Question about Toshiba 65H81 65" Rear Projection Television
No Sound I have a Toshiba 65H81 RPTV. I have always used my surround system for the sound, so I never really used the internal speakers on the TV. I tried to hook my kid's Wii up to it using the RCA jacks on the front panel, and I could not get the sound to work. I took the TV apart a year or so ago to clean the lens, mirror, etc. and then performed the detailed convergence using a grid. It is possible that I disconnected the speakers somewhere and failed to re-connect them. I've looked for a loose connector, but I don't see one anywhere. Does anyone have any ideas? Thanks in advance.
  • 1 more comment
  • srrobinson2 Nov 28, 2007
    There is not a button on the back, and the speakers are definately enabled in the menu.
    Do you know how to reset the TV to factory defaults in the service menu? Maybe that would fix it.
    Actually, I have the service manual and the schematic manual, but I can't find any settings to enable the audio in the service menu. I was concerned that when I performed the convergence process that I might have accidentally changed a value somewhere along the way which disabled the audio, but I can't find any reference to such a setting.
    thank you for your assistance. My problem actually turned out to be pretty simple. You were right with your first post about a switch on the back of the unit. It is labled "Center Channel Audio Input," which I am not using, so I did not pay any attention to it. Somehow the switch had gotten moved into the "ON" position which disabled the sound inputs. When I moved that switch to the off position and connected a regular DVD player to the front panel inputs, everything worked perfectly.
    This is a great service, and thank you again for your very valuable assistance!
  • 298 Answers
There may be a button on the back of the set
to turn interan speaker on and off
if not then in the sound menu
check that out if that dont do it
get back to me
Posted on Nov 27, 2007
  • 1 more comment
  • Eugene Merritt Nov 28, 2007
    try this link for the manual
    1.Surround sound off
    2.spray head cleaner dab alcihol on rca
    plug run the in & out a few times(any static)
    3.hook up a vcr to the front panel switch to
    video insert the video cable in one of the audio
    jacks you should hear a hum if your audio out
    is working
  • Eugene Merritt Nov 29, 2007
    Your're Welcome glad to be of service
No sound coming from internal speakers Toshiba Projection television Model 50h82.
Some TVs have a set up option to disconnect internal speakers when an external audio amplifier will be used.
Dec 29, 2016 | Samsung Audio Players & Recorders
Sound output to a sound bar
Most TVs have a menu setting that says internal or external speakers.Here are the instructions for yours.
Turning off the built-in speakers Use this feature to turn the TV speakers off when you connect an
audio system (see "Connecting an audio system" on page 11).
To turn off the built-in speakers:
1. Press MENU, then press x or • until AUDIO menu appears.
2. Press y or z to highlight SPEAKERS.
3. Press x or • to highlight OFF.
Feb 16, 2014 | Toshiba 36HF71 36" TV
Sentry 2.1 surround sound speaker system. i have my rca cords plugged in to my tv, but i only get sound from my tv, nothing out of the speaker itself. it only works when i have my headphone jack into
Most televisions have a setting that controls whether the TV uses its internal speakers or sends the sound to the audio out jacks for an external amplifier or speakers.
Try going through the settings menu and follow through the audio/speaker selections and confirm that the TV is set to use external speakers.
Best Regards,
Sep 01, 2017 | Televison & Video
Sound is not working. everything is plugged in right. got the tv from my father-in-law who always had it hooked up to a receiver box. now we have it and dont have a receiver box and are unable to get any...
it sounds like the internal speakers are just off. you should be able to navigate the menu and find where to turn the speakers back on. i have my tv set up with a surround sound system and turned the internal tv speakers off. should be in the sound settings or with a picturre of a speaker.
Dec 24, 2010 | Pioneer PDP-507XD 50 in. Plasma Television
I have a panosonic surround sound system and a toshiba 60" tv and when watching tv speakers have a humming sound , but when watching a dvd speakers are fine and no humming sound.what is the problem? Tv...
it depends on what volume level the tv is on
if the level of volume is low and making the sound then try unpluging or pluging in the sound system to the tv
Sep 13, 2009 | Televison & Video
Surround sound not working with PS3..
hook your front speaker wires up to the A side and on the front of it make sure only the A speakers are playing but leave the rear speakers plugged into the B side then hit the listen mode button and you should be rocking
Apr 24, 2009 | Kenwood VR-407 Receiver
Sound changed
I would first go into your audio menu and make sure the correct settings haven't been changed, also the variable or fixed output is on fixed.
Does your set have the external surround sound speakers for the rear or are you using an external surround sound audio system?
Mar 03, 2009 | Hitachi 42 in. Plasma TV
Toshiba TV/VCR/DVD combo MW24F12
You did not say if you have connected the video out on the surround system to the video in on the tv. If not connect it and select that input on the tv.
Aug 27, 2008 | Toshiba SD-V392 DVD Player/VCR
No sound from daewoo 42" plasma
This particular model doesn't have internal speakers. It has two removable external speakers mounted on the left and right side of the tv. If you didn't get the external speakers with the tv, you won't have sound unless you use a surround sound setup.
May 23, 2008 | Daewoo DTS42 42 in. HD-Ready Plasma...
Sony KV-27FV16 no sound
Try going into the audio settings part in your menu and select reset audio settings.
May 16, 2008 | Sony KV-27FV16 TV
Toshiba 65H81 65" Rear Projection Television Logo
90 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
