Question about Hawking Wireless-G HWR54G (603992506064) 802.11b/g Wireless Access Point
Help setting up hwr54g as an access point
Hi
I have Verizon DSL with a Westell 6100 modem (not wireless)
My Westell modem is connected to a wired Linksys 16 port switch
The Linksys switch provides my home with Ethernet connectivity
My Westell modem serves as my DHCP server assigning IP’s in the range 192.168.1.15 through 192.168.1.254
IP leases are good for 99 days
All computers/devices connected to the Linksys switch are successfully assigned an IP address and can access the internet
I wanted to add wireless functionality to my home network. I purchased the HWR54G for this purpose.
I would like to configure it so that machines connected to it are on the same network as those connected to the Linksys Switch.
My understanding is this is referred to as an Access Point.
I called Hawking Tech support and they advised me to do the following to allow my HWR54g to act as an access point:
  1. disconnect the hwr54g from the home network
  2. connect a PC directly to the hwr54g
  3. access the hwr54g from 192.168.1.254
  4. turn off dhcp functionality on the hwr54g
  5. reconnect the hwr54g to the home network
I have done this with the following results:
  1. HWR54g router gets assigned an ip address from my westell router (192.168.1.95)
  2. a machine connected to a wired port on the hwr54g gets an ip address of 192.168.1.1 (conflicts with the westell router’s ip address)
  3. no connected machine has internet capability
  4. no machine can connect to the router via wireless (left as ssid hawking as an unsecured network)
Does anyone have any suggestions on this issue and/or understand if I am to set this up a different way for it to work.
My main goal is to have a single network all machines (wireless and wired) can see and access each other be it directly connected to the westell through the linksys switch or to the westell through the hawing router.
Thanks
  • madpunter Nov 28, 2007
    Hi Riziel,
    Thanks for your response. Currently my Westell has the PPPoE credentials Verizon requires. I currently have the setup depicted in the diagram working (see attached jpeg). I do use WEP encryption for my wireless network. However my 1.x and 2.x segments cannot "see" each other so for example my computer on the first floor cannot print the the LAN printer on the 3rd floor.
    When I try to make the hawking router and access point only and not a dhcp server, all appears to work ok, except none of the machines connected to the hawking router can access the internet and none of them seem to get assigned a valid IP address. If you have a moment I can be reached at vinceb29.nospam@gmail.com
    Scholar:
  • 116 Answers
Yes there is an easier way! Just setup the router as you would any normal setup. Follow the directions to set it up for the first time. What you want to do is have the put in all of your information that you need for it to communicate with your Modem. This will automatically place the router onto your network. Now the part that I believe you want is for this to be secure! Well setup either a WEP or WPA these are both encryption Protocols that will denie access to anyone other than you or someone you allow to access your network wirelessly.
You do not really have to go through all of the trouble of setting up specifics. As long as the two devices communicate the router and the modem will do the rest. I do this everyday in my daily work day! Anymore quesitons please feel free to ask!
Posted on Nov 28, 2007
  • Herman Briggs
    Herman Briggs Nov 29, 2007
    Ok Try this first make certain to set your Router up as a router not an access point! Not need to waste a good piece of equipment. Make certain that the router and the modem can communicate with each other. When you no for certain that the two can communicate with each other. After you do that try to connect one of your devices to the router wireless. REMEMBER, when you setup your Router make certain to Rename your SSID. So that every Device connecting to it can locate it by name not just Hawking 54G. I like to personalize my things. Now as I said before be sure to setup some type of security. Because even if you do not need it on a wired network this will keep people from using it on your wireless network. So that others are not allow to surf the web utilizing your network setup security. This is where WEP OR WPA come into play! If you need me to walk you through this my Yahool IM is Trochinmaster2003. I will walk you through it!
3 Suggested Answers
  • 21 Answers
SOURCE: how do I reset the Hawking HWR54G to factor
At the back of your device next to the WAN Port (internet port) you will find a small hole with a button inside it, turn your device off then press and hold the small button in while switching on your device, keep pressing down on the button for about 5 seconds, that will reset your router to default settings.
Keep Moving Forward.
Posted on Jul 18, 2009
  • 126 Answers
SOURCE: I need the IP address
You can easily get the Ip-details from , http://www.ip-details.com/ it is very reliable and accurate.
Posted on Aug 16, 2010
How do i connect my verizon dsl westell 6100 to my belkin g rtr?
Wellll....since it seemed an impossible task, I tried the next best thing.
I bought a wireless adapter for the other pc and voila! they are on the internet, and I am returning the router.
Westell modem + Verizon DSL w/usb = No connection to router.
Dec 28, 2009 | Belkin Wireless G Plus MIMO (F5D9010)
Switching from a verizon 6100 dsl modem to a 327w versalink
make sure that your old setup not still on go to connect to from the start and right click on the connection and see the one that you are using is present
Nov 08, 2009 | Westell Wirespeed VersaLink...
Blinking light on Westell 6100 DSL modem
I have a westell 6100 modem also- The light your are talking about always blinks- it blinks as long as the internet is working (it is sending and transmitting data)
May 28, 2009 | Westell Wirespeed LiteLine 6100...
I have DSL/verizon,modem 6100F i keep loosing my internet connection
modem did not correct for set up and help to set correct also sorensen router need to set up for modem thank
May 27, 2009 | Westell Wirespeed LiteLine 6100...
Ps3 key change timeout using westell 6100 modem on verizon
there might be a problem with the Linksys router, the Westell 6100 should be 1st set to bridge mode in order for your router to be connected to it. or there could also be a proble on the Verizon server.
Apr 10, 2009 | Westell Wirespeed LiteLine 6110 Modem
Switching DSL Modems
Your dsl line stays the same. you're only changing your dsl equipment.
if you are not able to go online using the 327w, you might need to have it configured depending on the type of connection that you have. if you are using PPPoE (which means you enter a username and password on the modem to connect to verizon) you need your 327w configured for pppoe. but if you are using DHCP connection, any modem or routers should be plug and play.
Most verizon customers from the west coast uses DHCP while those on the east coast uses PPPoE.
You can call tech support to make sure which type of connection you are using.
Mar 29, 2009 | Westell Wirespeed VersaLink...
DSL loses signal during VOIP call.
hi,
i worked for verizon for two years and I encounter this problem many times,to tell you honestly,its not with you internet connection since if you'll notice,while you are connected to the internet and you make a call or call someone,its interrupted... Obviously,its the phone itslelf,the signal comng from the phone is different from the signal of the internet...thats the reason why you need a modem to convert the signal coming from the phone line to make it work for internet,,,what I suggest is you change the DSL plan from the Dry Loop to the regular dsl with the phone...
thanks and God Bless
Mar 20, 2009 | Westell Wirespeed LiteLine 6100...
Can only get dsl if i use landline
Hi, Rob just studied ur problem.Iam a tech which handles this kind of issue. I talk to verizon,at&t,bellsouth,qwest daily for such issues. Well i can suggest u onething u can get the efficient speedstream 4100 series modem which comes with a 1 yr warranty. And also checkout with verizon clearly abt ur distance from the central office.Bcos might be ur dsl circuit may be not technically feasible i:e NTF. For further clarifications plz get back to me.
Jun 07, 2007 | Westell Wirespeed LiteLine 6100...
Hawking Wireless-G HWR54G (603992506064) 802.11b/g Wireless Access Point Logo
1,138 people viewed this question
Top Hawking Computers & Internet Experts
Steve
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
