I used the settings recommended Power on, Open the drawer, key in 9879 slowly, pause for a 3 second delay then type 0, all via the remote and a message appeared on the screen saying Region Code now set to 0. I can now play Region 2 and region 1 DVD.
Re: Trying to reset Region Code on Toshiba SD290EKB
I used the settings recommended Power on, Open the drawer, key in 9879 slowly, pause for a 3 second delay then type 0, all via the remote and a message appeared on the screen saying Region Code now set to 0. I can now play Region 2 and region 1 DVD. Well done and thanks for all the hard work. God bless. Be encouraged. The truth is out there!
REGION UNLOCK CODE When i
bought this it said multi-region but its not. To unlock it to play
all regions turn on the dvd player open the disc tray and then enter
98790. It will now change to region 0 making it able to watch all
regions.
Hope that helps.
1) Connect to TV 2) Power on DVD 3) Enter 7777 using remote 4) Use on-screen menu to change region code (region code 0 = region-code free) 5) Power off DVD
The DVD is now region code free.
or
The Hack Procedure: - Power On - Open Tray - Press 9879 0 (0 stands for Multiregion, you may press buttons 1 to 6 to choose a specific region) - A Message appears stating that "The Reg.No was changed to: [insert whatever region (0-6) you selected here]"
That's all, now you can watch every DVD you please... :)
or
Additional Information: To get further info on your player do the following: - Power On - Open Tray - Press 966 - This should show a screen listing RC, Firmware- and OS-Version, Manufacturer Label, etc.
or
or
1. Turn Player on with no disc inside 2. Set the Unit to DVD mode (Not VHS) 3. Turn Player OFF 4. Turn Player on with no disc inside 5. Press pause on the remote control 6. Then key in 3 1 4 1 5 9 [CODE -- will then be displayed on the player display] 7. Key in desired Region number [0 for Auto Multi Region, or manually select 1 to 6] 8. Then Press Pause again 9. Turn off player and wait 5 seconds, then back on again.
- Power ON - Open Tray - Enter Cod : 9879 and 0 For All Region Free ( For A Few Seconds In Uper Right Corner Will Appare : { Now Your Region Is Set To " 0 " } Or Some Thing Like That) - Close Tay - Power OFF - Power ON
Try this it should work ok in making this player region free so you can play any dvd's.
1. Power on, 2. Press "Pause" || 3. Enter "314159" 4. Press "0" (for region free) 5. Press "Enter" ... the 0 replaces the previous region number in the second line. 6. Press "Pause" || 7. Power off.
Or
With the unit in DVD mode and the drawer open, key in "0" four times. A two line menu appears with "Edit Region:_" and "Region Code:x". Key in the required region (presumably 0) and press enter. Power off
Tops! It does work! I specifically bought this LG to replace an old LG which was easy to set. The open tray is critical as is waiting about a second between the three '0' key pushes. You will get the region code test screen on the TV.
Re-cap:
1. Open DVD tray
2. Press the '0' key on the remote three times, waiting about one second between key presses. The 'Region Test' screen will appear on the TV. If you don't get this screen, then power off/power on again and start over.
3. If the Region Test screen appears, enter '0' for all-regions.
4. Press pause to save and exit.
1. Open the tray
2. press the following sequence using the number keys: 98790 (this
is equivalent to the code 9879 with the zero at the end representing
all regions)
3. Press Close Tray - there should be a sign on the TV screen saying something like 'Region set to 0'
4. Turn off the DVD player for 5 seconds
5. Turn on the DVD player.
