Question about Kenmore 44102 Front Load Washer
It will not spin
I have a he 3t kenmore When ever I go to put it on a spin cicle it will not do it. A code number f 20 show up, and it makes a peebing sound. This is the first time i've had this problem. What do u think might be the proper solution to thim provlem
  • 1,294 Answers
Your filter is clogged with muck or whatever, refer to manual & clean it out. Would be good if you emptied out pockets, etc before loading clothes into machine.
Pl. rate if helped.
Posted on Jan 13, 2008
Cycle will not spin and drain properly near end of cycle. Keep getting F11 fail codes when I try resetting my kenmore elite HE 3t any suggestions?
Hi Shaun, I just found (and watched!) a good youtube video which may help with your problem regarding the F11 code, link follows below.
Trust this helps, best regards Alan
Troubleshooting and Repairing the F11 Error Code in Whirlpool Duet Washer
Feb 12, 2015 | Kenmore Washing Machines
Kenmore Elite HE 3t steam washing machine shows a code of F71
The F71 error code means "User interface heartbeat failure" to put that in simple terms what it means is,the touchpad/cycle selector is not talking to the main control board. To check to see why that code is being displayed ya would need to make sure that all the wire plugs between the selector and the control board are tight and in fully pressed in and making good contact at the respective connection point on the circuit board.
If ya find the wire connections to be good and tight,ya would need to start the washer and if the drum rotates the cycle selector would have to be replaced. If the drum does not rotate the main control board would need to be replaced. oldtech2332_146.jpg
Oct 20, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore h2 error code
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore 46462 Front Load Washer
He 3t error code f6,washer will not spin,door will not open
"f6" error code means that there a miss communication between mcu(motor speed control board) and ccu(central control unit). i recommend you to ohm out the motor. most likely its your motor speed control located at the bottom left of the washer good luck. replace the motor speed control board and you should be all set to go.
May 09, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Error code 32 on a brand new Kenmore HE 3T wash machine
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Getting an F 02 error code with my Kenmore Elite HE 3T
Your filter on your pump is probably clogged with lint and other stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels and unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Mar 22, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE 3t started leaking from the side when filling
check dispencer and make sure its not cracked,,if not turn your water pressure down to the dispencer its splashing up and over running down..keep me posted onthejob
Jan 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 44102 Front Load Washer Logo
Sal De
 Brian Main
Brian Main
