Question about Car Audio & Video
VM3LC 3 BAND BASS EQ layout dpwiring diagram - Car Audio & Video
SOURCE:
SOURCE: bass frequncy
Also bear in mind those are crappy eq's in that zoom, personal recorders are great but aren't known for pre-amp and eq quality, etc. If you're recording at proper levels and with no eq and there's no clipping on playback either then I would say you may be tweaking the eq more than it can handle when you use it. Try not boosting freqs so much, generally anything over a 6db. boost is drastic, especially with the lousy Q of cheap eqs. Try attenuating highs instead of boosting lows so much, I'm afraid yer just gonna have to live within the limitations of the equipment or get an outboard eq in front of the D.I. box and eq it during tracking or get an external recorder for mixdown and put the eq between the zoom and mixdown recorder and eq during mixdown. Here's a little trick that may help - when mixing turn the volume way down low for a minute till you can barely hear it then turn it up a bit more and see if the balance of the highs and lows is good, it will give you a general balance wich will sound good at higher levels. Volume level when mixing affects the way we hear, the frequency response curve of the human ear is totally nonlinear, we hear freqs differently at varying levels, mix too loud and it will tend to be bass light, mix too low and it will tend to be bass heavy, the fletcher munson equal loudness contour curves wich express the ears frequency response graphically, indicate that the nearest to flat response is at 85 db. spl
Posted on Aug 06, 2008
XSdB
  • 80 Answers
SOURCE: best settings on a 9 band eq for rock and r&b
Provided the rest of your system is all tuned an in proper shape, and up for the wattts, the best sound to set, starting with the low end...start with is a slightly elevated above zero (about 1/4 up from zero) then slowly gradually slope it down to 1/4 below zero in middle and then back up to 1/4 above at the high end.
The result is a gently curved V type shape.
Now, knock down the highest 2 or 3 freq bands a few clicks till they are just above zero. (1/8).
This is the curve you would shoot for with a real-time analyzer for SQ, punch and clarity.
Posted on Jun 12, 2009
Ganx
  • 113 Answers
SOURCE: KENWOOD 9-BAND EQ DOES NOT POWER ON
Hi try earthing the chassis of the unit as well to ground with a wire. Sometimes units have to grounded all round. Check the inline fuses also to be sure
Best of luck
Posted on Jul 25, 2009
rteemon
  • 578 Answers
SOURCE: best settings on a 13 band eq for rock and r&b
THAT IS BASE ON HOW YOUR SYSTEM IS SET UP MY FRIEND ADJUSTING ALL THOSE SETTING WONT GIVE YOU MORE BASS
Posted on Aug 07, 2009
budmrtn
  • 11361 Answers
SOURCE: where are the bass,treble,mids,high on a basic
Bass will be anything below 300Hz, mid will be 300Hz to 5KHz (Voice), above 5KHz will be Treble.
Posted on Nov 01, 2009
My head unit resets settings when key is taken out
Do you have the yellow wire going to a constant 12v power source? The yellow wire controls the memory of the radio and needs to have 12v going to it at all times, even when the key is taken out of the ignition.
Jun 28, 2012 | Pioneer DEQ-9200 3-Band Car Equalizer
How to wire it to make the bass cuts off when offing the eq
This unit has a separate EQ band for the subwoofer-- you'd connect the sub-out from your CD player to the sub input on the EQ, and the sub-out from the EQ into the input on the sub amp.
The "sub" slider would then adjust the sub volume.
If your CD player doesn't have a sub-out, and you are just using one of the regular front/rear outputs to feed the sub amp, then the sub volume will follow the other sliders toward the left side of the unit, which is less desirable.
Feb 13, 2011 | BOSS AUDIO SYSTEMS AVA1204 7Band Car...
Need wire diagram for pioneer eq-6500
Pioneer EQ-6500 9-Band Car Equalizer .i want to buy this equaliser.i need 10 pieces ,please send me through my email febiano22@yahoo.com
Nov 24, 2010 | Pioneer EQ-6500 9-Band Car Equalizer
No sound. loose wire or need new computer chip for it
Most common problem is depleted battery.
Use only akaline battery as rechargeable ones have lower voltage.
May 14, 2010 | Music
Where are the bass,treble,mids,high on a basic EQ.I have an 12 band stereo eq.what #'s are the bass,etc.
Nov 01, 2009 | Audio Players & Recorders
Best settings on a 9 band eq for rock and r&b
Feb 11, 2009 | Kenwood KGC-6042A 9-Band Car Equalizer
Best settings on a 13 band eq for rock and r&b
Feb 11, 2009 | Kenwood KGC-9044 11-Band Car Equalizer
Cannot Set the Treble & Bass
I have an Alpine 9887 you have a different eq than just trebel and bass the only way to get you bass an trebel setings are to install the imprint stoftware now if thats the route you go it tunes your radio to what it thinks it should sound like it's for sound quality not for alot of bass been there done that I have the software but you need to take it to a good alpine dealer to have it installed good luck
Jan 05, 2008 | Alpine CDA-9887 CD Player
How can i get my power to my EQ?
What kind of eq is it? First thing I would do is hook up the +12 and GND to the same place the amp is hooked up. I think the eq is having a hard time getting ample current, therefore shutting off all the way when the bass hits. Caps are good, but second battery and battery isolator are far superior.
Dec 06, 2007 | Clarion EQS746 Equalizer - 7-Band In-Dash...
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
