Question about Maxell Flat Speakers With Subwoofer and Remote Computer Speakers
Right speaker dead
My right speaker is dead!!
only works sometimes when the music is loud, but as soon as i turn the music down dies again. i've tried unplugged and plugged again, but nothing. the cable is fine, but i think is must be the hub or something. how can i fix it?????. Thanx
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Good Morning Kev09
you have to replace the speaker , or the inside speaker see if something is loose, or cable inside, the welding.
for the other, just change the plug that connect the speaker.
good Luck
Posted on Nov 28, 2007
I have the Harbinger HA120 Portable PA System set up in my room. I've had the system for about two years, and naturally have put some loud music through the speakers. However, now, when I send anything...
You need to do some test on the equipment. First check the resistance of each speaker. You may have a bad cable... and yes you can destroy the speakers with too loud a signal... HOWEVER if the system is made to work together this is USUALLY not a problem.
Aug 25, 2011 | Harbinger HA120 Portable PA System
Hello! I'm having problems during a phone call with my speaker volume being too low unless speaker phone is on. All other sounds are loud & clear. I've tried resetting & turning the phone...
Did you happen to update to iOS 5? Because since the update. Mine has been the same way. The volume is very low. and sometimes even the speaker isn't too loud either unless I'm playing music.
If you did not update to iOS 5. Then your speaker might be blocked and easily cleaned with a cotton swab, or the speaker is just old and going out.
Jul 25, 2011 | Apple iPhone 3GS Black (16 GB)
My speakerset goes dead every time I try to listen to some music. It just turns off and I can't get it back on(like it has no eletricity). Then after a while(seconds, sometimes minutes) it turns on again,...
It is more likely a setting --either in Windows itself-- Windows Media Player-- or your soundcard controls.
I've had that set for 2-3 years -- every time it was a software issue.
They are great speakers.
Dec 28, 2010 | Logitech Z-5500 Computer Speakers
I have creative 2.1 channel with sub woofer and 2 speakers (left&right) all of sudden my right speaker is not working left only working then I pluggeg right speaker to left speaker jack in sub...
I have a similar reoccuring problem with the left channel on my speakers. All of a sudden, while playing music or whatever, the left channel jusr dies. Turning the system off and then on again from the conrol unit does not remedy the situation. By chance, I discovered a workaround to get the left channel working again: Push the main power switch of the subwoofer until it almost switches off and then release it so that the power is never actually switched off. Now a click is heard in the system and the left channel comes alive again. This is quite annoying and seems to have something to do with switches in the subwoofer. Low quality components may have been used. I 've been thinking of getting another 2.1 system, but it's not easy to find one... Maybe I should open the subwoofer box and go through the switches and possibly hardwire some connections...
Jun 27, 2010 | Creative Labs MegaWorks THX 250D Computer...
I was playing music last nite,and the amp cut off,feeling hot,very hot,now when i restart it it just turns off,any info on it,its a denon 3808.it was up loud,but the sales guy said this is the system to...
First thing to do is disconnect all speaker wires at the receiver. Then turn the unit back on. If it still shuts down, the problem is in the receiver and it needs to be serviced. If it stays on, reconnect your speakers one by one at the receiver and test. If there is a problem with a wire or a speaker, when you turn it back on it will shut down. If this happens, then disconnect the wire at the speaker and test again making sure the ends do not touch. If it still stays on, check the speaker for a dead short with a meter. If you are not familiar how to do this, go to any shop and they will test it for free. Hope this helps. If you need further help, post a comment and I will be glad to help.
Nov 17, 2009 | Denon AVR 2808Ci Receiver
08 nissan frontier problems
No you need a new battery or alt. or both running a stereo will kill both faster. and could carosion faster too.
Jun 29, 2009 | 2008 Nissan Frontier
Imac g5 speaker has very loud buzz
Check the cable of your speakers or
Download another Music Player
Mar 18, 2009 | Apple iMac G5 Desktop
Denon avr 2105 died (3 times) dead AVR2105 faulty avr-2105
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Jul 19, 2008 | Denon AVR-2105 Receiver
Speaker Problem
Try swapping the speakers to the opposite channels (left and right) and see if the problem is on the same side. If it is, then you may have a bad channel in your amplifier/receiver.
Jan 11, 2008 | Philips FWP900 System
Maxell Flat Speakers With Subwoofer and Remote Computer Speakers Logo
97 people viewed this question
Top Maxell Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Andrew Taylor
Andrew Taylor
Are you a Maxell Audio Player and Recorder Expert? Answer questions, earn points and help others
