Question about Motorola Mobility i850 Cellular Phone
I850 stopped responding
My phone display did not come up when i opened it, it would not turn off, i removed battery, waited a few minutes, replaced it, and now all i get is i850
  • Anonymous Dec 21, 2007
    Problem Solver:
  • 26 Answers
Have you recently submerged or heavily wet your phone? Your phone has two flex cables with micro connectors that can be easily shorted by liquids. This requires disassembly and cleaning by someone with expertise. Assuming it has not been subjected to fluid contamination proceed as below.
Ask someone with a known to be operating Nextel or Boost Mobile phone to allow you to boot their phone with your SIM installed.If it boots normally, it is not your SIM. Use a sponge make up removing tip, like a Q-tip but with a sponge end, and clear alcohol to clean the SIM, as well SIM contacts in the phone, fully charge yours or use a fully charge substitute battery, and then reinstall it in your phone. If it does not power up you may be experiencing partial flex cable failure. You have to keep your phone away from devices that create magnetic fields like speakers and TVs.
Posted on May 08, 2008
    New Friend:
  • 133 Answers
Your Code lug may be corrupt you have to ake your unit to a serivce center for repair sorry
Posted on Dec 05, 2007
My CAssette reverse airconditioner wont respond to remote. Changed batteries worked 2 times then stopped
It's transmission error. Please remove batteries from remote.Remove power for a/c. Remove Dc wires plugged into indoor display sensor. Wait for 5 minutes. Now replug DC wires. Reset batteries in remote. Power on, Check now.
If still problem, check remote thr' mobile camera and press any button in remote. If you could see thr' mobile camera the ultra light in remote, it's o.k. Then you have to replace PCB of indoor. If no ultra light, replace remote.Thanks.
Feb 02, 2011 | Heating & Cooling
It says subsidylock i need to enter a special code
i have the motorola i850 cell phone, and this problem occured on my phone
after entering the wrong code a few times, a message appeared on the display
to wait to enter the code, after about 30 minutes, the enter code screen reappeared
so from this point i turned the phone off anf then back on again and that unlocked the phone
i received the welcome screen and the phone was up and running again hope this help you
Sep 12, 2010 | Motorola Mobility i850 Cellular Phone
I have a SKPE Phillips phone VO1P8411B/37. In an effort to fix the phone I de-registered it. When I select REGISTER, it comes back with 'Registration failed'. I tried to put in the default code of 0000...
Firstly, unplug the base unit, then remove from this base unit the ethernet cable and most importantly, unplug the telephone line! Then remove the batteries from the 2nd handset. Keep everything unplugged for a few minutes, then plug the power into the base unit, wait 1 minute, then plug in the Ethernet cable and wait 5 more minutes. Do NOT plug in the telephone line just yet. After the 5 minute wait, put the batteries back into the 2nd handset and then follow the registration instructions from the manual (copied below)...
Make sure you have configured the language, country code, and area code of your
phone before registering additional handsets.
1. Press "Reg.". Register shall be highlighted.
2. Enter the system PIN (Default: 0000). Use "Clear" to correct typing errors.
3. Press "Enter" to confirm.
• Your handset starts searching for the base.
4. Press the top button on the base unit until the two indications turn off.
• If registration is unsuccessful, the signal icon displays steadily.
Like other methods, you must hold down the button on the base unit until the lights STOP blinking. When you have successfully registered your 2nd handset, then plug in the telephone line into the base station. I did the above and it worked! The trick is to be patient and wait the few minutes while everything resets itself.
Aug 05, 2010 | Philips Lands Phones
My Canon i850 printer has stopped responding to a
The Canon i850 uses cartridges of type BCI-3. according to Canon, the color cartridges are compatible to:
BJC-3000 Series, BJC 6000, i450, i550, i850 Series, MultiPASS F30, F50, F60, F80, MP 700 and MP 730, S400, S450, S500, S520, S530D, S600, S630, S630 Network and S750.
The black one will work in a few more models.
Feb 07, 2010 | Canon i850 InkJet Photo Printer
I want to know how to format my nokia 6600 cellphone manualy will you pls help me?
Since you want to format the phone you can follow this steps in doing that:
Method One
Verify that your phone does not have a discharged battery. Charge phone until battery icon shows a full charge.
Save all personal information to the MMC memory card. Turn off the Nokia 6600 and remove memory card.
Simultaneously press the green dial key, the "*" key and the "3" key. Continue to hold those three keys while turning on the phone. Do not release the three keys until the formatting message is displayed on the screen.
Wait for a few moments while the phone reformat. Once completed, the phone will be restored to fresh out-of-the-box store defaults.
Reinstall personal information from the MMC memory card.
Method Two
Verify that phone does not have a discharged battery. Charge phone until battery icon shows a full charge.
Save all personal data to a removable memory card. Turn off phone and remove memory card.
Turn on phone. When phone is fully powered up, key in the following sequence, "#7370#". Answer "Yes" when phone asks if you really want to format phone.
Enter pass code "12345" when the Nokia 6600 asks for the confirmation code.
Wait while phone reformat. The process may take a few minutes.
Replace the memory card and restore personal data.
Jan 27, 2010 | Nokia 6600
Load default Delta file message
Problem My handset displays either LOAD DELTA FILE or LOAD DEFAULT DELTA FILE. What should I do?
Solution(s) Tip 1 of 2
If the handset is not responding normally, you may need to reset your telephone system. Complete the following steps to reset the telephone system:
Step 1: Disconnect the power to the telephone base.
Step 2: Disconnect the handset battery.
Step 3: Wait a few minutes and then reconnect the power to the telephone base.
Step 4: Reconnect the handset battery
Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again.
Nov 16, 2009 | AT&T 650530003417 Cordless Phone
Phone is frozen i850 My i850 freeze on the i850 screen when i first turn it on...HELP!!!
If it freezes at the i850 splash screen it is most likely a fatal failure. The defect is board level and can not be recovered. You either need to replace the phone or get another motherboard which, are not available separately- you will have to find a used one with a good board. I am a technician for Nextel and so far none of us have been able to resolve this issue.
Feb 04, 2009 | Motorola Mobility i850 Cellular Phone
Go to where you bought it and tell them the problem they might supply you with a new phone if you have a warrany with that phone hope that solves the problem.
Nov 07, 2006 | Motorola Mobility NEXTEL i850 Flexible...
Motorola Mobility i850 Cellular Phone Logo
50 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
