Question about Motorola Mobility V551
Error messages I am having a hard time getting the phone to stay charging; two different messages come up- one says 'insert SIM card'- even though I have done nothing with it. The other sayd "unable to charge battery'. What gives?  Thanks
  • 51 Answers
1. Is there a SIM card in the phone? Is the SIM card from the same carrier/provider you got the phone from? Was the phone purchased as part of a plan or separately?
2. I see the not charging message a lot with my v551 that I had. I usually adjusted the inserted connector (after insertion) and 85% of the time, the phone recognized the power coming through.
If this fails, then try another power adapter. If after trying a new power adapter does not work, then the pins on the phone has sustained some damage.
Hope this helps :) Kindly leave a rating. Thanks..
Posted on Nov 27, 2007
Keep asking sim card
Does your phone shows "insert sim card " error even though the sim is in? As far as I know there are two possibilities to get this error message.One is poor signal of that respective network for which you just need to switch OFF and ON your mobile and the mobile will be able to receive the signal from near by tower.You may also get this error message when you are trying to insert a sim other than which the mobile is locked to.To solve this problem you need to unlock the phone from that particular network or use the same sim to which the mobile is locked to.You can unlock HTC phones using unlock code from any vendors online like
Mar 07, 2014 | HTC Wildfire Cell Phone
Insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Jul 30, 2013 | Blackberry Curve 8350i
Need unlock code for sony ericsson z550a for a tmobile SIM
Hi, If you get error message as PIN blocked. Unlock?" You have entered the wrong PIN code too many times. You need to unlock your phone using the PUK (PIN Unlocking Key) code. Your PUK code is provided by your network operator. If you get error message as Insert correct SIM" You have inserted a SIM card that is not supported. Insert correct SIM card, or contact your Service Provider for a SIM unlock code. If you get error message as Phone locked" or "Enter PIN" Your phone is locked and you need to unlock it with your personal PIN. The default PIN is '0000', but you or your network operator may have changed it. I Hope it helped you. Thank you for using ' Fixya ' and have a nice day!!
Nov 18, 2009 | Sony Ericsson Z550A Cellular Phone
Says insert sim card when there is one in it
"Insert SIM" message is normally displayed on phones when a SIM card is not inserted on power-on or it does not detect the SIM card inserted.
Likely Causes:
  1. No SIM card inserted or inserted SIM card is damaged
  2. Inserted SIM card not positioned well in such a way as to make contact with the corresponding contact bridges on phone.
  3. Phone locked to a specific network and can only work on other networks when the firmware version is "flashed", that is completely changed to an unlocked version.
  4. The phone might be faulty (try with another good SIM, if you still get thesame message and its not one of the above reasons... it might be a transciever problem or the phone's SIM card slot's pins might be defective).
Apr 30, 2009 | Sony Ericsson Walkman® W880i Cellular...
Insert SIM Card message in nokia 6080 though SIM is inserted
May be its detecting your sim card properly. Check your sim card in another handset. Verify if its the propbelm with sim card not your handset.
Nov 26, 2008 | Nokia 6080 Cellular Phone
I can't insert other sim cards from this certain network
Sounds like the phone hasn't been unlocked properly. I had a similar problem and eventually just changed my sim to the original phones network. This solved all problems but i don't know wether this is the full solution to your issue. I tried to help best as though dude.
Nov 25, 2008 | Samsung SGH-G800 Cellular Phone
Insert SIM Card
make sure the sim card can make good contact with the phone.
Also check if it doesn't have space to slide, causing it to loose contact with the phone.
Mar 27, 2008 | Nokia 6270 Cellular Phone
Nokia 6230 insert sim error
Insert sim error could be a problem with the sim card contacts, check if the sim card is locked properly and connections are all clean.
Jan 30, 2008 | Nokia 6230
Insert SIM Card
My phones displays the message Insert SIM Card even though it has the SIM Card.
Oct 30, 2006 | Nokia 3200
Motorola Mobility V551 Logo
57 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
