. If the reading is 95 steps or less, slide the motion sensitivity switch to the right.
  • How to wear your pedometer:
  • Your pedometer clips easily and snugly to either side of the hip portion of your pants or shorts. For best results, keep the unit in line with the crease line of your pants.
  • The pedometer must be directly perpendicular to the ground. The pedometer needs to be at a 60 degree angle to the ground. Dragging your feet, walking with sandals or uneven footsteps in a crowded area can affect the accuracy.
  • The pedometer only works when walking, jogging, or walking up/down stairs.
  • How to use the panic alarm:
  • Pull out the panic alarm pin S7 (Panic Alarm) from the unit to trigger the alarm.
  • Press and hold S1 (RES) to stop sound temporarily.
  • Insert the panic alarm pin back into the unit to stop the alarm instantly.
  • Battery replacement:
    Panic alarm and LED Torch battery:
  • Open the battery door by unscrewing the secure screw.
  • Flip out the exhausted battery and replace with two new *CR2016 (3V) batteries. Make sure the polarity is correct. Close battery door and fasten the screws.
  • heatman101
    Oct 02, 2010 | Gaiam Walking Fit Kit Pedometer...
    Looking for a sports mp3 player,any recommendations?
    Sony S2 sports walkman
    It an hold a maximum of 1,350 of your favorite tunes. Workout friendly features include a calorie counter which displays data based upon weight and length of workout, target goals so the music shuts off when you hit the right moment, a stop watch, water resistant and running and walking playlists which play based upon your movement speed. You get up to 18 hours of playback on a rechargeable battery as well.
    Jul 05, 2010 | Sony Sports Walkman NW-S203F MP3 Player
    Exercise & Fitness Logo
    29 people viewed this question
    Top Exercise & Fitness Experts
    Treadmill Repairs...
    Tom Chichester
    ray gallant
    ray gallant
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
