Question about Microsoft Xbox 360 Console
360 not starting....
Hi my 360 is currently not working.My console had the three red lights and I tried the "eraser fix" but that didn't work. after that I tried to replace the thermal compound on the motherboard and then when i started up the console the fan started going and i had the a green light but then suddenly after like 5 seconds everything shuts off. Nothing works, please help me!!
    Problem Solver:
  • 18 Answers
Ok you could try this
what you need is two towels just normal bathroom towels take everything out of your xbox e.g harddrive,controlers etc only things to leave in is the av cable and power supply as you wanna turn on the xbox lie a towel flat on the ground and lie the xbox on its side ontop of the towel turn the xbox on, you will see the error message and the red lights flash. wrap the towel around your xbox covering the air vents and then the 2nd towel put over the top. leave it on in the towels for about 20 mins then after that take all the towels off turn off the console and leave to cool down for 15 mins. turn the xbox on and it should restart again fine but only lasts for a couple of days then you have to do it again. wont fix it but will let u play while microsoft gets it.
its only a temperory fix you may need to contact microsoft
hope this help please rate me
regards grant
Posted on Nov 27, 2007
I have problems with my Xbox 360 everytime i turn on the 360 there is a red circle. I tryed to fix it but it just won't work anymore how do i fix this Problem
Is there three red lights???? or a complete circle???? Three lights is the red ring of death. Four red lights or a circle is either a bad a/v cable (try a different one) or a bad hard drive....(try taking it off of the side when power is off then turn it on.).
Nov 14, 2010 | Microsoft Xbox 360 Console
When console is turned on, three lights flash
If you are currently experiencing the Xbox 360 3 Red Lights error, more than 30% of all Xbox 360 consoles have been or will be affected by this error, which occurs due to hardware and heating problems. Sometimes the excessive heat will cause the soldering to become loose. This affects the graphical processor and can lead to major hardware damage. The 3 Red Light error is an indication that there is probably a fault in the cooling system. You can add an additional inter cooler and remove the X clamps.
If this doesn't work you can send your Xbox 360 to the Microsoft service center: this is a good solution only if your console is still under warranty, because if it's not Microsoft will charge you $140 plus shipping to make the repair. If your warranty hasn't expired then you can have your gaming system repaired for free. The only downside is that you might have to wait 4-12 weeks to get it back.If you try to fix it by yourself, the first thing you need to do is to switch off your Xbox immediately. Excessive heat is what caused the problem, so you need to bring the temperature down quickly. Allow you system to cool down for a few minutes and then restart it. Please avoid using dangerous methods such as the "bath towel technique". The idea behind it is that wrapping your console with a bath towel will heat it even more and realign the soldier joints of the motherboard that have become loose. This won't work because to fix this problem you will need to reduce the temperature and not to increase it.
Thank you !!
Jun 28, 2010 | Microsoft Xbox 360 Console
My xbox 360 has three blinking red lights and it wont work at all
Just do a google search for the rrod. There are many helpful sites and tutorials to walk you thru fixing it. If it is still under warranty I would have xbox fix it for free. I believe they have extended their warranty to three years on defective xbox 360 consoles. If your out of warranty though, you may want to try one of the fixes. I had to do the x clamp fix to get mine going again. Good Luck!
Aug 03, 2009 | Microsoft Xbox 360 Console
Well when I turn on my xbox 360 the third part flashes red.
hello.
CAUSE The three flashing red lights may indicate that your Xbox 360 console has experienced a hardware failure. Please read the letter that discusses warranty changes for three flashing red light hardware failures.
MORE INFORMATION
If you suspect that you are experiencing this issue, you can submit a console-repair request online. However, before you submit your request, we ask that you first try the following two steps to verify that you are indeed experiencing this issue:
1. When you turn on the console, examine the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps that are listed in the following Microsoft Knowledge Base articles:
906101 Xbox 360: The power supply light is red 906102 Xbox 360: The power supply light is orange 906103 Xbox 360: The power supply light is not illuminated
2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the symptom occurs again. If your console continues to display the three flashing red lights, your console may have to be repaired. For information about how to start the repair process online, please visit http://www.xbox.com/support, and then click Console Repair in the upper-right section of the Web page.
Note: The online console repair service is currently not available in all countries or regions.
If you would rather contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact for information about how to do this.
APPLIES TO
* Microsoft XBox 360 Video Game System
* Microsoft Xbox 360 Hard Drive (20 GB)
* Microsoft Xbox
Apr 27, 2009 | Microsoft Xbox 360 Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
Blinking Red Light
If you have two red lights blinking, that means that the A/V cable is not securely inserted either into the Tv or the console. If you have three red lights, this means you have a hardware failure, and willl need to contact microsoft for free repair. If it is one light, it is just an error and should subside by restarting the console.
Apr 04, 2008 | Microsoft Xbox 360 Console
Three red lights
http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm
Unfortunately, a large number of folks know all to well from their own experience. Fortunately for those who have not opened their console for any reason Microsoft has extended the warranty of ANY console experiencing the 3 red lights failure for a full three years from the manufacture or purchase date.
Jan 08, 2008 | Microsoft Xbox 360 Console
360 issues
Two Red Lights
The two left quadrants of the Ring of Light flash red on the front of the Xbox 360 console
This behavior occurs when the internal temperature of the console exceeds the acceptable limits. You may think of this as too hot, overheating, and so on. Make sure the fans are operating and the system has adequate ventilation.
Since you've been inside it's possible that a heatsink or some other part of the cooling system is not working properly or is loose. Check all these!
Good Luck!
Nov 17, 2007 | Microsoft Xbox 360 Console
Eraser fix not working!!!!!!!
2 Flashing red Lights - Your unit is overheating
  • Let your Xbox 360 console cool.
    You may have to wait several hours for the console to cool enough. Do not turn on the console when it is still hot.
  • Make sure you can hear the fan running, also make sure you are not blocking the console from getting enough ventilation.
  • Do not lay your console on heavy carpet or in a confined book case or shelf
  • If you CPU is overheating you could replace the thermal compound. See the manual before you attempt this. The compound can be purchased at any radio Shack or electronic store.
For more things to try check here
Nov 09, 2007 | Microsoft Xbox 360 Console
X box 360 system crashes
microsoft have extended theyre warrenty on xbox 360consoles to 3 years with the ring of death problem... so microsoft shuld fix it free of charge just bring it to wherever you bought it and they should take care of it.
Aug 27, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
65 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
