I have a cub cadet LT1018, replaced the hex flange bearing, pinion steering gear and some plastic bushings. Now the mower won't start or crank. I checked the 20amp fuse -good; replaced the battery with a new one and still the same thing - WON'T Start or crank. Any ideas on what could be the problem?
It might be a saftey problem. But before you start changing swithches or whatever try this. If you have to lift a lever to engage the PTO for the blades try wiggling it up and down a little bit while sitting on the tractor and the brake pedal depressed and turning the key to start it.
Sometimes there is a little wearing and it won't be in the right spot on its own.
Good luck and let me know if this helped.
roundo4
