Netopia router i am trying to forward some ports so i can play my playstation 3 games online but i dont know what to do once i am in router settings can anybody help me please........................thanks!!!!!!!!!!!!!!!!!!!!!!!
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hi, Johabes
Depending on the router, you assing and IP address, and insert the cables to the playstation, so be advice to check the router manual for inside configuration, and your system setup too.
Posted on Nov 28, 2007
How do i forward a port i want to play call of duty black ops but i cant find an online game, the game website says to forward these ports, TCP [80] UDP [88, 3074, 22728, 33233] but i dont know how to...
http://www.netopia.com/support/hardware/technotes/NQG_025.html
Server List (Port Forwarding) NQG_025 With NAT enabled, the IP addresses of nodes on your LAN are private since they are hidden from the Internet. IP Servers let you pass specific types of network traffic through the Netopia router's NAT interfaces. Once configured, selected types of network traffic, such as FTP requests or HTTP (Web) connections, will be forwarded to a specific host or server behind the Netopia router. Please Note: From the LAN (Local Area Network), you will also be able to access the servers that are responding to requests from the internet, but only using the internal private IP address. Access via the public IP address is not supported from a local ethernet connection. If your ISP is routing you multiple public IP addresses, you can also configure the router to forward all ports in one public IP to a designated private IP address on your LAN via Easy PAT List entries. For those instructions, see Quick Guide NQG_024: IP Mapping (Address Forwarding).
Please Note: If your router is currently running Netopia Residential Firmware with a web "GUI" configuration menu, this technote is not applicable to you. Most 3300 Series Netopia Gateways can be upgraded to Enterprise level firmware. Click Here! to purchase the upgrade key.
Related documents: NQG_039 NAT and the Basic Firewall
Firmware References:
  • v8.2 R1 (and up) - 3300 Enterprise Series
  • v5.3.7 (and up) - 4000 Series
  • v4.8.2 (and up) - R-Series
Before You Start
Telnet into the Netopia router's Main Menu at 192.168.1.1 (if using the default IP setting). If your network has a different IP addressing scheme, modify this accordingly. Click Here! for instructions on using telnet and Hyperterminal (serial connection).
Login with the user name and password. The Superuser login is required to save changes. If you are unsure of this, contact your network administrator.
Don't forget to press the Enter key to save any entries. Hitting the back space, delete or tab without first hitting enter will undo any changes.
The Esc key will take you back towards the main menu screen.
Once you have completed your configuration, you should reboot the Netopia to save and apply your changes.
The Netopia Main Menu Interface
Server List Configuration
  1. From the Main Menu of router console screens, go to Quick Menus, and select Network Address Translation.
  2. Select Show/Change Server List.
  3. Select Easy-Servers.
  4. From the Show/Change NAT Server List screen, select Add Server.
  5. Select Service and the service and port you want to allow. If your service and port are not available in the pull-down menu, select Other. Selecting Other will allow you to enter a specific service port or a range of ports since fields are provided for both a First Port Number and a Last Port Number. To allow a specific service port, the First Port Number and Last Port Number should be the same. Select Okay.
  6. Next, enter the Server Private IP Address, or the private IP address of the host/server you are forwarding the service to, and the Public IP Address you want to associate with the same host/server. This value can be left set to 0.0.0.0 if you are using the WAN IP as the Public IP address. Note: If your ISP is routing you multiple static IP addresses, other then the one used for Internet access, you may create more than one server for specific service as long as all servers have a different Public IP Address specified. For example, with two web servers on your LAN you would need to create two Server List entries for TCP 80 (www-http). Since each specific port (service) can only be mapped once using any given Public IP Address, a distinct public address must be used for each TCP 80 server list entry. It is not necessary for you to specify more than one Local WAN IP Address or Public IP Address in your router's configuration. As long as you are connecting to your ISP via a public IP address used for NAT, they are responsible for routing all other IP addresses via that connection.
Conclusion
You have now configured your router for TCP/UDP port forwarding. If you have a switched connection (ISDN or Analog), you will need to either disconnect and reconnect your Internet connection, or restart your router for the Nat Server List changes to take effect. If you wish to filter traffic for your static IP mappings, please see the following Netopia Technote:
NQG_039: NAT and the Basic Firewall
Nov 12, 2010 | Netopia CAYMAN 3387W-ENT CABLE/DSL...
Weak connection
improve ur brodband connection
Jun 14, 2008 | Sony Playstation 3 (PS3) Console
My Modern Warfare 2 Game Wont Let Me Play... Please Help!!!
It could be your router or network settings for your internet. Do you use Port forwarding? The Playstation site tells you all the ports you need to use. Also try putting your playstation in a DMZ.
Mar 09, 2010 | Activision Call of Duty 4 Modern Warfare...
I click on the play online and it says connecting to matchmaking server...it never goes any further than that.
Most likely you are behind a Firewall / or preset Router Settings. If this is the PS3 version of the game, most likely its the router. Double check with the specs for Port forwarding online, and make sure the ports are open to allow you to play.
-GamePorts required open / Notes Call of Duty 3Source & Destination port 3074 allow outbound + inbound on UDP and TCP. -
CoD in most instances uses the same ports for all there games. This is the first thing I found after looking through Google search. Hope it helps.
DrakeTech
Nov 11, 2009 | Activision Call of Duty 4 Modern Warfare...
Playstation 3 error 80030001
It sounds like you are losing your connection to either your router or ISP. You can try to disable the media server in Network Settings and also disabling the Info Bar on the PS3. Try again.
If problem persists, and you own a router...login to the router settings and disable UPNP, put your PS3 in the DMZ or google port forwarding on the ps3 and follow the steps for your router.
Good Luck!
Aug 23, 2009 | Sony PlayStation® 3 (80GB) Console
Ps3 setting up static nat
are you in ireland and with eircom?
Feb 19, 2009 | Netopia 2247NWG-VGx Wireless Router...
Was workin now not
You are having port issue with your router. If you could careless about playing the online content just sign out of the PSN and the game will work fine. If you want the online content/games you need to open/forward a lot of ports on your router. I had the same problem. The ports required are as follows: Port type: TCP: 9293; 6358; 25; 110; 80; 443; 5223; 10070-10080; 50000-65535*. Port type: UDP: 3074; 3075; 3658; 3478; 3479; 6000-6999; 7000; 50000-65535*. If you don't know how to open/forward ports call the router manufacturer and ask. *some routers will only let you enter 65534, but try 65535 first.
Jun 06, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3 lag issues
if u haven't already , you may need to adjust your router settings
1. enable UPnP
2. enable DMZ
3. change ip settings from dynamic to static
4. check out game sites as may have to port forward some ports
Feb 22, 2008 | Sony Playstation 3 (PS3) Console
Problem with udp port
check whether the port numbers are opened for that particular game that you are trying to play
if not go to the router manager i.e. the home page of the router that you have and try to open the ports
Also known as port forwarding
if u dont know the ports that you want for a particular game
U can goto www.portforward.com and chek out the ports available for games...
for any further help, plz reply back
Feb 18, 2008 | Sony Playstation 3 (PS3) Console
37 people viewed this question
 Grubhead
Grubhead
