Question about JVC Audio Players & Recorders
My jvc home theater say protect..what must I do to remove that protect?
  • JVC Master
  • 584 Answers
Hello Velile, indicate the model of your Home Theater JVC, to find the best possible solution
Try disconnecting your JVC from the socket, then check that the cables that go to the speakers are well, that they are not peeled or shorted, after checking, reconnect and see if you are still in Protect
If you continue in Protect, I suggest you contact a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Velile, indica el modelo de tu Home Theater JVC, para poder encontrar la mejor soluci?n posible
Prueba desconectar tu JVC del toma de corriente, luego revisa que los cables que van hacia los parlantes se encuentren bien, que no se encuentren pelados o en cortocircuito, despu?s de revisar, vuelve a conectar y f?jate si sigue en Protect
Si continua en Protect, te sugiero te contactes con un servicio t?cnico especializado
Espero Puedas resolver el problema
Saludos Franco Dosil
Posted on May 21, 2019
4 Suggested Answers
SOURCE:
ginko
  • 19396 Answers
SOURCE: sony home theater system started blinking protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
  • 65 Answers
SOURCE: i have a JVC, Home Theater system. It is a TH-C30.
I think there may be a possible chord disconnected or the fuse may be bad!
Posted on Apr 26, 2010
dunnbiker
  • 8546 Answers
SOURCE: I BLEW UP MY DVD JVC SYSTEM AND I HAVE HOME
You mean EXTERNAL? Probably, but without exact details regarding what you have that's still alive, only you could tell.
Posted on Feb 22, 2011
Getting tv sound from home theater speakers
Connect your sound from the cable box out to the JVC theater audio in jacks. This will give you sound through the speakers.
Jan 29, 2014 | JVC TH-C50 System
R5002 resistor value for JVC XV-THD60 Home Theater
Why don't you read the color code? Assuming it's got bands of color painted on it.
Nov 12, 2013 | JVC THD-60 System
What do i do if my jvc home theater system can turn on when u press hte button then it immediately turns off.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Feb 20, 2011 | JVC THG31 Theater System
Jvc thc 30 wont power on
http://www.retrevo.com/support/JVC-TH-C30J-Home-Theater-Systems-manual/id/318ci572/t/2/
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 16, 2011 | JVC TH-C30 System
How do i fix a jvc stereo when it says protect?
Output amplifier failure. Take it to service shop.
Nov 01, 2009 | JVC THS55 System
Protection apears on power up then shuts down??? a fuse or something i can repair?
When problem accures in Amplefier section, protection actviates to protect speakers and further damage in unit. I think, Amp got defective in your system and needs qualified service person.
Jul 22, 2008 | JVC TH-A25 System
How to unlock protected mode on a jvc 5 disc cd changer?
cheack the speaker wireing.if thats not the pro i sugg the repair shop your unit could have over heated.
Jan 06, 2008 | JVC HXD7 5-disc Home Stereo Theater System...
How do i switch a jvc home theater system from pal to ntsc. model # rx-dv3sl
How do I switch a JVC home theater system from pal to NTSC.
Please e-mail this information to (shamarmec@yahoo.com)
Best Regards
Sharie
Dec 18, 2007 | JVC THC3 Home Theater System System
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
