Question about Kenmore 65812
Kenmore 106.72102100 Not cooling URGENT!
I've read the other posts, but they don't have the same symptoms as my fridge. The local repair guy I called said the model I quoted didn't exist, that I must have it wrong, but since I read it off the plate inside the fridge, I know it's right and he just isn't very good. It's a top-freezer Kenmore 106 Model 72102100, manufactured in May 2001, bought from Sears. I noticed yesterday it seemed a bit warm and assumed it was because we had put so much food in it (Ziploc bags full of the 25 pound turkey we cooked up, 5 pounds apples, bag of oranges, 2 heads lettuce, juice, water pitcher, birthday cake, 2 pies, huge thing of rice, PB, jellies, condiments, etc.) that the cool air wasn't able to circulate. I took out the water and apples to give room. The light comes on and the fan runs - I can see it when I pulled off the cardboard panel at the base on the exterior backside. This morning it's still warm and more CRITICALLY -- the freezer is warm on top!!! The cold air used to come out of the plastic unit in the middle back of the freezer - it was actually warm! Yes, there was food against that unit, but why would that make it warm? Things were already thawing. As a new mom, my freezer is full of irreplaceable breastmilk - something that I cannot buy and that my baby with allergies absolutely needs since he cannot take formula. Please please please can someone help??
  • Kenmore Master
  • 2,118 Answers
Re: Kenmore 106.72102100 Not cooling URGENT!
Next time if you notice that the bottom is cold and the top is warm make sure the evap fan motor is running,if the fan isn't running and you can check it by opening the freezer door,you should hear it blowing around, heat rises so the top will be warmer than the bottom,if you changed the evap fan motor you should be fine,i just worked on a kenmore that was totally warm,it was the start device so the compressor wasn't running but the evap fan was still working so if the machine was getting cold but the air wasn't moving because you had a bad fan motor you should be fine.
Posted on Jul 27, 2012
  • 213 Answers
Behind the back panel that you pulled off is where the compressor is. on the left side of the compressor is where the relay/overload is plugged in. its gone bad. if you touch the compressor it will either be really really hot or room temp. unplug it let the compressor cool and replace the relay/overload to fix your problem
Posted on Nov 28, 2007
0 characters
3 Points
I have a kenmore coldspot side by side refrigerator model#106.57372700 it's not getting cold on either side is there a reset button
Kenmore Elite Coldspot Side by Side Diffuser (1of2 ...
? 10:00
May 16, 2012 - Uploaded by Your32Maker
Kenmore Elite Coldspot Diffuser replacement. ... RefrigeratorRepair - Fresh Food Section Is Not Cooling , Kenmore , Whirlpool -59672213200 ...
Refrigerator Repair - Not cooling,Repair & Diagnostic ...
? 12:12
Jul 12, 2013 - Uploaded by
Fix a Kenmore Refrigerator suffering from some of the following symptoms: ... Not cooling,Repair & Diagnostic - Whirlpool,Kenmore 10671192101 ... Litton, Magic Chef, Montgomery Ward, Ikea, Cold Spot, Crosley, ESTATE, ...
Kenmore Coldspot side by side fridge/freezer not cooling the > Appliance
Question - Kenmore Coldspot side by side fridge/freezer not cooling the - HI. Find the answer to this and other Appliance questions on JustAnswer.
Kenmore Side by Side fridge not cooling? ' Yahoo Answers
May 16, 2013 - Hello! I have a 10 year old Kenmore Coldspot Side by Side model # 597799990 that stopped cooling on the fridge side. The freezer works fine.
kenmore coldspot is not cooling ' ShopYourWay > Manage My Life > Questions
Jan 24, 2016 | Kenmore Refrigerators
Kenmore 596 fridge not cooling and clicking, replace just relay or the capacitor too?
Jan 28, 2010 | Kenmore Refrigerators
Fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
Jun 23, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Kenmore coldspot 106.54563300 is not cooling. First the freezer stopped cooling then the fridge stopped. The fan is still working. Pulled fridge out, compressor was very hot. Is this a relay problem? If...
Not good news, it sounds like a compressor problem. Vacuum clean everthing you can safely get to in order to make it eaiser for the repair guy, (hopefully to save money). How old is the fridge?
Jun 21, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge not cold enough, but running it seems
Sounds like coolant is low in the system. Most fridges use a sealed system with refridgerant.
You may be able to have a sears guy or some other applicance house call repairman come and recharge it.
Also.. check that there is enough clearance around the fridge and that dust isn't clogging up the heat transfer pipes (that grid on the back.. or below the fridge) These guys need a lot of airflow to remove heat.
Oct 31, 2008 | Kenmore Refrigerators
Refrigerator not getting cold - freezer still pretty cold - perhaps not all the way I purchased a Kenmore fridge in Aug. 2005 (no freezer - fridge only). During a couple weeks...
assuming you have had the appliance unplugged for a while, plug back in and it may well work ok. if so, get back to me and i'll take it further
Aug 31, 2008 | Refrigerators
Amana Refrigerator
Dear friend,
ngfam at you service! happy to assist!
How old is the fridge ?
If its 10 years old its not worth repairing!
You will save enough money with a new fridge due to the fact that they are so much more efficient today!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Aug 28, 2008 | Refrigerators
Kenmore Fridge 4 yrs old side by side model not cooling
Hi. Your refrigerator is under 5 years and the compressor is still under full warranty. Call Sears and get it fixed parts and labor included. There should be no charge to you whatsoever. Make sure they understand that on the phone when you set up the appointment. You would be better off having a different technician from Sears come out to your house, as the one that came was not honest with you. Good luck, Mack
Jan 06, 2008 | Refrigerators
15 month fridge acting up
From what you describe, it sounds like the buzzing noise was caused by the compressor trying to start up, but not managing due to either a fault in the electrical supply, which may now be fine, or the compressor itself sticking. If the compressor was sticking, then there are three possible causes; - the fridge is either low on refrigerant gas (this contains the lubricant for the compressor too), if this is the case then $219 is not a bad price, shop around though - any fridge repair guy can do it, doesnt have to be sears/kenmore guys, but the warranty sounds useful. - just that the compressor was being temperamental. (sometimes happens but is fairly rare). If it doesnt happen again in the near future then your fridge may be fine. Third possibility is that the starter capacitor/condenser for the compressor is failing - this is a small part, quick to swap and cheap, although usually these either work, or they dont work - not much in between. I would recommend leaving it for a few days or so, and keep a record of the temperature every now and again - if it keeps getting warmer noticeably, or colder noticeably (i know it sounds odd but getting extra cold is a classic symptom of low refrigerant). Listen a bit, and see if you think the fridge compressor is running more often than normal if you can remember how it was, and if it keeps getting more frequent. If so - get it fixed. if everything stays about the same - temperature/amount of time running/noise then you probably can just hope for the best and leave it running, the moment anything changes, post again and we can probably advise you if it needs fixing or not. If you can spare the $219 then with the warranty attached it may be better to get it done anyway, but if it lasts a week with no change then it is probably fine for now. Hope this helps :)
Apr 02, 2007 | Kenmore 21.9 cu. ft. Side-By-Side...
Kenmore 65812 Logo
589 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
John Tripp
John Tripp
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
