Question about Radio Communications
I have a Milwaukee radio and one day the speaker died and it did not work any more the speaker still sounds very quietly but i can still hear it if i am 15 feet away
    Champion:
  • Radio Commun... Expert
  • 227 Answers
Its better you change the speaker if you need more audio otherwise its ok, at least your hearing the sound.
Posted on May 22, 2019
SOURCE:
SOURCE: Logitech X-240 Sound Problem
I live in the Netherlands and i hear radio from UK, Russia and other languages. It's true it's in evening. Weather here now are rain in thunderstorm, i thought thunderstorms maybe could be the problem. Yesterday evening i heard nothing of the radio station. Hearing that radio staions is against FCC rulles. So it's possible to complain about it to radio stations. Im going to contact Logitecht tmorrow about this problem. I keep you updated.
Posted on Oct 28, 2008
Mechanic688
  • 204 Answers
SOURCE: PA speaker quiet
I think this is a double post,, am I right Freddy??? Mechanic
Posted on Nov 01, 2008
  • 50 Answers
SOURCE: No sound lost volume control
What is the make & model # of your TV? Please feel free to call or message me and I'll do my best to help you with the repair of your TV! Ask for Dave @ 1-503-432-9904 / pleasefixitdave@yahoo.com
Posted on Feb 12, 2009
mlapres
  • 757 Answers
SOURCE: This may not be an
If it sounds normal, then yes leave them as they are.
But there may need to be an exception made.
The distances are set the way they are for the proper advance or delay in milliseconds of the sound arrival at the listening position.
The system calibrated your speaker settings based on how each channel's frequency responses measured at the listening position. Room acoustics and channel positioning greatly affects this. The settings it made in the system can be a best case scenario compromise that MAY not be good for your surround speakers as it can be delivering signal to them that they were not designed to handle; in which case it is best to increase the crossover value of those speakers.
Posted on Mar 29, 2010
dunnbiker
  • 8546 Answers
SOURCE: Describe your Magnavox Stereo Mini
Yes.
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Posted on Apr 17, 2011
Radio sometimes works
Bad solder joint in the radio. Chips don't come back to life when they die. Something that has to be searched for after the radio is tore down.
Dec 05, 2015 | Cars & Trucks
Unit powers up, cd and radio seem to be operating properly, but no sound is heard, unit worked fine a few days before, all wires are conected, everything seems unchanged
Well...as you said...the unit powers up...so you don't have a "dead set".I don't know if the speaker can be disconnected from the unit.As a rule of thumb...it is very rare that both channels (left and right )fail at the same time...it is usually one channel while the other speaker still operates.This is what I want you to do...In a quiet room..get really close to the unit...Switch it on and listen for any sound from the speakers...get really close...you should hear a slight hum from the woofers and a high frequency "hiss" from the tweeters....If no sound is heard..switch the unit off..You should hear a "plip" sound...If not...switch it on again...you should hear a slight "bump" sound from the woofers...If you hear no sound from the speakers at all..there is a problem with the output stages of the amplifier section.If you do hear sounds fron the speakers,,Turn up the volume and watch for an increase visually on the display (such as ascending numbers).If there is no indication of a volume increase...The "mute" may be stuck on..Try switching it off and on...please let me know what happens after you do all the tests....Looking to hear from you......PEACE!!!
ok...
Jul 11, 2011 | JVC HX-Z3 CD Shelf System
I have an 1998 escort , i entered the radio code , the panel is lit and the search is working, although i raised the sound volume but no output sound , may i know why ???
Turn the VOLUME up to maximum.
Can you hear a noise?
YES?.....There is likely to be a problem with the radio
NO (Quiet) ...there is a problem between the radio and speakers ( loose connector , broken wire etc, blown speakers)
May 30, 2011 | Car Audio & Video
Unit is plugged in but no lights, no sound, nothing....can hear a slight pop in speakers when it is un-plugged
Bose Wave Radio/Cd. The radio has no sound, no lights just dead completely. No power. Just died on me one morning.
Dec 12, 2010 | Bose Wave Radio
Radio dose not work. its makes a fuzzy noise and is really quiet but i can still hear some music.
Sounds like the wire to the speaker is shorted outsomewhere, as if some sharp piece of metal has worn through the insulation somewhere.
Jul 06, 2010 | 2001 Chrysler Concorde
PA speaker quiet
Oct 22, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Sep 01, 2008 | Logitech X-240 Computer Speakers
Motorola Speaker
to dissamble this radio you have to remove the face panel, under this face panel ( the blue one) you will find others screws. first of all try if you have an audio accesorie, with this earbund or head set the audio must be normal or the same quality than the other one, if is not, the radio need quilified service. Good luck Ernesto
May 06, 2007 | Motorola Talkabout T5720 (7 Channels)...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
