Fuji FinePix V10 Digital Camera Logo
Posted on Aug 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lines on screen and photos, too bright photos outside
Camera was dropped
david
Level 2:
  • Expert 244 Answers
  • Posted on Aug 07, 2009
david
Expert
Level 2:
Answers
244
Questions
Helped
86331
Points
810
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Too bright when photos taken outside. and lines in the photos
you have a defective ribbon (broken) wire connecting the internal lens that is why you are getting greenish lines when taking outdoor shots or too bright subject.
Unable to take photos
Your camera is having horizontal lines due to a faulty CCD, and not due to other problems.
Just tap on the side of the camera at times the horizontal lines will disappear.
If the problem is due to your dropping the camera, you might be out of luck.
If you have not dropped your camera and still facing this problem, then contact service people to replace the CCD imager in your camera .
Hope this helps .
1helpful
LCD screen and pictures go completly white
The camera is defective. But as you've only had the camera three months it still is under warranty. Canon is usually very responsive to these type of problems and will bend over backwards to make things right (probably the most responsive of the camera companies).
Call 1-800-OK-CANON to resolve this issue.
1helpful
Casio exilim ex-z700
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
Can't repair by yourself.
It's need repair camera machine shutter.
more detail CASIO Exilim EX-Z700 overexposure
Bright glare lines when taking photos outside
both actually,
my advisor says we are just going to send it in to the shop, thankfully we have a warrenty. however, we need to have a detailed service report so any ideas for things to check?
thanks
central stampede
4answers
Pictures with White Lines
Same problem with mine!  Fine Any suggestions?
Photo quality
send it back- it should not be like this Get onto Panasonic web site technical support team Should be in the Manual
2helpful
White streaks on all photos but not video
Your camera has a defective CCD imager. Please return the camera prepaid to Canon in New Jersey, they are replacing the CCD at no charge to the customer. This is a known issue and is resolved by many of the manufacturers using the Sony CCD element in their cameras at no charge. Good Luck my friend. Joe Weibel customelectronics.org
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
