Question about Philips 43PP9202 43" Rear Projection Television
Picture get blurry on right hand side
The picture look like it tips inwards on the right hand side of the screen. I went through all the menu option on the remote but non helped.
Is it rear projection? if yes try to open the front screen panel, there is a mirror inside which reflecting the picture from RGB Projecting source onto the scren. In same case the mirror is unclear, very dusting, try to clean the mirror use glass cleaner then look at the screen it should be same as the mirror full of dust, clean it too and the last there are 3 projecting unit ( R G and B) as the picture source clean the lens with glass cleaner
regards
agungale@plasa.com
Posted on Oct 10, 2008
I have a 55 inch Philips/Magnovox
The Picture is blurry and the color isn't sharp
How do i fix it
thanks
Posted on Sep 26, 2008
    Problem Solver:
  • 16 Answers
If the convergence is also off suspect convergence ic problem
Posted on Dec 27, 2007
Why is the picture on my Sony KDL-55HX729 blurry? The right side of the screen is light and blurry like its in slow motion and retains the previous screen picture, it fades after a few secondboard may
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 19, 2014 | Televison & Video
Blurry Picture
I know these models came out around 2001, and I'm afraid that the problem sounds like it is related to the bulb going bad.
This article outlines how many TVs from around the turn of the century have had similar problems to yours.
I know bulb replacement is an option. You may want to call around to TV repair shops and see what your options are. In the end, though, it may be time to start saving up for a new TV.
Jan 31, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Lines are bowed at top and bottom,picture is blurry
Is the convergence option still listed under the on screen menu setup options, or has it disappeared?
Jan 22, 2010 | RCA R52WH76 Television
The picture started to get blurry, after being turned on for 10 minutes would clear up, now just stays blurry and almost no picture at all.
Hi
Thanks for using FixYa. To reset the picture you’ll need to reset all the Video menu options to their original factory setting for which you’ll need to follow this step-by-step procedure---
Press the Menu button and then use up or down arrow button to select the Video menu. Now press the right arrow button and then use up or down arrow button to select Video Reset then press the right arrow button to reset the Video menu options to original values.
If still the problem persists, then you’ll need to check for local interference such as an electrical appliance or power tool and also check the antenna. If required change the direction of the antenna.
To resolve the issue of Blurry Screen, first check whether all the cables from your dish network are fine and connected firmly. If yes then you'll need to pull off the front of the TV, behind the speaker grill there would be a panel. Remove the panel and check for a black box hanging over there. It has 6 controls on it, 3 are marked as focus and 3 as screen. You'll need to adjust the screen. If you turn these too high you can damage a tube. So we are doing real small adjustments. Turn the color off on the TV and adjust the red, blue & green controls up till you get a fine picture. Also adjust the focus until you get a clear picture.
And, if it doesn't resolve your issue then it is an intermittent blue picture tube, a bad blue driver transistor on the CRT board, a bad connection on the blue CRT board, or a problem in the RGB coming from the video jungle IC. A set this age, most likely will run about 300-500 bucks to have this problem fixed, unless it is the picture tube.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 18, 2009 | Televison & Video
Picture not clear
CONVERGENCE problem.. with convergence problems on these sets i always start the diagnoses with some questions. IS the picture curved in at top and bottom? or is it just in certain parts of screen. Go to setup in cutomer menu do you have the convergence option in the menu. if you do not try reading the fl231 fuse problem in the tips and tricks section of this website. that is a simple and inexpensive repair. if you do have the convergence option then you may have a problem with one of three different cuirit boards
Apr 03, 2009 | RCA R52WH73 Projection Television
How do I adjust the picture to fill the screen
i was having problems in the tv menu getting full screen. no matter what i did there was two black bars on each side of the screen. i have att u verse so i went into the cable menu to options. In the options tab i went down to system options then to aspect ratio. in this screen you get a few options like 4:3 standard definition and 1080i on high def screen. I chose 1080i high def and then played with the zoom function on my remote and the problem was solved. hope this helps
Nov 19, 2008 | Insignia LCDTV26 26 in. Television
Samsung Digimax s500 Camera takes awful, blurry pictures!!!!
You can try adjusting the exposure compensation, quality of the picture.
Just press the +/- button on the right side of the screen.
For the Macro mode, just press the flower button on the bottom part of the Menu/ Ok button.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
The screen picture bulges inwardly on the right and the left
you have defective horizontal linearity! replace the capacitor at the hot side mostly 160uf 180V or 160uf 160V.
Oct 02, 2007 | Recoton Advent Advent Q2035A 20" TV
Philips 43PP9202 43" Rear Projection Television Logo
413 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
