Question about Olympus Camedia D-380 Digital Camera
Camera is instructing me to format media card but need the pics stored on it.Is there a way of reversing this, as I don't want to loose the pictures stored & it isn't giving me a choice... help please. I really don't want to loose them. regards raz
Hi Guys, contacted Olympus direct, and just passing on the info. in case anyone comes accross the same problem. Simply follow this link http://www.pcinspector.de/Sites/smart_recovery/info.htm?Language=1
and download the software for free for to recover.
many thanks raz
Posted on Nov 28, 2007
I'm taking photos with my Samsung D860, and when I want to view the pictures taken, it says 'no image', 'file error' or 'card error'. Sometimes it also says 'card...
Actually the camera is fine and the cause of problem is memory card, Mostly cheaper cards do this but the original cards don't. And as far as concern that you have lost many precious pics, No need to worry about it. Just install any recovery software on your PC and with the help of the software you can get back your pics, Secondly, shift all your pics on memory card in your PC and then format the card through camera, this will solve your problem.(Remember that run recovery software before you format the card if you need to get back your data from memory card)
Thanks
May 13, 2011 | Cameras
I am trying to transfer pics from my camera to my pc ??? i plugged it in and card is in camera but nothing?? help?
Here are some steps to run through to make sure the camera works as you'd expect it:
  1. Ensure that all cables are properly secured from the computer to the camera.
  2. Ensure that the memory card has not been dislodged from the camera.
  3. Check the camera's memory socket and the memory card for debris. A can of 'compressed air' can work wonders (typically available at any computer store).
  4. Make certain that the port connecting the camera to the computer is not damaged. Look for any bent pins in the camera's memory slot. Try replacing the camera cable. If the camera uses a USB port, try another USB port. If you don't have another USB port available, try plugging in another USB device to verify that the USB port is working.
  5. Check the power source on the camera. If you're using batteries while attempting to transfer the pictures to the PC, try changing your batteries, recharge the batteries, or use an A/C adapter.
  6. Try reinstalling the digital camera software on your computer. In most cases, reinstalling over top of the existing software will resolve this issue.
  7. Take the media out of the digital camera and attempt to download it to another computer. If all else fails, try formatting the camera media. Most newer-generation digital cameras equipped with an LCD screen have a menu option that can format your media.
Hope this helps.
May 05, 2011 | Panasonic Lumix DMC-LZ5 Digital Camera
Will not take pictures camera saying full when memory card is not full also when no memory card is in camera
Your camera is talking about its internal memory. If you want the card to start working, you must get rid of the pics on the internal memory. With no card in the camera, go into the menu and find "format" and follow the on-screen instructions.
Apr 04, 2011 | Cameras
My daughter has a polaroid a310 camera. She has a
You need to erase the internal memory. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions. Then, insert the card and do the format thing again. This will erase the card so download any pics from it you want to save using a card reader if necessary.
May 14, 2010 | Polaroid a310 Digital Camera
Camera say i need to format it because of a card error
First, get a card reader and download your pics to a computer. Then, format the card in the camera.
Jan 29, 2010 | Samsung L200 Digital Camera
After taking 30 or so pics all future images come up as file error?
it had a problem in saving the pictures ...so ...save the ones you can see..and format the card or the camera memory ..this will cause to loose any data ..but restore original storing functions ..it can be done from a computer using a card reader for memory card...or directly from the camera menu look for format ...and ok ...
Dec 25, 2009 | Sony Cybershot DSC-T200 Digital Camera
Pictures will not goto memory card. They only store to camera, therefore i can only take about 5-6 pictures?
Are the pictures stored in the memory important? Then go into the menu , scroll to "copy" and follow the instructions for copying from internal memory to card. Then, remove your card, bring up a picture from the internal memory and push the delete button...choose to delete all. Then, download any pics on your memory card to your computer using a card reader. Then, insert your card back into the camera, go into the menu, scroll to "format" and follow the on-screen instructions. After all this, you should be ok.
Nov 29, 2009 | Panasonic Lumix DMC-TZ2 Digital Camera
Card Error
Take no more pics until you've recovered the photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for.
You will need to use a flash card reader with this software. If you don't have one, get one, they're very inexpensive.
The reason this occurred is that you likely never formatted the card. The card will work fine in the beginning but eventually will corrupt. AFTER you've recovered the photos, format the card in your camera to prevent this from happening again (dig out that instruction manual to figure out how). Keep in mind formatting will also totally erase your card, so again only do this after you've recovered the photos.
Oct 04, 2009 | Cameras
Nokia 6131 - Memory card/camera
you have to try to format your memory card, but dont forget to backup your files before formating it. good lack
Jun 25, 2008 | Nokia 6131 Cellular Phone
Olympus Camedia D-380 Digital Camera Logo
43 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
